Old 11-07-2012, 04:25 PM   #589
sa1126
Drives: n/a
I took the car in for "diagnostic checks" and they determined mine qualified for the TSB. Ironically the sound seems to be very random now.
Raven MT as of 07-09-2012
'01 Taco prerunner
sa1126 is offline   Reply With Quote
Old 11-07-2012, 04:35 PM   #590
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
As the weather cools down, you'll likely hear it less and less.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 11-07-2012, 04:35 PM   #591
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
getting my pump replaced as we speak..ill give u guys feedback when i get the car back
brichard0625 is offline   Reply With Quote
Old 11-07-2012, 05:13 PM   #592
Lowellrenzo
Drives: Civic Si coupe
Just got my hpfp done no more cricket. Now the car seems to stall easier than before and odometer doesn't show what gear you in no more. Anybody got that problem?
Lowellrenzo is offline   Reply With Quote
Old 11-07-2012, 05:23 PM   #593
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
Took my car in for the TSB and the crickets have now come back. it isnt as bad as it was before i took it in but it does happen every so often
MrTranxD is offline   Reply With Quote
Old 11-07-2012, 05:57 PM   #594
killa.sushi.robot
Drives: 12 Sienna Se, FR-S Asphalt 6MT
Took my FR-S in yesterday, got it back later in the evening. Guess I'll just have to wait to see if comes back.
killa.sushi.robot is offline   Reply With Quote
Old 11-07-2012, 06:34 PM   #595
brichard0625
just got mine done and no more crickets but i still have to the cel p0018 and i have to open a case with toyota..they want to rip the engine apart but i rather them change the ecu first because they start digging in because when i checked the fuel pump there was a screw that wasnt tightened, and a clamp that was missing so i had to fix it myself which makes me nervous on taking the car apart. Can anybody when they get a chance just take a picture of the hpfp because it doesnt look properly installed..i didnt have time to check while i was there because it was snowing and they were closing shop due to the snow...thanx guys
Old 11-07-2012, 11:29 PM   #596
sf86
sf86's Avatar
Drives: Red Scion FRS AT
the cricket has come back after a few hundred mile. Should i take it back to the dealer to do another fix or just leave it this way ? the noise is really bothering me.
sf86 is offline   Reply With Quote
Old 11-07-2012, 11:51 PM   #597
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Call Scion. The dealer won't have a fix for you (neither will Scion, but they can document it for you).
Subie is offline   Reply With Quote
Old 11-08-2012, 01:09 AM   #598
Jeong
Drives: pet dragon
my noise is pretty bad and it gets really annoying at times but i need my car for work. i know its probably been asked but theres too much posts to read. how long would a fix normally take?
Jeong is offline   Reply With Quote
Old 11-08-2012, 03:12 AM   #599
brichard0625
one day really...if u bring it at 8am should be done by 3:30-4
Old 11-08-2012, 08:15 AM   #600
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
So my best friend is a tech at toyota. i asked him to get the low down on the cricket TSB the report to the A techs says , there is no fix if the customer wants a new fuel pump. basically in quick terms "there is no fixed fuel pump give them the brand new still shitty fuel pump" but yes being documented would be good. but he said realistically youll just be annoyed since it will be the same exact part.
id say wait a few months till a true fix has been made. thats what i plan to do.
i havent heard of anyone having engine failure or fuel system failure due to the HPFP to immediately need the fuel pump change. i read its the plunger that squeaks correct me if im wrong but it could just be a normal thing for the DI in this engine to do i mean i have heard this exact sound in VW 2.0T FSI engines.
again i could be incorrect. ill try to scrounge up some more info from the A techs when i get a chance.
DanoFA20 is offline   Reply With Quote
Old 11-08-2012, 09:26 AM   #601
HunterGreene
Hail Magnet
HunterGreene's Avatar
^This is the reason I plan on waiting until the spring, when my car comes out of hibernation to have this addressed.
Again, the clicking/tapping sound is normal for the DI system. The chirping is not.
Old 11-08-2012, 11:52 AM   #602
DanoFA20
Shift Down
DanoFA20's Avatar
correct.
Hood & Bumper Gap on BRZ mact Issues | Warranty | Recalls / TSB 17 02-25-2015 01:22 PM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 07:39 PM
Dry carbon fiber hood ChrisOkc8 Cosmetic Modification (Interior/Exterior/Lighting) 13 08-26-2012 11:58 AM
vented hood? 75 carrera Cosmetic Modification (Interior/Exterior/Lighting) 2 07-02-2012 10:57 PM
