Old 11-05-2012, 07:11 PM   #1
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Can i put a gallon of 87 octane?
Over here in New York were having a bit of gas crisis and i have a gallon of 87 octane in the garage, its maybe about two years old. I was wondering if i could use it for the FRS if i really have to or should i just pray that i never have to use it?
Thanks!
Old 11-05-2012, 07:13 PM   #2
wu_dot_com
Drives: accord
the short answer is yes. but you will encounter reduce performance.
now if you can get your hands on some octain booster, that could help.
if you do add 87, make sure to take it easy on the engine.
wu_dot_com is offline   Reply With Quote
The Following User Says Thank You to wu_dot_com For This Useful Post:
Bluecille (11-06-2012)
Old 11-05-2012, 07:22 PM   #3
DarkCard
Drives: Asphalt Scion Frs 6MT
Thanks!
I'm with you man, I threw 87 in, im not beating on it so it should be alright... no signs of any issue yet.
DarkCard is offline   Reply With Quote
Old 11-05-2012, 07:27 PM   #4
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
Thanks!
You can but, but until that gallon is done drive EASY. If you can avoid uphill driving on severe inclines. It's only a gallon it's not like you're filling your tank with it so you'll be fine. Just know that preignition is no joke, I've seen holes punched through pistons because of it. Like wu_dot said, if you can get your hands on some octane booster use it
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline   Reply With Quote
Old 11-05-2012, 07:27 PM   #5
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
be wary of gas that is over 6 months old and contains ethenol. That breaks down and will foul your engine. Sta bil or other products will allow you to store it.
5hairpins is offline   Reply With Quote
The Following 2 Users Say Thank You to 5hairpins For This Useful Post:
adprokid (11-06-2012), Guff (11-07-2012)
Old 11-05-2012, 07:29 PM   #6
that_one_guy
Drives: none
I would be more concerned with the fact that it is 2 years old than I would with the octane, make sure there is no dirt or water that could have gotten in from moisture build up over the years.
the higher octane fuels will be less resistant to combustion under compression. you won't find the knocking that used to be the case with old engines running lower octane than they were designed for, but you will lose a few horsepower. Also, I don't believe octane booster does much, if anything at all, at least from the articles/tests I've seen.
that_one_guy is offline   Reply With Quote
The Following 2 Users Say Thank You to that_one_guy For This Useful Post:
2pt5RS (11-05-2012), dem00n (11-05-2012)
Old 11-05-2012, 07:43 PM   #7
TheSt|G
TheSt|G's Avatar
Drives: BRZ L 6MT, 128i 6MT, E39 M5, E36 M3
Say hello to probable gunk and a reduced lifespan for your fuel filter in addition to the knock issues you will likely have.
I would do everything in my power to avoid it.
3.2 911 5MT
BRZ Limited 6MT
BMW E82 128i 6MT
BMW E39 M5 6MT
BMW E36 M3 5MT
TheSt|G is offline   Reply With Quote
Old 11-05-2012, 07:50 PM   #8
sierra
Drives: Skoda Yeti DSG diesel 4x4
Use it in your lawnmower.
sierra is offline   Reply With Quote
The Following 3 Users Say Thank You to sierra For This Useful Post:
DBacon1052 (11-07-2012), Ingen (11-05-2012), number1Tango (11-07-2012)
Old 11-05-2012, 08:06 PM   #9
wu_dot_com
Drives: accord
if its just 1 gallon i think it should be okay. perhaps run some gunk cleaner like techron later would help with gunk buildup.
Old 11-05-2012, 08:11 PM   #10
FantomRider
White Fantom
FantomRider's Avatar
Drives: Whiteout FR-S
Send a message via Yahoo to FantomRider
How much would you save? Is it worth it? If yes, use it on you.
Eibach Prokit Lower Springs
Injen Intake
Xenon 6000k HID
Beat-Sonic Shark Fin
Greddy Evo3 Catback
FantomRider is offline   Reply With Quote
Old 11-05-2012, 08:13 PM   #11
dem00n
dem00n's Avatar
Drives: Scion FRS
Alright, thanks guys.
I think i'm going to let it stay since its over two years old. Though a lot of gas stations are only selling 87 octane only as well, if i have the patience/balls to wait in line for hours to get some gas. Can't even get full tank, can only do 20 bucks...
Old 11-05-2012, 08:15 PM   #12
dem00n
dem00n's Avatar
Drives: Scion FRS
Frankly, a gallon can get me to school and back and considering the fact i personally know people who wait on line for gas more then 4 hours and not even get a drop of gas...its pretty risky. Theres tons of cars around of empty gas stations just because they run out of gas waiting...its quite nuts.
Old 11-05-2012, 08:18 PM   #13
jabbajaw99
jabbajaw99's Avatar
Drives: FT-86, VW Tiguan
If it were fresh 87 octane sure. 2 year old, without stabilizer, no way!
jabbajaw99 is offline   Reply With Quote
Old 11-05-2012, 08:21 PM   #14
gmookher
you'll be fine, just dont go beatin on it...
91 octane fuel EN2_Squirrel Forced Induction 1 10-05-2012 12:13 AM
93 Octane Smokinbuffalo Northwest 20 09-02-2012 06:24 PM
94 octane now at petro Sasquachulator CANADA 19 08-09-2012 02:11 PM
110 octane EZWood Engine, Exhaust, Transmission 19 06-29-2012 09:12 PM
93 Octane? ashtray BRZ First-Gen (2012+) — General Topics 175 04-04-2012 01:22 PM
