Old 11-05-2012, 12:02 AM   #1
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
Stock Mud Guard Install DIY (BRZ & FR-S)
This DIY guide will walk you through installing the stock mud guards on your BRZ/FR-S. These can be purchased @ any Scion dealer for around $65. The part number is PU060-18013-P1
Proceed at your own risk, I'm not responsible for any harm to yourself or your car that occurs while following this guide. Always be careful when under a motor vehicle, ensure it is properly supported at all times.
HERE IS THE STOCK PDF: BRZ Mudguard Installation Guide.pdf
Equipment required:
19mm socket for lug nuts (lug key if needed)
Breaker bar with 3" extension
Torque wrench
Bone tool (or flat head screwdriver for prying)
#2 Phillips screwdriver
5/16" drill bit (or 8mm)
Electric drill
Floor jack
Jack stands (x2)
Wheel Chocks
What's included w/the Mud Guards
FRONT INSTALL PROCEDURE
NOTE:
- Ensure the car is in gear and parking brake engaged.
- The first step is to break loose the lug nuts on the front wheels. Use a breaker bar, as most torque wrenches should not be used to untorque nuts.
- Next, jack up the front of the car.
NOTE:
- I recommend using a set of jack pads like these, got them @ Harbor Freight for $8
NOTE:
- Ensure all tools have been removed from underneath vehicle
- Install the lug nuts to finger tightness while wheel is in the air
- Once on the ground, torque lugs in a star pattern to 89 ft-lbs
...SOLD my WRB BRZ...
Replaced with a 2013 Mazdaspeed3!
JonnyRocket is offline   Reply With Quote
The Following 24 Users Say Thank You to JonnyRocket For This Useful Post:
Anthonytpt (01-30-2013), BareZ (01-15-2016), Ben_G (11-12-2012), BirdTRD (10-26-2013), bpracer (12-24-2012), CA2 (01-14-2013), cheesesteak (04-16-2014), chenshuo (03-04-2013), ChiefG (03-31-2014), chimmay (11-06-2012), CoolBReeZe (01-08-2014), CoRi J (11-22-2012), evil_1998 (04-13-2013), FRSGT86 (09-16-2013), jcw99 (03-06-2016), JPxM0Dz (11-05-2012), Khyron686 (05-05-2013), Overdrive (01-10-2017), shyong (02-13-2013), Stierzy34 (08-16-2013), Suberman (08-24-2013), tanner (06-09-2014), tk1138 (03-04-2016), Wally86 (06-19-2020)
Old 11-05-2012, 12:03 AM   #2
JonnyRocket
"New hotness"
REAR INSTALL PROCEDURE
NOTE:
- The first step is to break loose the lug nuts on the rear wheels. Use a breaker bar, as most torque wrenches should not be used to untorque nuts.
- Place wheel chocks in front of the front tires.
NOTE:
- Most torque wrenches should be returned to 0 ft-lbs when not in use.
The Following 37 Users Say Thank You to JonnyRocket For This Useful Post:
86 4 FUN (02-07-2014), BabaYaga (12-22-2014), Ben_G (11-12-2012), BirdTRD (10-26-2013), calis5nest (06-22-2013), Chanpion (04-04-2015), chenshuo (03-04-2013), ChiefG (03-31-2014), chimmay (11-06-2012), CoolBReeZe (01-08-2014), CoRi J (11-22-2012), Dadhawk (10-04-2013), dodj (02-23-2014), everythingsablur (09-12-2016), Flow (06-14-2015), FRSGT86 (09-16-2013), GTB/ZR-1 (12-02-2012), Gums (12-08-2012), HyperTech (06-23-2014), isolato (12-29-2015), johnb831 (11-05-2012), Khyron686 (05-05-2013), kludger (11-25-2012), kwood9000 (11-12-2012), mrg666 (11-04-2016), Namuna (01-24-2014), NorCal_Guy (03-29-2014), Pacific (08-24-2013), Packofcrows (03-27-2015), piotrr (06-19-2014), russv (11-12-2012), sato (04-04-2016), Scooby South (12-26-2012), Sigh-on-Rice (03-21-2022), Stierzy34 (08-16-2013), Wally86 (06-19-2020), wu_dot_com (11-05-2012)
Old 11-05-2012, 12:39 AM   #3
johnb831
johnb831's Avatar
Drives: SWP 2013 Subaru BRZ Limited
Thanks for the DIY
johnb831 is offline   Reply With Quote
Old 11-05-2012, 02:03 AM   #4
JonnyRocket
"New hotness"
Originally Posted by johnb831 View Post
Thanks for the DIY
Happy to help the community.
Old 11-05-2012, 02:06 AM   #5
dsgerbc
Drives: BRZ(sold), STI
The key step missing: wash the car first. No point in locking dirt under theguards. Also, I'd include scion instructions pdf in the OP.
Nice pics.
Old 11-05-2012, 02:34 AM   #6
JonnyRocket
"New hotness"
Nice pics.
Washing it first really goes without saying. Although I did note on one slide that I wiped down and QD'd (quick detailed) the area under each guard.
As for the stock instructions, that's a good idea. They've been added to the original post
Old 11-06-2012, 09:37 PM   #7
chimmay
chimmay's Avatar
Drives: Scion FR-S, Scion TC
i need to get me some mud guards now. Thanks for the DIY
chimmay is offline   Reply With Quote
The Following User Says Thank You to chimmay For This Useful Post:
JonnyRocket (01-10-2013)
Old 11-06-2012, 09:53 PM   #8
PrinzJ
Drives: White Fr-S and Black 9thgen Corolla
just got mine today. color matching it though ill put up pics when im done. thanks
PrinzJ is offline   Reply With Quote
The Following User Says Thank You to PrinzJ For This Useful Post:
Old 11-12-2012, 03:02 PM   #9
Ben_G
Drives: Blue BRZ
Just finished installing today. Great write up. Only $50 for the set from Toyota.
NOTE - Not sure why, but the baggies of screws and clips have different part numbers than the OP's bags. However, the front hardware is packaged with a front splash guard and the rear hardware is packaged with one of the rear splash guards. Even if you get them mixed up, only the rear uses the short metal clips, so that bag belongs to the back.
Ben_G is offline   Reply With Quote
The Following User Says Thank You to Ben_G For This Useful Post:
JonnyRocket (11-12-2012)
Old 11-12-2012, 06:09 PM   #10
Dezoris
Dezoris's Avatar
Thank you.
I will be doing this and dedicate the install to you. Although it looks dangerous, if I cut myself with one of the mud guards I will also be suing everyone in this thread.
The Following User Says Thank You to Dezoris For This Useful Post:
Old 11-12-2012, 06:43 PM   #11
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
EZ install, didn`t need to drill or take off wheels.
speedy racer is offline   Reply With Quote
The Following User Says Thank You to speedy racer For This Useful Post:
alex_86 (09-15-2013)
Old 11-12-2012, 06:47 PM   #12
xcelir8brz
Drives: 2013 BRZ Limited
I installed hardware without drilling as well. Installed a bit differently.
xcelir8brz is offline   Reply With Quote
The Following User Says Thank You to xcelir8brz For This Useful Post:
Old 11-12-2012, 07:03 PM   #13
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Awesome DIY!! Keep up the good work!
Beyer Subaru is offline   Reply With Quote
The Following User Says Thank You to Beyer Subaru For This Useful Post:
Old 11-12-2012, 07:31 PM   #14
JDMenrique
DEEEERP
JDMenrique's Avatar
thanks!
on a side note i seriously need to buy these.
JDMenrique is offline   Reply With Quote
The Following User Says Thank You to JDMenrique For This Useful Post:
flaps, guard, mud, mudflaps, rally armor
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 04:27 PM
Mud Guard Question geb2391 BRZ First-Gen (2012+) — General Topics 36 03-01-2013 07:37 PM
Opti guard in or near oklahoma? Flako Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 10-22-2012 08:00 PM
Opti Guard ExWhyZer0 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 10-10-2012 04:22 PM
'13 BRZ | Opti-Guard fun! michakaveli Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 09-02-2012 06:50 PM
