Old 11-02-2012, 04:02 AM   #183
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
Has anyone debadged the rear Subaru emblem on the BRZ? I'm curious how it will look completely naked....
speedracer38 is offline   Reply With Quote
Old 11-15-2012, 08:43 PM   #184
Fizzle
FizzRS
Fizzle's Avatar
Drives: Scion FR-S Asphalt
Originally Posted by DarrenDriven View Post
Easy to do, looks good.
Before you begin, you need an FR-S with badges.
You also need:
- window tinting hard squeegie
- heat gun
- lacquer thinner
- cleaner and wax
Start by using the tint squeegie to work behind the emblem. The tool is plastic that won't scratch your clearcoat.
Once I got the Scion emblem off I realized there are holes behind it. Oops, I'll figure out a way to make this look good later.
Hit the leftover adhesive with the heat gun. Make sure you move it around so that you don't hurt your paint. You just need to get the adhesive warm.
Once the adhesive is warm you can peel it off with your fingers. There will still be a little bit of residue left.
Use lacquer thinner with a soft cloth to remove the residue without hurting your clearcoat. Don't scrub it, just get it wet and then use your finger to remove larger chunks.
Clean and wax the area. I didn't use paste wax because sometimes fresh paint needs to breathe and I'm not sure how long ago this car was painted. I'll apply real wax soon, though.
The finished product.
Hey Darren, im trying to debadge my front emblem but it is so hard to take them off is there any pushpin thats holding it? its not like the back one thats easier to take off..the front one seems to be holding it so tight
please help!!
Fizzle is offline   Reply With Quote
Old 11-15-2012, 09:19 PM   #185
Fizzle
FizzRS
Fizzle's Avatar
this front badge is a TOTAL bitch!!!!
Old 11-15-2012, 10:35 PM   #186
DR 86
DR 86's Avatar
Front has pushpins. I swapped mine when i removed the bumper for other mods; otherwise, just use some force and snap it off.
DR 86 is offline   Reply With Quote
Old 11-25-2012, 11:54 PM   #187
olorin
olorin's Avatar
Drives: GBS Premium
Just did the letter badging on by GBS BRZ, hardly needed to scrap the adhesive. Was about 55 deg outside. I used a soft plastic spreader to pop the letters off.
Thanks for the guide.
olorin is offline   Reply With Quote
Old 11-26-2012, 04:51 AM   #188
86WRX
Drives: Asphalt
How come no one put a Subaru badge over Scion? Just wondering or does it make sense? If someone think of a Lexus badge??
86WRX is offline   Reply With Quote
The Following 2 Users Say Thank You to 86WRX For This Useful Post:
SkitterSkotter (04-01-2013), TOTO_86 (12-09-2012)
Old 12-03-2012, 08:26 AM   #189
Kairo
Drives: 2013 Scion FRS
I wish I saw this before I used goof off. Yikes. lol...
Kairo is offline   Reply With Quote
Old 12-15-2012, 02:02 AM   #190
vujosephv
vujosephv's Avatar
Drives: Raven
what did you use to put the toyota badges on?
vujosephv is offline   Reply With Quote
Old 12-15-2012, 07:04 PM   #191
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
Holy moly I removed the frs badge and what a pain in the butt was it to get off the adhesive crap. I easily removed the plastic badge itself with some waxed dental floss but that adhesive was horrific. I used turtle wax bug and tar remover with some coaxing I got it all off after an hour. Blehh. I've never had an issue when debadging my 02 celica, 06 tc or 08 Altima coupe
mikeg7827 is offline   Reply With Quote
The Following User Says Thank You to mikeg7827 For This Useful Post:
TheFRSChick (12-17-2012)
Old 12-21-2012, 10:16 PM   #192
Pavel
Drives: Raven 2013 Scion FR-S
Just debadged my Scion Fr-s today. I only removed the FRS symbol though. Items that i used: hair dryer, tooth floss (I recommend fishing wire tho), Automotive Goo Gone, and car wax. Here's the debadging process that I followed:
1. Clean the back of the car really well and let it dry.
2. Open the trunk half way and blow hot air on the frs sign with a blow dryer. I had it on high and I held it about 8 inches away from the emblem. I had the trunk open just to avoid unnecessary heat going on plastic bumper.
3. While applying the heat control the temperature of the trunk. If it is getting too hot to touch it, then you are overheating it. It only needs a bit of heat actually. Also grab the FRS logo with your fingers and see if you can move it slightly. If it allows you a bit of play, then you are good to go.
4. Close the trunk and begin removal. I used tooth floss, but I believe that fishing wire would be much better. I just didn't feel like buying fishing wire. I started from the right side and went towards left. Don't rush, take it slow and just cut through the glue.
5. After the entire logo was removed, I heated the remaining glue on the car just a bit and pealed it off with my fingers.
6. Then used a clean cloth and Automotive Goo Gone to clear the surface completely.
7. Then waxed the entire area and car looks like the symbol was never there.
Pavel is offline   Reply With Quote
Old 12-22-2012, 12:20 AM   #193
jshadeck
jshadeck's Avatar
For those asking about the fender badges pins lining up in place of the scion badge, they do not. The fender badge will fit nicely covering the two holes on the trunk (as pictured already) and on the front, in order to cover both holes you would have to place the emblem below centered, but not too far off.
jshadeck is offline   Reply With Quote
Old 12-27-2012, 10:42 AM   #194
tdoggy57
tdoggy57's Avatar
Drives: Asphalt Scion FR-S
I have almost like an indentation/outline of the FR-S letters after i debadged...annoys the hell out of me
tdoggy57 is offline   Reply With Quote
Old 12-31-2012, 05:24 PM   #195
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
hey darren, im curious. im planning on doing this to my car as well. the only concern i have is, do they come with the adhesive? or do i have to get my own? how do i stick em on?
Dispect is offline   Reply With Quote
Old 12-31-2012, 05:46 PM   #196
Anorax
Drives: '13 BRZ SS
Like the 86 badge on the rear. Considering it for my BRZ, but not sure it'll cover the pins...
Front Subaru badge would be a nightmare, since its indented.
Anorax is offline   Reply With Quote
teq emblem
Debadging - How difficult will it be? Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 86 06-24-2014 11:49 PM
