#29 |
ლ(ಠ益ಠ)ლ
Drives: E36 5.7 V8
2012 Civic sucks. 6700 rpm redline? for a 4 banger? compare that to their only rwd car, the s2000, with a redline of 8000! If you have ever sat in a car with a redline like that, youd understand why its so important.
I wonder if it can be flashed to get a higher redline though. Imagine a 2.5l 4 cyl with a redline of 9000? lol
I wish I was cool enough to have an FR-S
#30 | |
4G63 & Rotary
#31 |
Registered you sir
Drives: 99 impreza coupe
The AP1 2.0 s2k does have a 9K redline.
#32 | |
ლ(ಠ益ಠ)ლ
Drives: E36 5.7 V8
Notice I put reflashed to a higher rpm... AFAIK, in a reflash for higher rpm, you dont do anything to the low end.
#33 | |
4G63 & Rotary
Look at the EJ25, the engine is good till 7k, they limit it to 6400 to be cautious. The primary limiting factor and reason for being cautious is the crankshaft's inability to oil the internals at higher RPMs. So unless you're going to increase the bore on the lubrication holes, as well as lighten the rotating assembly and rework the valve train, you're not going to notice any performance increase. ![]() Dyno of a 2.5RS. Thinner line is the baseline with factory internals. Darker line is a reflashed 2.5 with Delta wild cams, OBX headers, Magnaflow cat, 2.25" mandrel midpipe, prodrive axel-back, Cobb intake, and LW crank pulley (~$2200). The factory power band starts to fall on its face well before the redline, just increasing it wouldn't give you any more usable power. It wasn't until after over 2grand in parts that he squeezed a noticeable bit of power out of it. Granted this isn't the motor going in the FR-S, but I highly doubt the FR-S motor will be a game changer. |
#34 | |
Site Moderator
Drives: Stuff
Now once the cams, etc are modified and you can make power above the stock redline, well the reasons are pretty obvious then. The boxer that goes in this car needs to be capable of at least 7.5-8k IMO with no internal changes.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#35 | |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
B
#36 | |||
4G63 & Rotary
Bouncing off the limiter depends on the vehicle. Cars like Vettes and GT3s can bounce off the limiter and maintain power. You're not going to lose anything coming around a corner by not being able to tach it out a little longer in cars like that. On the other hand, if it's more like a 370Z that falls on its face when it hits the limit as if VDC was activated, then a few more rev's will help. Quote:
#37 | |||
Site Moderator
Drives: Stuff
but all of my recent cars didn't fuel cut until 8200+.. so.. :shrug: currently one fuel cuts (stock) at 8200, one at 8500, and one will be 9000 soon (with stock valvetrain that would normally cut at 8500).
-Dave
| Anybody here getting that greasy "$27k" feeling? | rifleshooter | Scion FR-S / Toyota 86 GT86 General Forum | 360 | 12-02-2011 06:42 PM |
