Old 10-30-2012, 11:57 PM   #3445
DSTL
Drives: 2013 BRZ Limited 6MT
Originally Posted by BAE View Post
My car is running on the 10826 file. It is not locked up, but the fuel gauge is wrong etc. What shall I do? Re-flash to the stock file? Fill in a form? Why is not the improved file sent to everyone? I am getting tired of this mess. I thought I bought a tested product.
You won't get the updated tune unless you fill out the form, and shouldn't flash anything but stock or newest version... and then only on a fresh ProECU update. There was another issue on Ecutek's end so there aren't general updates going out right now, per request only. Should change soon, no ECU lock ups yet on new one.
Edit: New update may have been capped at 10 for testing? Can't remember now, it's all here though. I didn't soak it all in while it was going on, was just running the stock ROM and waiting it out.
DSTL is offline
The Following 2 Users Say Thank You to DSTL For This Useful Post:
BAE (10-31-2012), zkubidu (10-31-2012)
Old 10-31-2012, 12:23 AM   #3446
boris
Drives: 2013 white scion frs
can some one explain how the launch control works please? i followed the step someone posted a few page back and it still doesn't seem to work.....
boris is offline
Old 10-31-2012, 02:01 AM   #3447
Yruyur
Yruyur's Avatar
If I had the time I would love to start a wiki page that has the following
Full instructions of all features
Video walk throughs of install, flashing and features
Release notes of each version
Version status , supported vs discontinued support
Flash status ok to flash vs don't flash
Current Ecutek version
Formatting of the flash filenames
Faq's
Order forms
Contact info
Wiki format would be nice so that we could all help answer questions but stay away from some of our other conversations. Anyone have the time or knowledge to do this?
Sent from my flux capacitor using Taptalk
Yruyur is offline
The Following User Says Thank You to Yruyur For This Useful Post:
Sambosis (11-01-2012)
Old 10-31-2012, 03:27 AM   #3448
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
With the newest flash/racerom. From a complete stop with the car in neutral and the car on any map 2 or higher....
Clutch in to the floor, shift to first, push the gas all the way in. Floor it 100% or it wont work.
If the needle goes above 4k lift before you hit the limiter and try again.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline
Old 10-31-2012, 04:56 AM   #3449
Hawaiian
That guy
Hawaiian's Avatar
So, some of you already know this stuff, but since some don't i thought i would post this up.
This is what is going on durring the tuning process.
The short version.
Garrett
The long version.
autospeed
Ultramarine mt FR-S
P&L stage 1 turbo
Hawaiian is offline
The Following User Says Thank You to Hawaiian For This Useful Post:
Yruyur (10-31-2012)
Old 10-31-2012, 02:15 PM   #3450
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
Thanks! But is it unsafe for the car to run the 10826 file? Should I reflash to stock while we are waiting for a finished product from this supplier?
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline
Old 10-31-2012, 02:19 PM   #3451
Hawaiian
That guy
Hawaiian's Avatar
If you've already installed it, it's safe. If you install it it can lock up your ecu in a very very bad way. As John said, every time you run the install with that map, you're rolling the dice.
Ultramarine mt FR-S
P&L stage 1 turbo
Hawaiian is offline
BAE (10-31-2012)
Old 10-31-2012, 02:38 PM   #3452
DSTL
Yup, if it's on the car already you're good. No worries.
DSTL is offline
Old 10-31-2012, 04:33 PM   #3453
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
I flashed back to stock, as I have an appointment for the dealer to check the fuel pump for the 'chirp', as well as the rattling/fluttering sound coming from the rear.
Filled out the form; looking forward to a tune I can put on the car.
Symbiont is offline
Old 10-31-2012, 05:01 PM   #3454
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
John I have emailed you a few times regarding my tune file not being customized to my car (this all stemmed from me filling out the form, then you sending me the files and telling me to let you know if I have had any problems) We fixed the license issue and I am now good to flash but I got the not customized to car error and naturally can't go any further.
I emailed you a screen shot (on monday night I believe) so you can read the exact error. Hope that helps
SkAsphalt is offline
Old 10-31-2012, 05:05 PM   #3455
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
I'd loan you one of my tunes if I could
2URGSE
JPxM0Dz is offline
The Following User Says Thank You to JPxM0Dz For This Useful Post:
SkAsphalt (10-31-2012)
Old 10-31-2012, 05:09 PM   #3456
Yruyur
Yruyur's Avatar
How did you fix the license issue?
Yruyur is offline
Old 10-31-2012, 05:11 PM   #3457
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Not to sure but i know CT was a in a state of emergency and most of the places had power outages. So john might be MIA for a little while. Tried to text him and see if he was okay but no response..Hope hes alright
brichard0625 is offline
Old 10-31-2012, 05:14 PM   #3458
Hawaiian
That guy
Hawaiian's Avatar
I'm sure he's tuning the hurricane for more power.
Ultramarine mt FR-S
P&L stage 1 turbo
Hawaiian is offline
The Following 2 Users Say Thank You to Hawaiian For This Useful Post:
brichard0625 (10-31-2012), SkAsphalt (10-31-2012)
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 02:42 PM
