#3403 |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | Sportsguy83 (10-29-2012) |
#3404 |
FRS Rear Mount Turbo
Drives: 2013 FR-S Raven, Rear Turbo
Anybody having any luck fixing the fuel gauge problem? Tried battery cable disconnect with no luck. Is it a EcuTek issue and should I email them? Anybody know?
#3405 |
John is most likely working with ecutek.
Sent from my flux capacitor using Taptalk |
#3406 |
Drives: 2021 Supra / 2022 Tundra
What mode would you normally put the car in to defeat this? Just hold down the trac for 3 seconds or something else?
TomR
#3407 | |
Drives: 2013 Asphalt FR-S
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
#3408 | |
Grip>Slip
What's your recommendation, @Visconti ? Also, where's the easiest place to pick up RPM signal? |
#3409 |
I Love custom Turbo kits
Drives: Limited BRZ
You long press the Trac off button for some amount of seconds and two lights will come on in the dash showing all Aids are off.
#3410 |
Even doing this you'll still light up the ABS and traction lights once the dyno starts, at least mine did.
TomR
#3411 |
Drives: 2018 Subaru BRZ tS
Got my cable in john! I have the file I am not suppose to flash so I will be sending you a form soon. In the options though its only E85 and 100 octane do I just choose the 100 octane one?
If I installed deltadash so I need to reinstall without it checked? I also cannot find my license update file, looked everywhere I think it might be. Looked through the screenshots when it goes to License download i am getting (Remote folder not found) Last edited by Gregory Gawaran; 10-29-2012 at 01:47 PM. |
#3412 | |
Drives: 2013 BRZ Limited 6MT
http://www.ft86club.com/forums/showthread.php?t=10292 Edit: Here's the quote from Don@Accelerated on this, different thread than the one above that is closed now so can't quote it "I had similar issues on my Dynojet pickup as well. I changed to using the pickup w/ the ground and just clamping the harness bundle behind rear cylinder on passenger side. Never had any issues from there forward." |
| The Following User Says Thank You to DSTL For This Useful Post: | xjohnx (10-29-2012) |
#3413 | |
Tall guys fit, too.
Drives: BRZ Premium 6MT (SWP)
Emailed you a couple times, John. Would you prefer that I call you?
#3414 |
Drives: '13 DGM BRZ Limited
If the tune is already on the ECU, you are fine. You can flash the stock ROM or the 10895 tune without issues. The problem is if you try to flash any of the older tune files, you run the risk of locking up your ECU.
#3415 |
Tall guys fit, too.
Thank you for the clarification; flashing to stock (appointment for dealer service in a couple days)
#3416 |
Just don't flash back to a tuned file until you get the latest file.
| LED Front Signals with Resistor Flash Correctors | DarrenDriven | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 09-20-2012 02:05 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
| How to embed a flash gallery? | DarrenDriven | Site Announcements / Questions / Issues | 2 | 04-24-2012 07:43 PM |
| Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors | blur | BRZ First-Gen (2012+) — General Topics | 130 | 09-01-2011 01:42 PM |
