Old 10-25-2012, 05:12 PM   #29
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Thanks, guys. That eases my mind a bit. What's a "good" tire pressure gauge? Every one I've ever used has been horribly inconsistent. I'd like to just order one online and know that it'll be solid.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 10-25-2012, 05:19 PM   #30
gmookher
I use a liquid filled arb...can dial to qtr pound consistently
Old 10-26-2012, 12:14 AM   #31
TSY
TSY's Avatar
Drives: 2013 BRZ Limited SWP
You might want to check and see if the organization you're running with has loaner helmets.
If not and you can't find someplace nearby to try SNELL SA rated helmets you could find a motorcycle place and try some motorcycle helmets for size. It might give you an idea of what size you are and what brands may fit better which you can order online.
Otherwise I would suggest you order 2 or 3 helmets and plan on returning the ones that don't fit. You don't want to be thinking about how uncomfortable your helmet is while trying to learn how to drive a track!
I like my HJC helmet- it's lightweight and comfortable at a very reasonable price.
Good luck, have fun!
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX
TSY is offline   Reply With Quote
Old 10-26-2012, 12:27 AM   #32
CSG Mike
CSG Mike's Avatar
A cheapie from America's Tire or anywhere else will work.
Ask a few veterans to borrow their gauges, and compare it to yours to know if it reads high or low, and then compensate for any error in reading. The cheap stuff is surprisingly accurate.
Old 10-26-2012, 03:27 AM   #33
einzlr
Drives: several
I actually remember seeing a tire gauge comparison where the inexpensive basic ones did better than some of the fancy $$$$ ones. The only thing I would advise when selecting is get one with a hose so you're not trying to read it directly at the tire at an awkward angle or with it obscured due to glare.
Asphalt FR-S MT (future)
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale)
"Simplicate and add lightness." - Gordon Hooton
einzlr is offline   Reply With Quote
Old 10-26-2012, 09:19 AM   #34
diirk
diirk's Avatar
Drives: 4Runner
I like the ones that thread onto the stem, have a full dial guage and a button to bleed air so you can dial in your pressure easily. With that said, my last one disappeared and I'm currently using a cheapo stick one.
this might make a good thread....I'll do a search and start one if it isn't already there.
edit: tire guage thread created. http://www.ft86club.com/forums/showthread.php?t=20751
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 10-26-2012, 10:42 AM   #35
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
We've been using an analog longacre with about a 2.5" face for years with good luck.
GTM_Challenge is offline   Reply With Quote
Old 10-26-2012, 11:36 AM   #36
GTM_Challenge
Drives: On track
I disagree on the fluid. Novices tend to drag brakes instead of getting on them hard and then getting off them. I've seen far more novices boil the heck out of fluid than I've seen advanced drivers do it.
More or less agree on the rest, I'd still do pads too though. Doesn't hurt.
This is true...I guess you have to think about what will make a beginner enjoy the car on track as well - not knowing if the car is going to stop or not isn't going to be fun.
If you really want to do a budget setup that will actually make the car better, and seriously prolong the life of your consumables - do camber bolts, and tires, and brake pads and fluid.
The camber bolts will allow you to wear the tires less on the shoulders and stickier tires won't wear/turn to dust as fast as the OEM all season will in a track setting.
Upgraded pads (nothing crazy) should last longer on track than the stockers as well - not to mention stopping the car better and being more up to the task at hand.
So if you look at it form this angle, there are a few things that can be changed very easily to extract more out of the car and save the owner more in the long run.
Old 10-27-2012, 10:04 PM   #37
DR 86
DR 86's Avatar
If you're that noob that you're dragging your brakes to the point of boiling your fluid, instead of picking a braking point and getting on them hard till your turn-in, maybe you should get some formal instruction, or at least some pointers from more seasoned drivers before you track. Also, it completely fine to run this car stock as a noob, just limit yourself to a smaller number of laps per session and allow adequate time in between for components to cool. Oh, and remember to never engage your e-brake after an extended session.
DR 86 is offline   Reply With Quote
Old 10-29-2012, 01:33 PM   #38
Hanakuso
I was also told to leave the engine running for a few minutes after each session, but at the same time do not engage the brakes. Put something behind the wheels to keep it from rolling
Hanakuso is offline   Reply With Quote
Old 10-29-2012, 01:40 PM   #39
scionnut
Drives: 2013 FRS, 2011 XB
I've taken my FRS to two track days (willow springs & buttonwillow) & a drifting event
along with 9k miles in street driving.... my pads still have atleast 7mm front & 9mm rear
of the original 12mm the stock pads came with
watch me at buttonwillow here-
[ame="http://www.youtube.com/watch?v=lZgpyfSmz6c"]scion FRS full lap at buttonwillow - YouTube[/ame]
scionnut is offline   Reply With Quote
Old 10-29-2012, 02:15 PM   #40
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Longacre
http://www.longacreracing.com/catalo...id=223&catid=8
Yeah, it's not cheap but you asked for the "good" one.
Old 10-29-2012, 02:17 PM   #41
rice_classic
I would agree here but...
You can use the tire pressure gauge on all your vehicles, bike tires etc etc. Most folks have more than one thing that requires air pressure. Might as well get a gauge that feels good. Also the nicer ones (like what I posted above) make it easier to bleed air quickly while simultaneously checking air for quick adjustments.
Old 10-29-2012, 02:39 PM   #42
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
The other issue with cheap ones is they tend to go out of calibration sooner. Suddenly the 35psi on tires everyone else is using you need 40psi. I've had a couple cheap ones do this recently and so now all the cars have longacre gauges. It's really not that expensive when you figure my gauge from 2003 is still reading accurately.
TomR
ABQautoxer is offline   Reply With Quote
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
Element Tuning Track Tested and Track Proven FRS Video Element Tuning Tracking / Autocross / HPDE / Drifting 47 07-17-2012 04:12 PM
$110 Track day at Willow Springs- Big Track -May5 in SoCal Louie Southern California 3 05-04-2012 01:05 AM
$110 Track day at Willow Springs- Big Track -March24 in SoCal Louie Southern California 1 03-10-2012 01:31 AM
