| View the official forum sponsors list |
#86 |
Drives: Asphalt FR-S
I was thinking of purchasing a pair. What do you mean by losing functionality? As in not as bright as they should be?
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
#88 |
Drives: Scion FR-S Ultramarine
Yup. You can't even tell that they are on when you are inside the car. Unless it's completely pitch black outside then you can see a faint glimmer of light, but that's also only if your car is almost kissing a wall.
| The Following User Says Thank You to phanguy For This Useful Post: | Le86 (10-30-2012) |
#89 |
The DRL LED's are LED only and not meant to be used as a hi beam. The alternative to this is purchasing an HID kit for your hi beams in order to maintain an actual hi beam over just the DRL's.
#90 |
Drives: Raven FRS
I sent a PM for price. 6k kit, 1x Dome LED, 5x License plate/Trunk/Reverse LED's.
#91 |
Thanks for the insight!
#92 |
Speed Racer
Drives: 94' Supra TT 6MT, 11' Subaru WRX
Any update on the Switchback availability? I have sent you a few PM's, but haven't heard a response yet...
Also, as others have asked, where do you install the relay? Does it just splice into or clip onto the turn signal wires anywhere to create the extra load or is it like others are saying and it has to be installed in the steering column?
1994 Toyota Supra TT 6spd - BPU+++ 2011 Subaru WRX Premium Hatchback 2013 Scion FR-S 6MT Whiteout *SOLD |
#93 |
All PM's have been replied!
#94 | |
Drives: 13 Argento FR-S, 06 F-350, 97 240sx
Our relay replaces the stock flasher relay. You simply unplug the stock unit and plug our relay in, no cutting, splicing, soldering or anyting. It is located on the steering columpast where the plastics stop, no pannels need to be removed to access it.
| The Following User Says Thank You to Jon@TrueStreetIndustries For This Useful Post: | TRBO2NR (10-31-2012) |
#95 |
Kouki-Monster
are these produced by the same company as DDM Tuning kits?
Rich Anderson
EMPOWER AUTO |
#96 |
#97 |
I Love custom Turbo kits
Drives: Limited BRZ
If I buy the front/back Turn Lights LED's with the relay, this will fix the hyper blinking on all four lights?
(Probably a stupid question as I think there is one common relay for the four lights but just making sure. )
#98 |
You're correct. One common flasher relay for all turn signals.
| The Following User Says Thank You to Jon@TrueStreetIndustries For This Useful Post: | Sportsguy83 (11-01-2012) |
| Automation Lighting offers HID xenon headlight + foglight kits | jjdrivesajazz | Exterior Parts - Lighting | 138 | 01-13-2014 01:19 AM |
| Automation Lighting offers LED interior/exterior kits | jjdrivesajazz | Interior Parts (Incl. Lighting) | 393 | 10-11-2013 10:49 AM |
| HID PnP Kits | engee | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 02-05-2013 04:29 PM |
| HID_Powerhouse offers HID kits and LED lighting for your FR-S/BRZ | KI_ZN6 | CANADA | 2 | 07-27-2012 05:13 PM |
| NA engine kits? | Levi | Engine, Exhaust, Transmission | 36 | 11-17-2011 11:45 PM |
