Old 10-27-2012, 06:39 PM   #3347
DSTL
Drives: 2013 BRZ Limited 6MT
Originally Posted by Subynewbie View Post
I have that file as well. I've played around a bit with the display while in different maps, but 50.0 keeps coming up. Analog speedometer does nothing aside from displaying speed in all maps for me. Does it work for you? Does air/fuel ratio work for you? I'm thinking about unplugging my battery like I've read about to see if that changes anything. I love the tune though!
Analog speedo doesn't show anything but speed to this point. We've just had some chatter about putting it to another use since it's redundant with the digital readout.
DSTL is offline
The Following User Says Thank You to DSTL For This Useful Post:
Subynewbie (10-27-2012)
Old 10-27-2012, 08:39 PM   #3348
Carwhisperer
Drives: A lot of supercars.
You would need a forced induction tune and upgraded injectors
John
Alright. I'll keep in touch, and we can touch basis in January when I'm ready to go all in.
Carwhisperer is offline
Old 10-27-2012, 09:33 PM   #3349
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Originally Posted by Apoc View Post
Anyone in Canada able to get fuel level % in map 4 working correctly? As in showing percentages above 50.0?. I reflashed to the latest file RR-10895-ZA1J700C-STG1 v1.07 FED-M-XXXXXX any everything works great except fuel level it stops at 50.0%
Same tune, same thing with the fuel thing, Mae a video if you can, hea
Asked me to but haven't been drivg mine
Bu-Tang is offline
Old 10-27-2012, 11:48 PM   #3350
Visconti
Drives: 05 STi
I'll have to talk to ecutek about the cluster but as for the tune files not flashing in... Your giving me the wrong dongle information!
I'm copying and pasting directly from the form you filled out to the tune file.
If your unsure about your dongle info, open pro Ecu, press f1 and copy the dongle info by highlighting it with your mouse. Then paste it in the form.
John
Visconti is offline
Old 10-28-2012, 12:13 AM   #3351
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Hey John how are the e85 tunes coming along for the autos?
Area86 is offline
Old 10-28-2012, 12:16 AM   #3352
Visconti
Drives: 05 STi
I have a old version but since its getting cold out I really need to get the cold start cranking correct before I finish pushing them out.
I already have a bunch of people running it so once I get logs / feedback the faster I can get everyone their updated tune.
Btw flex fuel kits are in the process of getting built
Visconti is offline
The Following 4 Users Say Thank You to Visconti For This Useful Post:
Area86 (10-28-2012), dabocx (10-28-2012), LeavingNormal (10-28-2012), nix (10-28-2012)
Old 10-28-2012, 12:22 AM   #3353
dabocx
dabocx's Avatar
Drives: Scion FRS
Dongle ID was copied correctly, ill double check everything else.
Edit- Looked at the tune you sent that didnt work. The dongle ID on the one you sent has O where its the post to be a 0
dabocx is offline
Old 10-28-2012, 12:27 AM   #3354
LeavingNormal
FRS2DTH
LeavingNormal's Avatar
Drives: Hot Lava 2013 Scion FRS
just what i wanted to hear john! keep us posted!
LeavingNormal is offline
Old 10-28-2012, 12:38 AM   #3355
Area86
Area86's Avatar
Ok cool. If you have the time when your in Vegas you can always use my car to get some logs. Just putting it out there but I know your probably going to be busy.
Area86 is offline
Old 10-28-2012, 12:51 AM   #3356
Visconti
Drives: 05 STi
I expect to have a lot of free time in Vegas so I'm sure we'll be in touch
Visconti is offline
Old 10-28-2012, 01:01 AM   #3357
Area86
Area86's Avatar
SWEET!!!!
Area86 is offline
Old 10-28-2012, 01:09 AM   #3358
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
What fun is Vegas without a little free time...
Wish I were already there. F work, seriously.
vubaru is offline
Old 10-28-2012, 06:46 AM   #3359
Yruyur
Yruyur's Avatar
John
Looks like mine is correct based on the screenshot that I sent you. I'll double check tomorrow.
Yruyur is offline
Old 10-28-2012, 07:20 AM   #3360
Calum
That Guy
Drives: 2013 asphalt FRS MT
Will the sensor be plug and play, or will guys have to add an input to the ECU?
How is the ECU controlled electronic boost control working? (Not the Crawford car itself, I understand you can't talk about that, just the feature)
Also, can you give us a run down on how to use launch control? Every time I try to use it I just bounce the engine off the rev limiter.
Calum is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
