Old 10-26-2012, 02:38 AM   #1947
Le86
Drives: Asphalt FR-S
Originally Posted by cnk View Post
Unless the tuner gets a hold of the new ROM used to fix the issue and builds maps off that ROM. Then anyone that flashed that tuned ROM file would in essence have the fix.
I think you may be on to something here.
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline   Reply With Quote
Old 10-26-2012, 02:38 AM   #1948
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Originally Posted by TeamSweet86 View Post
Fudge...
I'm #2 on this list. Lights came on the night I bought the car. Cam sprocket replaced, ecu replaced. Took forever. Fuel pump also replaced for the chirp. Finally had the car for a solid 6 days without anything going wrong until driving to work this morning,... lights came back. I hate my car.
Anybody else's CEL/SL come back from the dead recently?
How many miles later???
Sent from my PC36100 using Tapatalk 2
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 10-26-2012, 02:41 AM   #1949
Le86
Originally Posted by ftc~brz View Post
Well, it's not hunting real hard like the CEL dip, that's not so bad I know with everything I've read that some little dips are common but I know you've read all or more the same stuff.
I also smell coolant burn off now that I can smell things again. But I spilled a little (3 drops)when I added some in CT that first weekend after flash. I was trying to do all I physically could to keep the cel gremlins at bay being so far from my dealer.
I can't tell if I'm smelling things now just because I'm afraid or over reacting or just plain paranoid.
But I still smile when I rev her stinkin ass out!
I think it might just be your imagination. 3 drops of coolant really shouldn't create a distinct enough smell to where you can detect it. But good job keeping an eye out for small things.
Old 10-26-2012, 03:53 AM   #1950
TeamSweet86
TeamSweet86's Avatar
Drives: Subaru BRZ
Sprocket and ecu were replaced at about 350 miles. Came back almost 2k miles later
TeamSweet86 is offline   Reply With Quote
Old 10-26-2012, 08:53 AM   #1951
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Yup; I think I don't have a problem yet but with everything happening to these things I have been paying very careful attention to the car. This is the first time the idle has ever wavered, even the slightest tinny bit.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
The Following User Says Thank You to @Art_Mighty For This Useful Post:
ftc~brz (10-26-2012)
Old 10-26-2012, 09:18 AM   #1952
rthaanum
rthaanum's Avatar
Drives: 2013 Ultramarine Scion FR-S A/T
Picked up my car from the dealership last night. They had a field tech come reflash the ecu. So far she seems to be running like a champ! Much better than its ever run before. No more idle dip and seems like it has more power.. maybe I was just used to limp mode...
rthaanum is offline   Reply With Quote
The Following User Says Thank You to rthaanum For This Useful Post:
eurospeed (10-26-2012)
Old 10-26-2012, 11:31 AM   #1953
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
Originally Posted by @Art_Mighty View Post
So I've experienced 2000 trouble free miles. There's a weird smell that I think is anti-freeze but I can't seem to find any evidence of a leak. I mounted my snow tires tonight and while I was heat cycling them I noticed this while I waiting for my tires to cool down...
...when the engine was warmed up the engine idle was cycling between 800 down to 400 RPM and back. Is this the beginning of another CEL?
Mine just started doing this also but it never gets below 500pm (at least as of now). I'm wondering if that is the reflash catching the drop and correcting it. At least that's what I hope. I've also noticed the tach quickly shoot up to 1000rpm occasionally even though it doesn't sound like the engine is revving with it.
rapidcars is offline   Reply With Quote
The Following User Says Thank You to rapidcars For This Useful Post:
Old 10-26-2012, 12:06 PM   #1954
ftc~brz
Done
Drives: WRB BRZ
I hope it is just me. The hell I've been through and the decisions ahead of me can make the next 100k in this car my most favorite or worst buy ever. There is nothing worse than not knowing if your daily driver is dependable or not. But I'm going to take it day by day. I'm so close to lemon law in my state so who knows how this will play out.
ftc~brz is offline   Reply With Quote
Old 10-26-2012, 12:39 PM   #1955
killercl0wnfish
Drives: fr-s
Update.... picked car up yesterday at 10am ran great no cherp at all no power loss ......drove to work at 430 pulled in parking lot then herd cherping again 0_0 i dont mind the cherp but it was nice when it wasent there .....
killercl0wnfish is offline   Reply With Quote
Old 10-26-2012, 12:45 PM   #1956
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
That's just the thing. The car's ECU wasn't flashed when the first cam gear went out. It's still on original code and hardware (I still have the 810 ECU)
Old 10-26-2012, 12:54 PM   #1957
Rob_g
Drives: 2010 4Runner Trail
So far for me it's worst buy ever. Engine still isn't right and now needs another new tail light since the replacement is full of condensation again.
Rob
Rob_g is offline   Reply With Quote
The Following 2 Users Say Thank You to Rob_g For This Useful Post:
eurospeed (10-26-2012), ftc~brz (10-26-2012)
Old 10-26-2012, 12:54 PM   #1958
whataboutbob
AutoX-10/10ths every run
I just had my first CEL/Slip ligth exp this AM.
I noticed the lights came on after a brief stop at Mailboxesetc on the way to work.
The car was in limp mode, so I pulled over and turned it off for 5 min.
Started it back up and the lights were gone. Drove the next mile to work. We'll see how the 40mi drive home goes tonight. I really hope that it makes it through next week so I can participate in the Scion to SEMA drive that I've already signed up for...
whataboutbob,FR-S,118XX,XXX243, haven't taken in yet,CA,USA
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Old 10-26-2012, 12:56 PM   #1959
Rob_g
You should phone Scion and ask if they have tow trucks on standby for this event.
Rob
The Following 4 Users Say Thank You to Rob_g For This Useful Post:
dabocx (10-26-2012), eurospeed (10-26-2012), rapidcars (10-26-2012), whataboutbob (10-26-2012)
Old 10-26-2012, 01:17 PM   #1960
mhigham
Rob
Ouch, I just might ask them when they call today.
mhigham is offline   Reply With Quote
The Following User Says Thank You to mhigham For This Useful Post:
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
