Old 10-23-2012, 11:02 PM   #15
dabocx
dabocx's Avatar
Drives: Scion FRS
If your only getting a catback id agree but for those that plan on adding the catless front pipe/over pipe and header it might be too much for some.
dabocx is offline   Reply With Quote
The Following User Says Thank You to dabocx For This Useful Post:
Turbowned (10-26-2012)
Old 10-23-2012, 11:02 PM   #16
gmookher
dyno schmyno
I'm telling ya, dont believe me, thats just fine.
Old 10-23-2012, 11:12 PM   #17
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by gmookher View Post
dyno schmyno
I believe in numbers.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
xjohnx (10-23-2012)
Old 10-23-2012, 11:15 PM   #18
gmookher
dont blame you at all! I'd think I was smoking the good stuff too..the unresonated stays, the resonated gets sent back..nuf said
Old 10-23-2012, 11:19 PM   #19
xjohnx
Grip>Slip
xjohnx's Avatar
Perrin accepts returns on used items?
Old 10-23-2012, 11:25 PM   #20
Hawaiian
That guy
Hawaiian's Avatar
He's probably getting freebies (or reduced prices) for shilling them.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 10-23-2012, 11:33 PM   #21
Nardi330
Nardi330's Avatar
Drives: 86
i think he has been beta testing a few stuff like tunes, oil cooler etc so he obviously has contacts.
Nardi330 is offline   Reply With Quote
Old 10-23-2012, 11:42 PM   #22
Jedi1
STX build in progress!
Jedi1's Avatar
Drives: Whiteout FRS. Just Gorgeous!
We installed the non resonated cat back last week. It sounds WONDERFUL! It is anything but loud for the sake of loud. Zero drone. Interior noise levels might be marginally higher than stock, but it just sounds like I thought the car should sound from the factory. Nice growl at start up on quick idle. Quites right down as the idle drops to normal and then it just sounds great above 3000 rpm.
Jedi1 is offline   Reply With Quote
The Following 5 Users Say Thank You to Jedi1 For This Useful Post:
Chad86 (04-09-2014), gmookher (10-31-2012), soros151 (10-26-2012), tennisfreak (09-05-2013), Tylub (10-24-2012)
Old 10-24-2012, 12:03 AM   #23
Opposed
Drives: 2013 Asphalt FR-S
I want to believe you, but what happens when your installing a catless front pipe which I intend to do? Im sure with the cats in place, the non res. is very tolerable. But with a catless setup, could it cross over to annoying?
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 10-24-2012, 12:11 AM   #24
Jedi1
Jedi1's Avatar
It could, but I haven't heard that config so I don't really know. I had our Perrin Cat Back Non Res sitting next to a Nameless high flow cat BRZ over the weekend and the Nameless system was louder, but by no means was it obnoxious. In fact, I liked it!
Old 10-24-2012, 12:36 AM   #25
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
I have Dyno proof...the un-resonated makes the same power as resonated...all my sound recordings were done on the same dyno under close to the same conditions. Unfortunately I do not have the print out from the un-resonated dyno run as I didn't think about getting them printed out at the time and I was only there for recording purposes that day, but the final number was the same as the resonated.
Basically...get whichever you prefer sound wise...I personally switched back to the resonated as my GF didn't like the louder noise and the more I drove it the more I felt like "that guy with the obnoxious exhaust." Plus later on when I get the front pipe and over pipe I don't want it to be even louder.
Honestly...get whatever you like, but don't go claiming it makes more power...because it doesn't.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
The Following 14 Users Say Thank You to Sony For This Useful Post:
Bcarlos (04-05-2013), Calum (10-24-2012), djdnz (10-26-2012), Drebin252 (04-09-2014), flippy (01-08-2016), Hanakuso (10-25-2012), Hawaiian (10-24-2012), JTM (10-25-2012), Marchy (09-05-2013), Pseud0logik (04-01-2014), Sportsguy83 (10-24-2012), theredtape (07-29-2013), Trobinson (03-25-2013), xjohnx (10-26-2012)
Old 10-24-2012, 12:40 AM   #26
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
I have the resonated, I would love to swap that pipe with someone with an unresonated. So far my system is very moderate (uncatted midpipe and catback), so I think I'd like to drop the weight and go slightly louder. If interested, PM me
TomR
ABQautoxer is offline   Reply With Quote
Old 10-24-2012, 01:04 AM   #27
RYU
RYU's Avatar
Drives: really slow...
Actually, if any of you plan to run Laguna Seca your stock exhaust will barely pass the decibel limit.
I plan to run MLSR so it's the stock exhaust for me for a while
RYU is offline   Reply With Quote
Old 10-24-2012, 01:08 AM   #28
ABQautoxer
ABQautoxer's Avatar
Weird. With muffler delete you should blow ~85dB at 50ft as people have done this a bit at SCCA events.
TomR
Another AVO/Perrin Install msile Engine, Exhaust, Transmission 18 01-10-2013 04:40 AM
Perrin drop in mach330 Engine, Exhaust, Transmission 4 10-08-2012 07:01 PM
Resonated test pipe? track_warrior Engine, Exhaust, Transmission 3 07-30-2012 12:22 PM
