Old 10-23-2012, 05:33 PM   #43
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Originally Posted by Dipstik-sportech View Post
Will water/meth be needed if you're running 91 pump gas with the intercooler?
i doubt it laminova air-water intercoolers are pretty efficient as long as they use the right amount or even a bit more than they need and have a heat exchanger of sufficient size to keep the water from getting too hot and causing heat soak. i'm sure that they have not overlooked this though.
FreshFRS is offline
Old 10-23-2012, 05:47 PM   #44
Dipstik-sportech
Dipstik-sportech's Avatar
I just know on our crappy Canadian 91 my m62 supercharged del sol only made 276whp with water/meth. And it only had 10:1 compression, lets hope the intercooler and the DI helps. I'd love to see this make 300-350wheel.
Dipstik-sportech is offline
Old 10-23-2012, 06:20 PM   #45
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
I try to use only chervon 94 (couple stations close) and im thinking 300+ is doable for sure. DI and higher compression seem to be working well many people are getting 300+ from boost.
I would like to see the intake first though. if it's what i expect i may just make a custom top piece with a couple more Laminova cores, built in BOV and run D3's turbo with a straightish pipe from the compressor to the MAF to TB maybe 20 inches of piping max. hello throttle response
FreshFRS is offline
Old 10-23-2012, 06:27 PM   #46
SpeedmasterBRZ
Drives: Pearl BRZ Limited
Waiting for pics...
SpeedmasterBRZ is offline
Old 10-23-2012, 06:44 PM   #47
subatoy
subatoy's Avatar
Drives: subatoy
I don't want to wait for SEMA this is torture! we need some pics!
subatoy is offline
Old 10-23-2012, 06:59 PM   #48
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
FreshFRS is offline
Old 10-23-2012, 07:05 PM   #49
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Agreed. SEMA needs to get here now
Freeman is offline
Old 10-23-2012, 07:13 PM   #50
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
Ok, LETS SPECULATE we get 300 HP to the wheels... Do you think that would require any drive train mods to support it? Gearbox/Clutch.. ect ect?
RedRocket is offline
Old 10-23-2012, 07:22 PM   #51
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Originally Posted by RedRocket View Post
Clutch
Absolutely going to need a clutch sooner than later with ANY of these supercharger/turbo kits.
No Limit Motorsport is offline
Old 10-23-2012, 07:24 PM   #52
Opposed
Drives: 2013 Asphalt FR-S
Just a clutch most likely. Fullblown said the stock clutch starts to slip around 280whp.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
Old 10-23-2012, 07:28 PM   #53
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
This.
FreshFRS is offline
Old 10-23-2012, 07:54 PM   #54
sf86
sf86's Avatar
Drives: Red Scion FRS AT
would this one work on AT ?
sf86 is offline
Old 10-23-2012, 08:02 PM   #55
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Aisin says our AT is rated for 400hp? (TB-61SN)
http://www.aisin-aw.co.jp/en/product...eup/index.html
Spartan65 is offline
The Following 2 Users Say Thank You to Spartan65 For This Useful Post:
sf86 (10-23-2012), usptwins (10-23-2012)
Old 10-23-2012, 08:07 PM   #56
Freeman
Freeman's Avatar
Holy crap.
Freeman is offline
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 03:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 10:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 06:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 01:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 07:10 AM
