#29 |
Drives: bicycle
The factory throttle body @ 3" is huge for the displacement of this engine. It's more than sufficient. The issue that needs to get around is how these things are choked up by 3 catalytic converters.
#30 |
Drives: FRS, M3
Hey Guys, figured I would help answer some questions.
There is no core exchange required - it's a complete brand new unit. It works with the factory ECU and it requires no additional tuning or modifications. I have 3 coming in next week. PM me if you want to get one ordered. -Frank |
#31 |
Pull my finger...
Drives: Silver Scion Slushbox
#32 |
Drives: 2013 Firestorm FRS, 97 BMW M3
I'm not an expert at the engineering dynamics of throttle bodies but I am a consumer who does a lot of research for the products I buy. I did a fair amount of research when looking to upgrade the throttle body on my 97 m3 (3.2l inline 6) and the percentage of the increase in area was one important aspect. I realize that comparing engines is rather pointless but i wanted to point out the following:
FRS stock - 76mm cusco - 78mm Increase of 2.6% M3 stock - 63.83mm Dinan - 66mm +6.46% Riot Racing - 68mm +11.9% There are other aspects to BBTB such as smoothness of the chamber and the single vs. dual arm. However an increase of 2.6% makes the part seem more of a bragging right rather than a performance part. Maybe some of the tuners who having been working with the FRS can tell us if there is any need for a larger throttle body or at what power/modifications point more flow is needed. |
#33 |
If the stock throttle body's O.D. Is 76mm I don't think cusco will make it bigger from the outside. I bet will be the inside instead. Anyone know what's the stock I.D. Of the TB ?
If no one knows, I will pull my TB this weekend and check ! |
#34 | |
Drives: Vibe
76mm is the stock Internal Diameter. |
#35 |
Drives: A nice one
Just curious what kind of gains can be expected from this?
#36 |
Is it actually 76mm at the throttle plate, or is that the I.D. at the tip of the inlet?? Most 2L engines run WAY smaller TB's than this. Typically 70mm is a huge TB on a 2L.
#37 |
Potato Farmer
Drives: #SLOBRZ
But Cusco.. it has to be better?
What about if i put a HKS sticker on it? would you pay $2250? OMGOMGOMGOMG JDM #mustwastemoneycauseitsJDM I think my post is about as pointless as this product.. Sorry.
Something something butter..
www.vic86brzclub.com |
#38 |
Drives: 13 White MT FR-S
Yes.
#39 |
Potato Farmer
Drives: #SLOBRZ
#40 |
I sprung for a Dinan OTB for my m3, but it was part of a tuned kit, cai package and software to match it all. The OTB from cusco by itself for that money...pass
#41 |
igotthatpurp
i heard it was made using Chuck Norris's tears
must be good then
#42 | |
SorosMotorsports
Drives: Whiteout Pearl
Measured the TB here. Mostly approximately, but not bad at all. |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 07:44 PM |
| Throttle Controllers | harajukukei | Engine, Exhaust, Transmission | 31 | 07-28-2012 12:40 AM |
| Cusco Rear Diff Covers!!! Cusco LSD Units! | vividracing | Transmission and Driveline | 0 | 06-18-2012 03:24 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
| Throttle Blip, and other features? | ashtray | BRZ First-Gen (2012+) — General Topics | 39 | 03-07-2012 10:52 AM |
