Old 10-16-2012, 06:10 AM   #43
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by einzlr View Post
Indeed! Getting somewhat off topic here, if you ever want to get completely blown away by feats that were possible 50, 60, 70 and more years ago, visit the Smithsonian Air and Space museum in D.C. They have rows and rows of engines (some cut in half for display so you can see inside) that span several decades of military aircraft. You can see before your eyes how piston engines were taken to the very limit of what's possible in terms of power output (and almost beyond) and how they then quickly gave way to a new approach in the form of turbine engines. The last of the reciprocating engines were as bizarre as they were problem-ridden, and several prototypes were scrapped after huge and costly R&D effort when the advent of turbine engines revealed that the old model had become a lost cause.
Been there its quite cool
what about any upcoming cars that are pushing over 100hp per liter?
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 10-16-2012, 01:25 PM   #44
einzlr
Drives: several
Haha maybe I should have guessed that. Oh well, maybe someone else will be inspired to visit
Not too many AFAIK, they're all going to turbochargers now. LOL the new Viper either misses the mark by far, or comes fairly close depending on how you look at it. Word is it's an 8.4l V10 making 640hp/600lb-ft, but:
Fun fact: you can call it an even 800 hp created in the cylinders, because powertrain chief Richard Winkles claims that the first 160 hp are spent overcoming engine friction.
source:http://www.motortrend.com/roadtests/...all.html?ti=v2
Last edited by einzlr; 10-16-2012 at 07:29 PM. Reason: reworded to avoid ambiguity
einzlr is offline   Reply With Quote
The Following User Says Thank You to einzlr For This Useful Post:
Rayme (10-16-2012)
Old 10-16-2012, 01:42 PM   #45
low trq
Drives: 2013 Honda Fit sport
My honda fit has a higher hp/L ratio than the new viper. That thing isn't even close.
low trq is offline   Reply With Quote
Old 10-16-2012, 03:19 PM   #46
TAP Auto Parts
Drives: FRS
My engine makes 12000hp, but 11200 of it is spent overcoming friction.
TAP Auto Parts is offline   Reply With Quote
Old 10-16-2012, 03:23 PM   #47
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Not too many AFAIK, they're all going to turbochargers now. LOL the new Viper either way misses the mark or comes fairly close depending on how you look at it. Word is it's an 8.4l V10 making 640hp/600lb-ft, but:
That's like saying I can probably lift 500 lbs but sadly I got to overcome earth's gravity (the reality of physics). Marketing BS
Rayme is offline   Reply With Quote
Old 10-16-2012, 03:52 PM   #48
einzlr
Drives: several
And if those numbers are accurate, that's pretty hefty drivetrain loss at 20%. Typical is more like 15%.
Old 10-16-2012, 05:26 PM   #49
Dark
Elite Padawan
Dark's Avatar
Originally Posted by GenkiElite View Post
Does it have to be a car? Just about every modern sport bike qualifies. For example, My stock 06 GSXR 750 puts 125 to the wheel.
Haha Good one. Any 600cc+ sportbike will have more than 100hp/l. My 08 CBR600RR also make 100hp.
Dark
Dark is offline   Reply With Quote
The Following User Says Thank You to Dark For This Useful Post:
einzlr (10-16-2012)
Old 10-16-2012, 07:27 PM   #50
einzlr
Drives: several
As OP I'll make another decree that it doesn't have to be a car as long as your post contains some interesting info about engines that contributes in some way to the general topic. I didn't know that about sport bikes, so that qualifies as interesting
Old 10-16-2012, 07:45 PM   #51
serialk11r
Drives: '06 AM V8V Coupe
hp/L is pretty much a function of how high it revs, at least for road cars. Well, the bigger the engine the harder it is because for a car to pass EPA certification there is a maximum quantity of toxic emissions allowed, rather than maximum ppm. For bikes they can make more torque because they don't need to worry about emissions and noise (I think? The sport bikes going past my apartment are f***ing loud even compared to the diesel buses and trucks and modified sports cars). That's why that Hartley V8 hits 133Nm/L whereas Ferrari can only hit 120Nm/L. The highest "factory" specific torque I've seen is the TRD 3S-GE with 13.5 pistons, short trumpet ITB, cams, etc. etc. at 125Nm/L.
A CBR600RR on the other hand makes about 100Nm/L, which doesn't sound that great until you realize it's only 600cc, so the engine has to deal with proportionally much more friction and heat rejection than any larger car engine.
Bike engines have miniscule strokes (600cc bikes are typically 42mm or something like that) and hit 12000-15000rpm. 600cc bikes are IMO the coolest thing a normal consumer can buy, 15000rpm, power peak at 13500rpm, 180hp/L +. Not far from an F1 engine at all. Previous season F1 engines had minimum stroke of 39.5mm says Wikipedia, and 2014 they will be rev limited to 15000rpm
The Following 3 Users Say Thank You to serialk11r For This Useful Post:
einzlr (10-16-2012), Guff (10-16-2012), Turdinator (10-25-2012)
Old 10-16-2012, 07:51 PM   #52
STJ
STJ's Avatar
Drives: Skyline R33 GTR
How about 200Hp from a 1.6 NA! The Nissan Pulsar VZ-R N1.
STJ is offline   Reply With Quote
The Following User Says Thank You to STJ For This Useful Post:
einzlr (10-16-2012)
Old 10-16-2012, 08:06 PM   #53
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Moto GP machines make between 240-260 hp out of a liter... I know I know not a production car.. But still an awesome hp/liter output, like F1..
The first car that pops in my head besides an exotic is always the S2000... I always remember the ads about it.. What 120hp per liter back when it came out
Gixxersixxerman is offline   Reply With Quote
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
einzlr (10-16-2012)
Old 10-16-2012, 08:23 PM   #54
acro
Drives: GT-86
that was an awesome engine
acro is offline   Reply With Quote
Old 10-16-2012, 09:01 PM   #55
einzlr
Drives: several
Like this one? I had no TV access during that time so didn't see them, but this one is clever for sure
[ame="http://www.youtube.com/watch?v=yiFoeosCEQI"]http://www.youtube.com/watch?v=yiFoeosCEQI[/ame]
Old 10-16-2012, 09:41 PM   #56
RaceR
Drives: 2010 Cooper S, 74 Beetle
yeah I still remember that.. 120HP per liter. Could read about the amazing figure in every review.. It is still very impressive today for a road car!
The last/current Porsche GT3 RS 4.0 beat it tough.. 500HK. 125HP/L
I do not know of any production road going vehicle with more HP/L...
RaceR is offline   Reply With Quote
What other engines fit our transmissions 1strwdcar Engine, Exhaust, Transmission 36 08-02-2012 05:45 PM
So you think you know engines? Ryephile Other Vehicles & General Automotive Discussions 43 02-04-2012 04:49 AM
Boxer Engines and Superchargers brillo Engine, Exhaust, Transmission 2 01-06-2012 06:49 AM
different engines for different domestic markets?! Abflug Scion FR-S / Toyota 86 GT86 General Forum 20 10-02-2011 09:04 PM
Subaru engines' weights Allch Chcar Other Vehicles & General Automotive Discussions 19 04-30-2011 01:10 AM
