Old 10-14-2012, 04:47 AM   #1
WRB-DZA-BRZ
Cookie Monster
WRB-DZA-BRZ's Avatar
Drives: 2013 Subaru BRZ Premium 6-MT WRB
Question Tire chains... yes/no?
I noticed the manual says not to use tire chains, due to clearance issues.
But that is with the stock size wheels/tires.
Anybody have plans to run tire chains on non-stock wheels/tires?
I am trying to buy a set of 2005 WRX wheels (16x6.5, 55mm offset), and will mount either 205/55-16 tires (1% larger diameter than stock), or 195/55-16 tires (0.7% smaller diameter than stock).
Depending on what deals I find, I will most likely buy Michelin X-Ice tires, which are pretty good, but I like to have an option of chains if I can.
For chains, I'd probably run some Thulle CG-9 self-adjusting chains, if they fit.
Stock 205/45-17 tire OD is 625.1mm. 9mm chains would increase the outside diameter of the 205/55-16 tire from 631.7mm to 649.7mm. The 9mm chains would increase the OD of the 195/55-16 tire from 620.8 to 638.8mm. Has anybody done any tire clearance measurements yet?
WRB-DZA-BRZ is offline   Reply With Quote
Old 10-14-2012, 03:56 PM   #2
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Doesn't it say to use a particular type of chain?: I believe there is reference to SAE class S devices such as spring/cable chains
example
http://www.canadianchains.ca/Cobra-C...nger-_p_8.html
I would suggest that these are really only for lingering packed snow or snowy mountain areas?
smbrm is offline   Reply With Quote
The Following User Says Thank You to smbrm For This Useful Post:
WRB-DZA-BRZ (10-15-2012)
Old 10-23-2012, 10:06 PM   #3
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
I am also curious, I may be picking up an FR-S and will have to drive it over the pass.
Cade01 is offline   Reply With Quote
Old 10-23-2012, 11:00 PM   #4
gmookher
buy jeep
The Following User Says Thank You to gmookher For This Useful Post:
usptwins (10-24-2012)
Old 12-30-2012, 05:36 AM   #5
Fuzzysmith
Drives: 2013 Firestorm FR-S MT
www.autosock.us
Looks cool. Subie dealership pointed me that way.
Fuzzysmith is offline   Reply With Quote
Old 12-30-2012, 01:12 PM   #6
CA2
Dusty Raven
Drives: FR-S MT
I have the Thule 9mm chains and they fit fine on the stock wheels/tires.
CA2 is offline   Reply With Quote
Old 12-30-2012, 04:14 PM   #7
ozne99
Drives: GBS BRZ Limited
My dealer specifically told me not to put chains on the car.
ozne99 is offline   Reply With Quote
Winter tire Dub666 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 02:32 AM
Group Buy: 86 Key Chains!!! 86_ZN6 Miscellaneous 98 07-31-2012 10:00 AM
What tire PSI are you using SEC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-30-2012 10:09 AM
GB: 86 Key Chains for AU/NZ 86_ZN6 AUSTRALIA 46 07-19-2012 01:42 PM
Tire Rack still needs a BRZ! Lonewolf Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-12-2012 03:35 PM
