Old 09-25-2012, 07:31 AM   #29
BRZranger
@RavSpec, w/ the gtspec rear camber arms, does the 30mm bend raise the ride height and reduce bumptravel?
BRZranger is offline   Reply With Quote
Old 09-25-2012, 03:05 PM   #30
RavSpec
Drives: Rx7
yes raise by about 1" to compensate for the bend due to the drop of the suspension.
Mark.
RavSpec is offline   Reply With Quote
The Following User Says Thank You to RavSpec For This Useful Post:
BRZranger (09-25-2012)
Old 09-25-2012, 03:31 PM   #31
jamal
jamal's Avatar
Drives: Legacy GT
Could you elaborate on that?
So if I were to install them on a completely stock car it would sit higher? Looks to me like the shock mount is lower down in the arm, which would lower the car with no other changes.
jamal is offline   Reply With Quote
Old 10-10-2012, 10:41 AM   #32
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
bump
Old 10-10-2012, 10:51 AM   #33
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Love that front strut/power brace setup
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-10-2012, 02:48 PM   #34
jumbaco
jumbaco's Avatar
Drives: FD
Nice, I'd like to see a bronze wheel on white though.
jumbaco is offline   Reply With Quote
Old 10-10-2012, 02:51 PM   #35
RavSpec
Drives: Rx7
This Sat at Firstclassfitments.com you will see them
19x9.5/19x10.5 on this BRZ.
Old 10-16-2012, 01:02 PM   #36
RYU
RYU's Avatar
Drives: really slow...
What's the availability looking like on these braces?
RYU is offline   Reply With Quote
Old 07-18-2013, 04:49 AM   #37
RavSpec
Drives: Rx7
Quick bump ....
Old 08-01-2013, 10:16 PM   #38
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Thanks for working with GTSPEC and their product line. All pieces appear well designed and easy to install. I've looked across many forums without finding any quantitative analysis of before and after installation of any chassis products. Can you point me toward any analysis beyond seat of the pants?
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 08-04-2013, 04:48 PM   #39
RavSpec
Drives: Rx7
Originally Posted by BRZranger View Post
Those GTSpec rear camber arms look like they have a different design than: part# GTS-SUS-1376 for 08 Sti
Is this a part in development for BRZ?
Yes, new version for brz specifically.
Old 08-05-2013, 12:33 PM   #40
stancypants
stancypants's Avatar
Drives: FR-s
you are not completely maxxed on the bc's are you ?
stancypants is offline   Reply With Quote
Old 08-05-2013, 03:32 PM   #41
RavSpec
Drives: Rx7
no, not at all, installed with stock spec out of the box.
stancypants (08-05-2013)
Old 08-13-2013, 04:26 AM   #42
eckoflyte
Drives: Toyota 86 GTS
@RavSpec this question had been posed in this thread before, does the bend on the rear lower control arm lower the shock mounting point, in effect, lowering the car and keeping bump travel?
I'm confused because this was GTSpecs official response -
"Thank you for your inquiry. Our BRZ/FRS rear camber were not developed for lowering the stock shock mounting point. The arm was mainly design for camber adjustment. "
Also do they use sphericals on the end?
eckoflyte is offline   Reply With Quote
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 11-20-2015 12:12 AM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x8.5 +47 / 18x9.5 +38 FML Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 91 06-13-2015 08:48 PM
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 05-26-2015 11:39 AM
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +18 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 103 11-21-2013 03:28 AM
New Spec - WORK Emotion Kiwami 18x8.5 +38 / 18x9.5 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 58 01-24-2013 12:51 PM
