Old 10-09-2012, 10:37 PM   #43
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
They are both very similar and good exhausts. I have heard the Perrin and I have the nameless on my car and they both sound more or less the same. I chose the Nameless because it was a lot cheaper since it is just an axleback and I didn't see any benefit to replacing the midpipe. I'll save my money for headers/front pipe combination where the real power is. The build quality on the axleback is really incredible, it is like a work of art. The tips are the perfect size and offset and really made the back end of the car look a lot better.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 10-09-2012, 10:51 PM   #44
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Originally Posted by ayau View Post
awesome! this means the nameless axleback + factory midpipe combo is 9lbs lighter than perrin's catback.
perrin catback = 39.5lbs
nameless axle back (18lbs) + factory midpipe (12.4lbs) = 30.4lbs
100% factory: factory midpipe (12.4lbs) + factory axle back (25lbs) = 37.4lbs
Really cant wait for you guys to get with the times and use the Metric system like the rest of us modern country's :P
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
The Following User Says Thank You to fuddbutter For This Useful Post:
sierra (11-22-2012)
Old 10-10-2012, 01:28 AM   #45
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Thanks for reviving this thread. I'm also trying to decide between Perrin or Nameless, but I may put off the decision for a little while. Have the power gains been proven by independent tests yet?
I was leaning toward the Perrin, but now I'm thinking: Does the Nameless option (of axleback+frontpipe) really produce about the same power as the Perrin Catback (if not more)? If so, wouldn't the Nameless be a clear winner given that it weighs a lot less than the Perrin?
Phaedrus29 is offline   Reply With Quote
Old 10-10-2012, 02:22 AM   #46
Nardi330
Nardi330's Avatar
Drives: 86
the weight quoted for Perrin cat back was for the resonated version. my understanding is the non resonated cat back is lighter. can't someone confirm?
thanks
Nardi330 is offline   Reply With Quote
Old 10-10-2012, 02:48 AM   #47
Phaedrus29
Phaedrus29's Avatar
thanks
Yes, true...posted by dwx earlier in this thread:
"The catback without a resonator weighs 26lbs total, so about 12.4lbs less than stock. But then you have to deal with a louder and probably raspier exhaust."
I do want something quieter though so I'm considering the resonated Perrin or the offset version of the Nameless.
Old 10-10-2012, 03:08 AM   #48
mach330
Drives: Ultramarine frs
Just got my Perrin resonated installed. I love it so far. Living in Cali, I wanted something quiet. But I was a bit disappointed that it was quieter than I would like. However, I would rather have it too quiet, than too loud. I wish it was a tad louder. The non resonated would probably be perfect. I do feel better that cops won't pull me over as it's pretty tame until I get really on it.
Gotta fine tune my ecutek tune with it this week.
Tap'd from my G-Nex
mach330 is offline   Reply With Quote
The Following User Says Thank You to mach330 For This Useful Post:
BabaYaga (08-05-2014)
Old 10-10-2012, 03:17 AM   #49
Phaedrus29
Phaedrus29's Avatar
Tap'd from my G-Nex
Thanks for the comments. I have been a bit worried that the resonated Perrin catback might be TOO quiet, although I am looking for something that won't wake the neighbors. If we are planning to do frontpipe also (and maybe overpipe and headers at some point), then maybe resonated is the way to go because those other parts will add volume. I wonder how loud the resonated catback with catLESS frontpipe would be.
Old 10-10-2012, 03:21 AM   #50
mach330
That was my thought process as well as I do want to get a front pipe and maybe over pipe in the future and didn't want to add more noise. Is front and/or over pipe won't pass smog?
Tap'd from my G-Nex
Old 10-10-2012, 03:23 AM   #51
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
Loud and proud. Perrin non res.
driftartist is offline   Reply With Quote
The Following 3 Users Say Thank You to driftartist For This Useful Post:
flippy (11-27-2012), gmookher (10-26-2012), PERRIN_Chris (10-10-2012)
Old 10-10-2012, 03:50 AM   #52
Nardi330
Nardi330's Avatar
Drives: 86
the perrin systems are really a trade off.
go with res cat back + non cat front pipe and you have more power but also more weight.
go with non res cat back + cat front pipe then you gain less power but you also lose weight.
if non cat front pipe + non res cat back isn't too loud then that's the best solution for power & weight gain.
personally i think i'd go for non res catback and cat front pipe as i don't mind a little noise.
The Following User Says Thank You to Nardi330 For This Useful Post:
Old 10-10-2012, 03:54 AM   #53
Phaedrus29
Phaedrus29's Avatar
I just need to hear all of these combos in person, back to back. That shouldn't be too tough, right?
Old 10-10-2012, 04:23 AM   #54
Norcalmav23
Drives: SWP Limited manual BRZ
im probably going to confuse you guys even more on your choices. I have a visconti tune and a resonated perrin catback. I have over 2k miles on this set up. I swear overtime it has become a little louder. I would say it is easily 10% louder than when I first got it. Go figure I LOVE IT. Perrin is awesomeness
Norcalmav23 is offline   Reply With Quote
The Following User Says Thank You to Norcalmav23 For This Useful Post:
Old 10-10-2012, 04:28 AM   #55
Nardi330
Nardi330's Avatar
Drives: 86
once the exhaust is run in, does it sound louder or softer or no change???
firstly too many choices on the market for exhaust. but now that i have picked Perrin, still too many variables.....!!!
Old 10-10-2012, 04:31 AM   #56
Norcalmav23
firstly too many choices on the market. but now that i have picked Perrin, still too many variables.....!!!
definitely louder. More growl. Not loud at all. But I really wouldn't say super quiet, especially now, I give it a 5 out of 10 on the loudness scale.
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 03:23 AM
Nameless Performance Exhaust Group Buy jwuwu Southern California 56 10-28-2012 11:11 PM
Question about Nameless Performance exhaust Metallic BRZ Engine, Exhaust, Transmission 16 08-05-2012 10:06 PM
Nameless Performance Exhaust Group Buy jwuwu BRZ First-Gen (2012+) — General Topics 1 07-24-2012 03:12 AM
