Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 10-09-2012, 11:34 PM   #1
monkie
monkie's Avatar
Drives: 86 GTS
Article on Drive.com.au
Engine problems for Toyota 86 and Subaru BRZ
Rough idle and stalling complaints plague joint venture Japanese affordable sports coupes.
The Toyota 86 and Subaru BRZ may be two of the most desirable cars on the market, but some owners claim to be experiencing engine issues with the sporty Japanese twin coupes.
A report from Automotive News states the Toyota and Subaru two-doors – which were co-developed and are powered by the same 2.0-litre ‘boxer’ engine – are experiencing rough engine idle symptoms and occasional stalling.
According to the article, Subaru and Toyota representatives have stated the issue is related to a software problem. It states the car’s ECU (engine control unit) is an adaptive computer that picks up on how the owner drives the car in the first 100 miles (161 kilometres), and sets the engine to perform accordingly. The ECU may then pick up if the car is being driven outside of these tolerances, and send an error code, causing the engine to idle roughly or stall.
Toyota says the problem is not mechanical, and that the ECU’s software will need to be re-mapped (or “re-flashed” in car jargon) if it has less than 100 miles on the clock. It says that if the odometer reading is higher, the ECU should be replaced.
More: The Toyota 86
Advertisement
Automotive News quotes Toyota spokesman Brian Lyons as saying: “It does involve the variable valve timing, but it does not involve a mechanical repair.”
Subaru, however, claims the fix is not dependent on how far the car has been driven – instead, it claims the ECU simply needs to be re-flashed.
More: The Subaru BRZ
“This is not a mileage-dependent condition,” Subaru spokesman Dominick Infante is quoted as saying. “No replacement of the ECU is needed at any mileage to rectify the issue. The ECU re-flash is the fix. There is not a defect concerning the ECU.”
Drive is still awaiting a response from Toyota Australia and Subaru Australia.
International enthusiast sites such as FT86club.com are openly discussing the problem, with more than 100 registered complaints about rough idle issues including one forum member who says their car has been “in the shop” for three weeks with parts including the engine’s oil control valve and variable valve timing cam gear requiring replacement. In a number of cases, those who have complained and had their ECU re-flashed have stated the rough-idle problem is still occurring.
Australian owners have also taken to the internet to discuss the engine problem. The ************* forum has a thread dedicated to the problem, with several users explaining how their cars have been affected.
“Well in my case if the car sits idle for 1-2 minutes it is likely to conk out and you can feel the car shaking,” writes user tisb0b. “This can usually be negated to an extent by having my foot on the accelerator and brake at the same time keeping it around 1.5k rpms [sic].”
“For me it happens intermittently, mostly shortly after the car is in neutral, idling,” writes forum user keen as. “It is very rough idling, revs varying 100-400, coughing (mis-firing [sic]), car shaking (embarassing [sic] at the lights), stalled once. The engine smooths with light throttle pressure to keep around 1.5k rpms [sic]. If I didn't do this to smooth the engine, I guess the CEL [Check Engine Light] will come back on again.”
Another, apparently unrelated issue raised by some BRZ and 86 owners is that of a “chirping” sound from the car’s fuel pump. Described as similar to the sound of a cricket, the sound is reported to start occurring once the car reaches 300 miles (482km), and while it is not considered problematic, several users on the **************.com site have indicated they are opting for a fix at their dealership.
monkie is offline   Reply With Quote
Old 10-09-2012, 11:47 PM   #2
coyote
coyote's Avatar
Drives: Slowly
Cutting and pasting an entire article is poor form.
Not linking to the original is inexcusable.
coyote is offline   Reply With Quote
The Following 3 Users Say Thank You to coyote For This Useful Post:
a.beck (10-10-2012), BenjKC (10-10-2012), RJ_ (10-10-2012)
Old 10-09-2012, 11:54 PM   #3
davey90
Akina Speed Stars
davey90's Avatar
Drives: White 86 GTS Auto [CID- ***]
Send a message via Yahoo to davey90
Link is here to Original
http://smh.drive.com.au/motor-news/e...010-27cbu.html
davey90 is offline   Reply With Quote
The Following 3 Users Say Thank You to davey90 For This Useful Post:
monkie (10-10-2012), TheDemons (10-10-2012), TheRipler (10-10-2012)
Old 10-09-2012, 11:54 PM   #4
ZZT86
ZZT86's Avatar
Drives: BR86
Ooooopppps, brand T & S ain't gunna like that !!!
http://news.drive.com.au/drive/motor...010-27cbu.html
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
monkie (10-10-2012)
Old 10-10-2012, 12:06 AM   #5
eleu2166
Drives: '07 Civic Type R
Does this mean we shouldn't baby the car the first 100 miles since babying the car is not how I normally 'drive the car'?
eleu2166 is offline   Reply With Quote
Old 10-10-2012, 12:11 AM   #6
davey90
Akina Speed Stars
davey90's Avatar
LOL! I floored it for the first 160ks LOL!
The car is still good! *Touch wood*
The Following User Says Thank You to davey90 For This Useful Post:
nix (10-10-2012)
Old 10-10-2012, 12:27 AM   #7
st162celica
Drives: 86 GTS Manual - Tornado Grey
More: The Toyota 86
Advertisement
OK so which statement is correct, toy says or subi says.
Baby run in. No way. Gradually thrashing it works for me.
st162celica is offline   Reply With Quote
Old 10-10-2012, 12:27 AM   #8
monkie
monkie's Avatar
Drives: 86 GTS
Agree with forgetting to past the link to the site my bad there
In regards to pasting the article that's your opinion i do not see what is so bad about keeping people on the current site that they were visiting in the first place without redirecting them to another one
The Following User Says Thank You to monkie For This Useful Post:
scyzer (10-10-2012)
Old 10-10-2012, 12:27 AM   #9
NG86
Drives: 86 GTS 6MT Pegasus White
I think they meant to say the ECU sets performance parameters according to the last 100 miles, not the first 100 miles.
NG86 is offline   Reply With Quote
Old 10-10-2012, 12:29 AM   #10
JiB
JiB's Avatar
Drives: GT86
i wouldnt say its plagued me, its happened once, and havnt been able to reproduce
JiB is offline   Reply With Quote
Old 10-10-2012, 12:43 AM   #11
ZZT86
ZZT86's Avatar
Drives: BR86
How many k's your car done & how did you run it in (assume very well) & do you have this problem?? The answer to this problem could be to drive it hard from delivery . . . !
Seems awfully fukd that a learning computer quickly determines the future outcome of a car's drive-ability and not follow a set program for life ! Geeeeeee . . .
Old 10-10-2012, 12:47 AM   #12
scyzer
Drives: GTS 86
Agreed that the original link should have been included, but that particular line makes no sense.
The article doesn't take up much space at all and absolutely no one is going to get it confused with original content by the OP.
Cut him some slack...
scyzer is offline   Reply With Quote
The Following User Says Thank You to scyzer For This Useful Post:
monkie (10-10-2012)
Old 10-10-2012, 12:47 AM   #13
ZZT86
ZZT86's Avatar
Drives: BR86
That makes much more sense, but I reckon the computer should grow a brain & not cause issues that many have experienced . . .
davey90 (10-10-2012)
Old 10-10-2012, 12:59 AM   #14
nix
nix's Avatar
Drives: AVO BRZ
Arghh factory ecu updates versus custom reflashes will not be fun.
nix is offline   Reply With Quote
Interesting article Symbiont BRZ First-Gen (2012+) — General Topics 5 09-01-2012 11:25 AM
WSJ Article on the BRZ and FRS... jdub512 FR-S / BRZ vs.... 3 08-26-2012 03:19 AM
AAA Article: What Will We Drive in 2016? MF_DEUCE Other Vehicles & General Automotive Discussions 3 10-26-2011 01:47 PM
