#15 |
Kouki-Monster
The condition was a 0-until I need to start braking (around 90 mph) on a straight stretch of road. I saw the road about to run out so I was on the brakes first step was light and they did almost nothing. Second was hard braking. No lock-up / ABS .. it felt really greasy. I had to engine brake hard like I said to grease off the speed.
Car has 5k miles and has otherwise performed well.
Rich Anderson
EMPOWER AUTO |
#16 |
#17 | |
#18 | |
Drives: AVO Turbo Subaru BRZ / Subaru WRX
#19 |
Drives: '13 DGM BRZ Limited
#20 |
Kouki-Monster
how does 5.1 act in severe cold?
Rich Anderson
EMPOWER AUTO |
#21 |
#22 |
Reap the BReeZe
Drives: 04 LandShark STi
#23 |
Drives: 2017 Subaru BRZ PP
At least it wasn't like this:
[ame="http://www.youtube.com/watch?v=9UkXvXsFO50"]How to ALMOST crash your Subaru in style!! - YouTube[/ame] But anyway, if you're going to be braking hard like that, you need better performance brake pads which are properly bedded in, better brake fluid (DOT 5.1), and better tires.
Toyota + Subaru =
#24 |
Kouki-Monster
It'll happen, and I'll be driving
Rich Anderson
EMPOWER AUTO |
#25 |
Ridge Racerrrrrrrrr
#26 |
Drives: SSM LT MT BRZ
The OP seems to have the exact opposite issue of the rest of the sporting world, his brakes were BELOW their minimum operating temp if you are to believe his scenario played out as described...
I for one have had ZERO issues off track with this car and even on track this weekend i had no problems with repeated stops from 100 mph with or without engine braking, I could engage ABS anytime I would have liked and I had a fresh set of Hankook Ventus RS-3's mounted in 225 flavor just for this weekend.... blame canada |
#27 |
Drives: 23 BRZ
I don't see the point in "upgrading" brake fluid for street use. Same with lines and rotors. The OP was driving on the street, people. He doesn't need upgraded heat capacity, just more friction.The stock pads are a little silly. I changed them to Hawk HPS for street use - much better. Good bite, good modulation, don't need any time to warm up. Beware of vendor posts encouraging you to "upgrade" systems that don't need upgrading.
#28 | |
Drives: Skoda Yeti DSG diesel 4x4
| Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) | Levi | BRZ Photos, Videos, Wallpapers, Gallery Forum | 43 | 05-16-2012 01:37 AM |
| Casey Stoner high speed cornering at 1000fps | tranzformer | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 08-01-2011 05:20 PM |
