Old 10-08-2012, 05:34 PM   #99
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by Opposed View Post
Beside weather, and driver, and altitude, and tires...
looooool 2/2
Tansey86 is offline   Reply With Quote
Old 10-08-2012, 05:42 PM   #100
Cheddar
Saving them pennies...
Gotta love that corn juice!
Cheddar is offline   Reply With Quote
Old 10-08-2012, 06:08 PM   #101
2forme
You forgot wind speed and direction.
The Following User Says Thank You to 2forme For This Useful Post:
Opposed (10-08-2012)
Old 10-08-2012, 06:52 PM   #102
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
The trap speed will still be pretty consistent regardless of the time.. You can judge a lot by the amount of speed a car picks up in the final 1/8 of the track.
Ranatsu is offline   Reply With Quote
Old 10-08-2012, 09:14 PM   #103
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
Originally Posted by VSGTS14 View Post
seems like it's finally better built. the EJ has been around forever. subaru had to at least replace it with something stronger. 06 and up just seemed so problematic.
don't forget, 04 and 05 sti's were holding 400-500whp for a while on pump gas on the stock internals. eventually the boost killed them.
it's all a matter of time. the FA will hold, but not forever. i give them a couple thousand miles before they pop.
So, true. I was pushing well over 500whp on my EJ257 with just bolt-on parts for over 10,000 miles, and that was with the drivetrain loss of AWD. It would have lasted longer if I hadn't pushed it harder, and lifted the heads off with an extra 4psi.
Unless Subaru has made significant changes to the head studs, I suspect they will stretch somewhere around the same power level. I'm guessing ~600whp. Once I saw that the crank was notably beefier, I suspected this new motor would be a champ.
TheRipler is offline   Reply With Quote
Old 10-08-2012, 09:26 PM   #104
TAP Auto Parts
Drives: FRS
Congrats guys, great work!
Just saw a civic si make 620whp on 110, stock bottom end, stock head other then cams. These factory mills are getting better all the time.
Anyone see that S2k set the new NHRA super stock record? 700hp stock block!!!!
TAP Auto Parts is offline   Reply With Quote
Old 10-08-2012, 09:35 PM   #105
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
ehhh... The 2J still holds better records lol
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 10-08-2012, 09:37 PM   #106
Opposed
Drives: 2013 Asphalt FR-S
Fullblown did 800whp stock block...
[ame="http://www.youtube.com/watch?v=cxOLCybSvIE&feature=relmfu"]Ballistics Jake :: Record breaking WHP :: 800.06whp! - YouTube[/ame]
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
The Following 2 Users Say Thank You to Opposed For This Useful Post:
LeeMaster (10-10-2012), TAP Auto Parts (10-09-2012)
Old 10-08-2012, 10:03 PM   #107
Synack
Boosted
Synack's Avatar
Drives: Sideways
I'd just be happy if I could have 300whp at 4000rpm
And some good torque down low.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 10-08-2012, 10:15 PM   #108
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Bring a kit to Florida and put it in my whip I will run it down the track for u
RWD-boxer is offline   Reply With Quote
Old 10-08-2012, 10:19 PM   #109
2forme
300whp at 4000 RPM? That's insane low end. 393ft-lbs.... at 4000 RPM. I don't see that happening on a 2.0 liter. You'd need a seriously large turbo, and at that point, it wouldn't spool until well after 4000 RPM.
Old 10-08-2012, 10:26 PM   #110
Synack
Boosted
Synack's Avatar
Drives: Sideways
I know I know
Drove an IS300 today and I miss the torquier six cylinder.
The car in this thread didn't make it past 200whp/wtq until 5000rpm.... It'll feel like VTEC + NOS + METH + TURBO just kicked in yo, at higher RPM's.
Old 10-09-2012, 02:47 AM   #111
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Originally Posted by carbonBLUE View Post
dont forget accelerated is pushing 9k rpms on the stock valve train at 400+ whp
Are they reall? Is that in any of their dynos? 9k revs.... Does the tach read that high lol
TouchMyHonda is offline   Reply With Quote
Old 10-09-2012, 04:53 AM   #112
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Well, literally speaking, Don overrevved due to his clutch fork breaking and hit 9k. And he is sitting north of 460rwhp.
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
CEL - Engine Blown!!!!!!! rapidcars Issues | Warranty | Recalls / TSB 65 12-10-2014 09:32 PM
Full FR-S Interior Part Out Evasive Motorsports Interior Parts (Incl. Lighting) 22 01-05-2013 11:17 PM
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 09:32 PM
5 Axis FULL BODY KIT?? TRD86 Southeast 7 06-19-2012 09:38 PM
