Old 10-08-2012, 10:28 PM   #1401
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Originally Posted by speedy racer View Post
My FRS has been disabled since 8/31/12 which qualifies as a lemon now. I feel a little better about this CEL issue, now I got the upper hand. After replacing VVTI parts, I have been promised ECU twice and still waiting. I have lost confidence with SOA in finding solid fix and my patience has about reach the limt. If compensation is not to my liking or car is not 100% right, I will excersize lemon law.
As much as its been talked about I don't think anyone has actually gone thru with it yet on this or any forum. Would you look for a new FRS or for Toyota to buy you out of the car?
How long have you been waiting for an ECU?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 10-08-2012, 10:29 PM   #1402
Martin Donnon
86 Racer
Martin Donnon's Avatar
Drives: 86GT
The VVTi issue is with machine swarf in the VVTi actuators, they were not cleaned properly during manufacturing, they need replacing. Take that from someone who has had theirs pulled down after generating a P0016 to find the root cause of the problem. Good luck trying to fix this issue with a reflash
Martin Donnon is offline   Reply With Quote
Old 10-08-2012, 10:31 PM   #1403
Boost_Junkie
3.141592654
Boost_Junkie's Avatar
Drives: 2013 Galaxy Blue BRZ
Riiiight, pics?
Boost_Junkie is offline   Reply With Quote
Old 10-08-2012, 10:33 PM   #1404
gdi2290
Web Designer/Programmer
gdi2290's Avatar
Drives: WRB BRZ Limited (Lemon)
reflash failed they called and told me it was all fixed... I went in my car adjusted my mirrors waited for the engine to warm up then as soon as I shifted to Drive the Check engine light came on... needless to say they're ordering a new ECU and I'll be calling subaru tomorrow.
PS: thought it was funny If you type in "Subaru BRZ Check Engine Light" into Google Images mines the 5th and 6th image
gdi2290 is offline   Reply With Quote
The Following User Says Thank You to gdi2290 For This Useful Post:
ftc~brz (10-08-2012)
Old 10-08-2012, 10:43 PM   #1405
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Your the only other person I've run into with a P0016 code. That would make sense as Toyota insisted on the parts replacement with mine after they analyzed the recordings from the ECU.
Old 10-08-2012, 10:44 PM   #1406
Rob_g
Drives: 2010 4Runner Trail
Originally Posted by Those Meddling Kids View Post
I honestly think the root cause of this issue will end up being low oil pressure. The reflash is most likely expanding the tolerances at which the error codes will be thrown. That's why most of the cars being reflashed are still having poor idle quality but no new CEL. If the car does not have enough oil pressure going to the OCV's and the cam gears the system will not operate properly. The hypothesis of oil passages being blocked or inadequate seems like a very logical explanation for the problem. This is why I'm hoping that my car gets lemon lawed or a very long warranty applied. I don't want to have to pay for Subaru's screwups down the road.
Well the hypothesis does sound interesting. What is also interesting is that there are a few people who reported the CEL right after an oil change.
Rob
Rob_g is offline   Reply With Quote
Old 10-08-2012, 10:59 PM   #1407
HATED1
HATED1's Avatar
Drives: 86
Rob
right on the money!
HATED1 is offline   Reply With Quote
Old 10-08-2012, 11:05 PM   #1408
Alienate
Drives: 2013 Scion FRS
Looks Like Mine Is "Fixed"
Got a call from my service adviser at Scion today. He got a call from Toyota that they were going to "connect their computer to my computer and transfer some new code" They did so, and then they drove it for 50 miles with NO Problems. Told me to come pick it up. I did and put about 30 more miles on it. All SEEMS fine. The idle is very steady at 650 rpms. NO HUNTING.
This was great news as I was told earlier that a new ECU was not coming until Nov 1st.
So I called my SOA rep "LISA" to close out the case. She not in, I got Greg instead. He took all my data and seemed aware of this new data streaming fix. He told me that Lisa would call the dealer tomorrow to verify the job as complete and would then call me to finalize and talk about the "Scion Good Will Extended Warranty.
I had the car 11 days before it went into the shop. It sat there 22 days.
I will update more after some LISA TALK.
Scionara to you
Alienate is offline   Reply With Quote
The Following User Says Thank You to Alienate For This Useful Post:
ftc~brz (10-09-2012)
Old 10-08-2012, 11:12 PM   #1409
JohnS_Rosamond
Drives: Mazda MX5
Though I have no evidence to provide, I think the following:
It was postulated that only about 15% of all cars sold actually had problems. If it was oil pressure resalted it would have effected more cars. If it were bad oil pumps, the cars effected would be clustered within a small VIN range.
The Aussie who stated that he thought it was cam actuators that hadn't been cleaned well makes more sense. It might not be an easily seen defect, so bad parts were put into the factor stream. Debris that comes out of these actuators could get caught in small oil passages, etc. Further, in their hurry to get unhappy customers out the door (and back on the street) it may be that some of the defective units (still boxed up) were sent back out.
This might explain why Toyota / Subaru hasn't really been forthcoming about what is really going on. Who would want to admit that they goofed not once, but twice? Just my thoughts.
JohnS_Rosamond is offline   Reply With Quote
The Following User Says Thank You to JohnS_Rosamond For This Useful Post:
Old 10-08-2012, 11:49 PM   #1410
jduffy
jduffy's Avatar
Originally Posted by Marrk View Post
How about a little Reality Principle with your paranoia? You might find the change both useful and stimulating.
Fear-mongering isn't helping this thread. Let's stick to fact-based statements as much as possible.
Agreed.
Oh and in that vein someone says:
"It was postulated that only about 15% of all cars sold actually had problems." Really, 15%? That's a lot of units failing.
You take the numbers to be sold in the US for Subaru and Toyota it's 16,000. 15% of that is 2,400. The list here contains 129 instances of failure.
So, what you're telling me then is that roughly 2,271 people do not know how to use the internet.
You know this being America, I almost buy that!
jduffy is offline   Reply With Quote
Old 10-09-2012, 12:32 AM   #1411
JohnS_Rosamond
Drives: Mazda MX5
jduffy, you're using my words against me.
I was not trying to say that there was no problem. Nor was I trying to say that the stated problems were insignificant. In fact I feel great empathy for those who have had to wait for weeks without their car while Toypta and Subaru decided to tell owners nothing.
I was simply trying to say that if this was an oil pressure related failure, the rate (in my mind) would have been significantly higher.
Old 10-09-2012, 01:21 AM   #1412
Those Meddling Kids
Drives: 2013 SWP BRZ limited
By low oil pressure I don't necessarily mean the whole system is low on oil pressure. What I meant to say is that there is a problem with oil getting to the cam control system. So low in the system itself- things like clogged actuators, improperly sized oil galleys, etc. Look at the screens in the AVCS cam bolts from the early DBW turbo cars. Many of those cars have experienced turbo failures. When I see similar codes to this in an STI for example it usually is related to clogged lines or low oil which stems from improper maintenance. Many of these cars experience a bearing failure shortly after they start throwing cam control codes.
Those Meddling Kids is offline   Reply With Quote
Old 10-09-2012, 02:51 AM   #1413
cyrus
Drives: 2013 Scion FRS White Out
Just a quick update for others:
The dealer stated a reflash will not fix the issue. They have ordered a new ECU and have no idea when it's coming in as the computer simply says processing. They estimate hopefully 3 to 4 days, but they really have no idea. I'm not sure if the ECU is on backorder or if it's readily available.
They had to contact a corporate tech to take a look at the ecu dump before making any moves on correcting the issue.
cyrus is offline   Reply With Quote
The Following User Says Thank You to cyrus For This Useful Post:
Old 10-09-2012, 08:03 AM   #1414
nomuken
Drives: AE86, IS250, Lancer EVO
all fixed
nomuken is offline   Reply With Quote
The Following User Says Thank You to nomuken For This Useful Post:
eurospeed (10-09-2012)
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 07:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 11:42 AM
Idle issue scioneric CANADA 23 08-24-2012 02:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 11:00 AM
