Old 10-04-2012, 06:26 PM   #211
SnapOv3st3r
Drives: 400whp Scion tC
Originally Posted by Tansey86 View Post
Can we buy the 3" exhaust before the turbo kit? Like will it bolt up to the factory manifold? For people who want to wake the car up but cant afford the turbo kit yet? If so, is there a price yet?
Just keep in mind that you will lose torque when you do. 3 inches on a N/A car does that. You are removing the back pressure by having a larger exhaust and thus killing your torque output. Not the same case when you have a turbo setup cause the turbo needs to flow and hates back pressure.
SnapOv3st3r is offline   Reply With Quote
Old 10-04-2012, 07:25 PM   #212
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Oh yeah man I know, and its gonna be stupid loud, but its gonna be okay because shortly after a turbo will be on it too :happy0180:
Tansey86 is offline   Reply With Quote
Old 10-04-2012, 07:44 PM   #213
SnapOv3st3r
Ok kool. Look forward to it.
Old 10-04-2012, 08:08 PM   #214
Opposed
Drives: 2013 Asphalt FR-S
That is completely untrue and a very old myth. It is very well know that a 3" exhaust on an N/A 4 cyl does in fact NOT lose power or torque. If anything, you gain both of those all across the power band. Most N/A Hondas are running 3" systems that gain more power than their 2.5" counter parts. Just ask Fullblown about how much better S2K's run with 3" systems.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 10-04-2012, 08:16 PM   #215
FullBlown
FullBlown's Avatar
Drives: Scion FRS
The full 3" exhaust that bolts up to the complete kit is only 895? Great price!
yes
FullBlown is offline   Reply With Quote
Old 10-04-2012, 08:21 PM   #216
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by FullBlown View Post
Another happy customer
Blue = Stock baseline
Red = 91 pump @ 7psi
Green = e85 @ 10psi
What about a orange entry for 93 pump @ 10psi.
What would be the highest boost you want take it to on 93?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 10-04-2012, 08:36 PM   #217
Tansey86
Tansey86's Avatar
I'm honestly surprised the motors are holding up with 8 psi on 93. Does the DI help with being able to run more boost with higher compression?
Old 10-04-2012, 09:26 PM   #218
Opposed
That is a big reason
Old 10-04-2012, 09:35 PM   #219
Tansey86
Tansey86's Avatar
Awesome, I thought so.
Old 10-04-2012, 09:49 PM   #220
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Huh???
At stock compression on a K series 11:1 I made 425whp at 16psi on 93 and drove it that way for three years beating the piss out of it. I only ended up building internals for fun later on. I never had any issues with the motor. I'm sure the 86's high compression Subaru motor can handle 8 psi. And incidentally, high compression makes the HP numbers easier to hit.
Jeff86 is offline   Reply With Quote
Old 10-04-2012, 09:52 PM   #221
Tansey86
Tansey86's Avatar
Originally Posted by Jeff86 View Post
Huh???
Well the rule of thumb that ive been lead to believe is low comp = high boost, high comp = low boost. High boost and high comp will always give more power, but you will need more octane than 93.
Old 10-04-2012, 10:07 PM   #222
Opposed
Correct, that is why they are able to run more power with this kit on E85.
Old 10-04-2012, 10:19 PM   #223
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
It's because the higher the octane rating of a fuel, the more compression that fuel can withstand before detonating.
Old 10-04-2012, 11:08 PM   #224
Tansey86
Tansey86's Avatar
8-10 psi isnt high boost, but it is with 12.5:1 cr on 93 with oem internals. Im not misinformed in the slightest. People bashing others is just as harmful as this accused " misinformation"
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 09:32 PM
Exhaust Stage enkubus Engine, Exhaust, Transmission 3 08-14-2012 09:31 PM
Initial D stage 5 86boyAF1 Off-Topic Lounge [WARNING: NO POLITICS] 7 08-08-2012 10:00 AM
Battle Stage 2 trueno86power Other Vehicles & General Automotive Discussions 2 09-26-2011 03:04 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
