Old 10-03-2012, 04:16 AM   #1023
jesperswe
Drives: GT86
300km ago i got new CAM gear and ocv. Had p0017.
Noticed today that when i press the clutch, Going to a stop. Idle goes Low and car shudders then idle jumps up again. Only does this once at every stop. No cel yet....
jesperswe is offline   Reply With Quote
Old 10-03-2012, 09:12 AM   #1024
450hp/tonne
Drives: 2011 Corolla Ascent Sport
Originally Posted by uspspro View Post
Big ____up though... If this is truly the case, then this is going to cost Toyoburu a bunch of money
Maybe not.. looks like the oil passages are in the timing cover.
This shows nothing different to any other Aluminium (Aluminum in US English) timing cover I have seen.
Plus, anything causing issues here would end up in the sump or oil filter, not cam controllers. If this wasn't the case, far more catastrophic failures would be occurring - connecting rod bearing clearance is 0.025 to 0.055mm (0.00098 to 0.00217in for those not using SI units).
450hp/tonne is offline   Reply With Quote
The Following 3 Users Say Thank You to 450hp/tonne For This Useful Post:
Marrk (10-03-2012), OmarGC (10-03-2012), uspspro (10-03-2012)
Old 10-03-2012, 10:20 AM   #1025
mact
Drives: 13 GTI
Wow... the head casting issue makes total sense.
[img]http://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/332734_10151220526064245_1940119701_o.jpg[/im]
What are you looking at in this photo?
mact is offline   Reply With Quote
Old 10-03-2012, 10:52 AM   #1026
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Something was posted on the FB group about a source claiming there was a casting problem with the internal oil passages to the VVTi
It's the only reasonable explanation but it's not the timing cover. The problem is in the head or the cam shaft itself.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 10-03-2012, 11:11 AM   #1027
sajonf
Drives: 13 Scion FR-S, 12 Camaro ZL1
Here's the FB post - I sure hope this is not true:
Got some more info today... Looks like the fix is not going to be a simple reflash, or cam gear issue. These were attempts to fix a bigger issue. The reason the cam gear is not in the correct position is because it is controlled by oil pressure. The casting of the heads is the real cause I'm being told. I have had oil control valves swapped, cam sensors swapped, ecu swapped and problem sill exists. The BRZ they have been swapping parts from has not had the cam related codes pop at all... Even when my "faulty parts" were installed on it to see if it was a non mechanical part. Looks like this is going to be a real major issue which is why there is no simple "fix".
sajonf is offline   Reply With Quote
The Following 2 Users Say Thank You to sajonf For This Useful Post:
eurospeed (10-03-2012), Yruyur (10-03-2012)
Old 10-03-2012, 11:14 AM   #1028
Sargy
Long Distance Driver
Sargy's Avatar
Gave a call, and was told sometime this week before I asked the question to confirm next weeks eta. Will get another update later today.
I am on Week 2 waiting for ECU swap.
Sargy is offline   Reply With Quote
Old 10-03-2012, 11:15 AM   #1029
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Root Cause
Non-Newtonian fluids do weird things when you put them into spinning metal cylinders.
The Following User Says Thank You to @Art_Mighty For This Useful Post:
ftc~brz (10-03-2012)
Old 10-03-2012, 12:40 PM   #1030
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Guys....this is NOT a mechanical issue. Trust me...DO NOT let your dealers take the engine apart and cause more problems. There is a ECM Reflash coming, once it is approved by the EPA & CARB all the dealers will have it available to do.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 10-03-2012, 12:46 PM   #1031
goincarcrazy
Future FR-S Owner
goincarcrazy's Avatar
Drives: '05 Scion tC
Unless you're talking about another one after the reflash they're doing now, they're already doing it...and we're seeing mixed results.
goincarcrazy is offline   Reply With Quote
Old 10-03-2012, 12:51 PM   #1032
sajonf
the link to the facebook page in post 1017
Old 10-03-2012, 12:58 PM   #1033
sajonf
More comments from the same post on that Facebook post
I'm told the oil pressure is off due to improper castings of the heads. The oil journals are not flowing properly to keep correct oil pressure on the cam adjustment at idle. The improper oil pressure is keeping the cam from rotating back to home position. I would not start bringing it up with the dealership at this point but I'm fairly confident in my source of info. My source says its not a mechanical issue, or electronic but a casting issue within the heads.
The Following 4 Users Say Thank You to sajonf For This Useful Post:
einzlr (10-03-2012), eurospeed (10-03-2012), Marrk (10-03-2012), RossGA (10-03-2012)
Old 10-03-2012, 01:01 PM   #1034
Marrk
Drives: Honda Fit
Going Facebook was a mistake. Now we have info moving around and not necessarily covered in both places.
Marrk is offline   Reply With Quote
The Following 5 Users Say Thank You to Marrk For This Useful Post:
einzlr (10-03-2012), eurospeed (10-03-2012), ftc~brz (10-03-2012), hankster (10-03-2012), RossGA (10-03-2012)
Old 10-03-2012, 01:10 PM   #1035
enigmaaron
enigmaaron's Avatar
Drives: '13 Firestorm FR-S MT, '04 Tacoma
X2 Why do people insist on making facebook groups for things that already have a forum/thread on the subject.
enigmaaron is offline   Reply With Quote
The Following 3 Users Say Thank You to enigmaaron For This Useful Post:
eurospeed (10-03-2012), ftc~brz (10-03-2012), Marrk (10-03-2012)
Old 10-03-2012, 01:36 PM   #1036
jesperswe
Drives: GT86
I do not know who to trust actually. I got my cam gears replaced and it got rid of the CEL.
As of today i'm seeing strange idle behavior when going to a stop. But nothing as severe as it was before with the CEL on.
And is this the same Reflash that some people already have got? And there are still failures even with new software.
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 07:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 11:42 AM
Idle issue scioneric CANADA 23 08-24-2012 02:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 11:00 AM
