Old 10-02-2012, 11:40 PM   #1009
Jar
Jar's Avatar
Drives: 2014 SWP BRZ Limited
Originally Posted by pituala View Post
Well....Scion rep is starting to piss me off.
Is it Lisa?
Jar is offline   Reply With Quote
Old 10-02-2012, 11:55 PM   #1010
Rob_g
Drives: 2010 4Runner Trail
Originally Posted by Those Meddling Kids View Post
Take a video of it doing what you say it's doing. Bring said video with you to dealer.
Agreed. I took a video and caught the CEL happening on my car. I've been pushing back and making sure toyota and the dealersip know all the issues and when they happen. My FR-S is now in the shop with no repair available yet here in Canada. Toyota Canada is really leaving customers in the dark...
Rob
Rob_g is offline   Reply With Quote
Old 10-02-2012, 11:56 PM   #1011
DarkSunrise
DarkSunrise's Avatar
Picked mine up from the dealership. The service notes indicate that they tested the VVT-I hardware and found it was working properly. The only real work they did was to re-flash the ECU and test the car (~14 miles).
Driving home, I immediately noticed when the engine is free rev'd, the RPMs drop back down to 600 rpm very slowly and deliberately. That's different than before. No CEL/SL driving home, but at idle, I can feel a slight shudder/off-beat cadence. My STI felt the same way though, so that could be normal.
Will put 400+ miles on the car in the next 4 days and see how it goes.
Old 10-03-2012, 12:02 AM   #1012
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Rob
Are there Lemon Laws in Canada?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 10-03-2012, 12:03 AM   #1013
mact
Drives: 13 GTI
Has anyone thought about how it could be faulty WIRING or connectors going to the cam gear position sensors?
I noticed that a lot of people are getting the P0019 which is a specific corner. Replacing the gears/ECU/reflashing/swapping OCV's doesn't work in some cases. The only common thing other than the engine itself would be the wiring and connectors. I don't know, just thinking out loud.
Maybe the reason these fixes seem to work with some cars and not others is that the harnesses and connectors are touched/unplugged/plugged in/etc while the warranty work is being performed, and the accidental fix is actually in the wiring/connectors themselves. This would also explain the wide randomness in mileage people are seeing the issue as well as why some owners never see the problem at all.
mact is offline   Reply With Quote
The Following User Says Thank You to mact For This Useful Post:
@Art_Mighty (10-03-2012)
Old 10-03-2012, 12:33 AM   #1014
soconfoozed
Drives: 2013 BRZ Limited 6MT WR Blue Pearl
I've spent a lot of time staring at both crimps and IDC under high magnification, and certainly people get both wrong, sometimes badly, but I would be REALLY surprised to see bad connectors in an automotive wire harness.
This is probably all done on an AMP-O-MATIC class machine, and again, it would just be very surprising to see poor workmanship here.
I'm not sure I would buy intermittent connectors in a high vibration environment anyway. But, who can say...
I really ought to be out burning some gas right now to see if my CEL comes back, for my CSR's sake. I suspect I'll be less cranky if I get this failure again BEFORE my crickets are taken care of, as opposed to developing some sense I'm in the clear and can finally try to love my car again, and then throwing another P0019...
soconfoozed is offline   Reply With Quote
Old 10-03-2012, 12:42 AM   #1015
felisa
Drives: Subaru BRZ
https://www.facebook.com/groups/frsbrzcelowners/
felisa is offline   Reply With Quote
The Following User Says Thank You to felisa For This Useful Post:
einzlr (10-03-2012)
Old 10-03-2012, 12:48 AM   #1016
TurnOne
Drives: BRZ Ltd. WR Blue 6MT
Update: 5 weeks today. I called. Expecting new ECU tomorrow. If all goes well, I drive it home. I forget what it looks like. 4 days in the car, 5 weeks in the shop.
TurnOne is offline   Reply With Quote
Old 10-03-2012, 12:51 AM   #1017
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
As per my earlier post, got her back after 5 days in the shop. So far so good...
Here is the summary of the work done from the invoice:
(this part seems to be the initial diagnostic from 9/27)
Code:
VERIFIED CHECK ENGINE LIGHT IS ON, EXTRACTED CODE POO19 : CAMSHAFT POSITION CORRELATION (BANK 2 SENSOR B.) . MOVED B10CV TO B2 LOCATION. CLEARED THE ECM: AND PERFORMED TEST MODE A AS PER TECH LINE INSTRUCTION. RECHECKED FOR CODES AND FOUND CODE P0019 STORED. WILL NEED TO REPLACE BANK 1 EXHAUST CAM GEAR AND PERFORM TEST MODE A.
(this part seems to be the final diagnostic as of 10/2, FYI Tom Blamey is the Subaru field rep in the Sacramento area)
Code:
WAS CONTACTED BY TOM BLAMEY INVOLVING A REFLASH OF THE ECM.TOM BLAMEY INSTALLED REFLASH OF THE ECM-CLEARED THE CODE. PERFORM TEST MODE A AND RETEST DRIVE 43MILES TO SEE IF CODE WOULD RETURN. NO FAULTS OCCURED AT THIS TIME.ADVISE CUSTOMER TO MONITOR.
Any idea what "MOVED B10CV TO B2 LOCATION" means?
tbertran is offline   Reply With Quote
Old 10-03-2012, 01:05 AM   #1018
Those Meddling Kids
Drives: 2013 SWP BRZ limited
Means they moved the actuator valve from one side of the engine to the other. They were looking to see if the actuator was the issue. If it was you would have gotten a p0017 code. Since it got the p0019 code again they decided to replace the cam gear on that side.
Sounds like before they replaced the cam gear the field engineer came out and flashed the ecu instead.
Those Meddling Kids is offline   Reply With Quote
Old 10-03-2012, 01:23 AM   #1019
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Wow... the head casting issue makes total sense.
Big ____up though... If this is truly the case, then this is going to cost Toyoburu a bunch of money
Maybe not.. looks like the oil passages are in the timing cover.
uspspro is offline   Reply With Quote
Old 10-03-2012, 01:43 AM   #1020
Sargy
Long Distance Driver
Sargy's Avatar
Trying to understand that ^
......nevermind I think I see it now
Sargy is offline   Reply With Quote
Old 10-03-2012, 01:45 AM   #1021
uspspro
Something was posted on the FB group about a source claiming there was a casting problem with the internal oil passages to the VVTi
As far as the picture... on the right is the oil pump housing, on the left is up near the cams
It would be interesting if new timing covers show up on the next TSB... haha
The Following 3 Users Say Thank You to uspspro For This Useful Post:
@Art_Mighty (10-03-2012), Sargy (10-03-2012), Yruyur (10-03-2012)
Old 10-03-2012, 02:21 AM   #1022
Yruyur
Yruyur's Avatar
Very interesting. I'm still not signing up on facebook though.
The Following 2 Users Say Thank You to Yruyur For This Useful Post:
eurospeed (10-03-2012), ftc~brz (10-03-2012)
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 07:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 11:42 AM
Idle issue scioneric CANADA 23 08-24-2012 02:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 11:00 AM
