Old 09-29-2012, 02:12 PM   #1
Calidrifter
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
Installing JDM Window Visors
Type: Cosmetic
Time: 30-40 min
Tools: heat gun/hair dryer (optional depending on area)
I got these from Nigel-jdmparts.com I ordered them on a Tuesday and got them on a Monday. Very fast ordering process and delivery
In the box you get the left and right visors plus some very detailed instructions and two guides so that you set both visors in the correct area.
First you want to roll, down th windows and prepare the area by rubbing some alcohol where the visors will be attached to the body. Per the instructions you want to do one wipe from the front to the back.
Next you need to place the guides. The back one lines up with the line where the front and rear trim pieces meet:
The front one lines up with where the body panel lines up with wind shield:
The rear of the visor is marked with a tab. Pull up the tab so that the sticky part is exposed:
Place on the car to line it all up. DO NOT press down on the sticky end yet:
The tabs (seen below)go between the black trim piece and the body. Note that there is a small chanel between the front part of the trim and the back. The visors will not go in and you might break the tabs if you force it down in this area.
You will hear a 'click' once the tabs have gone in correctly. To make sure they are in by gently trying to lift the visors out. You will not be able to lift them out and will feel a small tug.
Once it is lined up with the rear press down on the part with the exposed sticky end to set the visor in place:
The back of the visor lines up with the guide you placed on the the rear of the black trim.
The front will not line up but there should be an even gap between the visor and the guide.
Remove the sticker backing to expose the sticky end along the entire visor and press down on the visor starting at the rear and going to the front.
Press down on the visor a couple of times to make sure that it all sticks.
Optional for colder areas: instructions say to heat the area from under the visor on the window side to help the visor to stick. It's been close to 100 here is other California so I didn't do this part.
Club 4AG | Apex'i | HKS | GrimmSpeed | TRD | Beat Sonic | ENKEI | Cusco | Fujitsubo
Originally Posted by Jyn View Post
That guy, like me after BBQ Thursdays, is full of shit.
Calidrifter is offline   Reply With Quote
Old 09-29-2012, 02:28 PM   #2
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
pics pics!!
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 09-29-2012, 02:31 PM   #3
boonFRS
Drives: 2013 Scion FRS whiteout
Daylight pics please lol.
boonFRS is offline   Reply With Quote
Old 09-29-2012, 02:39 PM   #4
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Need moar pics!
Beyer Subaru is offline   Reply With Quote
Old 09-29-2012, 03:17 PM   #5
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Is this OEM? Usually called rain gaurds around here.
chulooz is offline   Reply With Quote
Old 09-30-2012, 05:42 PM   #6
showbe
Drives: A nice one
Is this really a question?
Do you not know how to read the thread title?
showbe is offline   Reply With Quote
Old 09-30-2012, 07:12 PM   #7
chulooz
Registered you sir
chulooz's Avatar
Dont be rude to me.
And take your foot out of your mouth before you respond, nowhere does it say OEM.
Old 10-01-2012, 12:18 AM   #8
cto424
update on pics?
cto424 is offline   Reply With Quote
Old 10-01-2012, 09:29 AM   #9
Beyer Subaru
Yes, per the title these are the OEM, JDM, Toyota Rain Guards for the 86 model line-up that is also named the BRZ and FR-S in other world markets
Dont be rude to me.
Now we still need moar pics!!
Old 10-01-2012, 12:42 PM   #10
Cudgel
Drives: 2008 Mazda3 GT Hatchback
Yes, daytime pics please.
Also, how much did these run you?
Cudgel is offline   Reply With Quote
Old 10-01-2012, 10:12 PM   #11
Calidrifter
@Executive_chicken
Ok, ok I'll get the daylight pics as soon as I can. Forgot to take my DSLR to the Tanabe/Club 4AG meet. I'll try to get some pics tomorrow in the daylight.
Yes, these are OEM JDM parts.
Old 10-01-2012, 10:16 PM   #12
Calidrifter
@Executive_chicken
I got these for 320 picked up through Nigel-jdmparts.com but he is currently running a group buy for these here:
OEM JDM Groupbuy
Old 10-01-2012, 10:52 PM   #13
Cudgel
OEM JDM Groupbuy
Ouch! Those are really pricey. Thanks for the info and I'm looking forward to more pics when you have time.
Old 10-01-2012, 11:00 PM   #14
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Been said. Daylight picture request.
I call them smokers vents BTW.
Great for smokin.
I usually-always have the windows down a bit.
Ohh... more pics.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Installing BRZ Trunk Interior Liner into FR-S DarrenDriven DIY (Do-It-Yourself) Guides 30 11-19-2016 02:06 AM
DIY: Alarm installing wiring diagram trueno86power DIY (Do-It-Yourself) Guides 17 02-07-2014 09:03 PM
How necessary is alignment after installing new springs? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-22-2012 11:52 AM
Installing GT86 AC unit? SupraLove Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 02:08 PM
[FR-S] Installing New Subwoofer and Mono Amp hx3 Electronics | Audio | NAV | Infotainment 0 08-09-2012 07:12 PM
