Old 09-29-2012, 03:49 AM   #911
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
Originally Posted by Tricky1980 View Post
if i press my gas pedal very slow in nuetral.. i can get to a point about 3/4 of an inch in pedal movement.. before rpms move at all.. i can create a ticking noise...
if i blip gas pedal quickly and lightly .. i can get teh rpms to DROP before they go up...
under WOT from a 5mph roll my car has very low power it feels.. when im moving and rpms are closer to 3kish car pulls great
i have about 120 miles on my cam gear and egi repair... meeting oct 17th with toyota and 3rd party arbitrator.. i just dont like the way the car feels.. even after repair...
hopefully i get what ive requested and that is to walk away from deal. and i woudl cover interest expense on 2 months ive owned the car.. my insurance costs and whatever "usage" fee they wanna throw at me for my 225 miles ive put on the car.
Man, im sorry you arent happy with the car and have had such difficulty. From what you describe, WOT from a 5mph roll would be at very low rpm's, where torque is at its lowest. In order to maximize acceleration, you should keep the engine above 4.5k rpms to utilize its optimal powerband. The engine responds very similar to a rotary in the feel that it needs to spin up, or get to a certain rpm before it really starts dispersing its power to the drive train. This keeps "torque dip" as its being called, helps keep mpg's high, and the car manageable in bad weather conditions.
Best of luck during your negotiations, I hope you get what you want, and for better or worse, you wont have another car like the 8-6.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
The Following User Says Thank You to Grishbok For This Useful Post:
gmookher (09-29-2012)
Old 09-29-2012, 08:42 AM   #912
Tricky1980
Drives: 2013 Raven Fr-s
Yeah, i understand its "lower torque" i guess when i mean its doggy is you try to pull out in traffic and im nervous about it.... i had a stock 240sx(same torque) and it could go from a dead stop(withoutdropping the clutch at 4krpms) i dunno... maybe its the car but that seems odd to me... i just feel like its hard to get up to speed sometimes.. it doesnt feel that way every time, which is why i think my car is "covered up" not fixed....or im paranoid and looking for another problem.
Tricky1980 is offline   Reply With Quote
Old 09-29-2012, 08:49 AM   #913
Grishbok
Grishbok's Avatar
How many miles are on your engine? At around 3-5k miles, the engine starts becoming a lot more responsive and sharp. I think you may be referring to a bit of lag or delay as a result of the engine components being brand spanking new. On any new car, there is a definite delay in response until the engine settles in. It takes a few thousand miles for everything to settle in and to really start delivering.
Old 09-29-2012, 10:14 AM   #914
choi0706
Drives: t
I wonder why scion has a reflash avail and subaru wants to change the ecu..
choi0706 is offline   Reply With Quote
Old 09-29-2012, 11:10 AM   #915
pituala
Mr. Know It All
Drives: 2013 FR-S Asphalt
So I started a list of complaints for my Rep when I speak to him on Monday;
- A/C smells bad when I turn it on.
- The erratic idle and clunky timing chain slapping sound when the idle drops.
- Engine ticking (I have to listen to this a little closer, it may be the injectors...will check when I get home from work today)
- Was told they put 50 miles on the car, but they actually put 100 miles on the car. I dropped it off with 905 miles and got it back with 1004 miles (yes technically that is 99 miles). I wouldn't really care about this except I dropped the car off with a near full tank of gas and got it back with less than a 1/4 tank, but I was expected to return the rental with the same level of gas. They owe me a tank of gas.
All of this may cause me to reconsider my compensation needs.
2013 FR-S Asphalt MT (55w HID's)
1985 Celica Supra 1JZ (Stupid Fast)
pituala is offline   Reply With Quote
Old 09-29-2012, 11:44 AM   #916
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I think it's because most dealers are not equipped to flash the ECU in these cars...yet
F1point4 is offline   Reply With Quote
Old 09-29-2012, 12:00 PM   #917
choi0706
Drives: t
alot of the tsb stuff I've found came through scion first.. Including the HPFP ..
the flow chart says to replace the ecm from subaru.. scion's tsb says to reflash..
The Following User Says Thank You to choi0706 For This Useful Post:
Marrk (09-29-2012)
Old 09-29-2012, 12:34 PM   #918
Marrk
Drives: Honda Fit
Originally Posted by CMOS View Post
This is not the end.
This is not the beginning.
This is not the beginning of the end.
It is not even the end of the beginning.
Computers make very quick and very precise mistakes, if this was one of those it would come up for everyone by the time they got home. I assume that Subaru in their infinite wisdom has designed one computer and replicated it a few thousand times rather than making each one unique. Either all of us have a failing timer module or that thing is not kidding about the engine problem. Personally I'd like to know the cause of the error and not the symptoms before making repairs that mask the symptoms and lead to valve shaped hood ornaments.
I agree.
On the other hand, if a "work-around" effectively solves the problem, and no parts later come flying through the hood, then I would say it amounts to the same outcome.
Just because we don't know what the problem is doesn't mean that they don't know what the problem is. Also, if they are willing to change hard parts and software in an attempt to fix the problem, then it doesn't sound like they are simply trying to "mask the problem."
But, again, I agree with you. Best to know what's going on in toto.
Marrk is offline   Reply With Quote
Old 09-29-2012, 12:39 PM   #919
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
Reflashing didn't fix mine. Replacing the ECU seems to work better from what I've seen on this thread. I'll find out Tuesday when they hopefully replace mine and fix it for good.
rapidcars is offline   Reply With Quote
Old 09-29-2012, 01:09 PM   #920
jesperswe
Drives: GT86
And Toyota Sweden didn't do anything of that. They changed my Cam Sprocket and OCV (P0017 code) and i've had the car back for 3days and so far no CEL
jesperswe is offline   Reply With Quote
The Following User Says Thank You to jesperswe For This Useful Post:
Marrk (09-29-2012)
Old 09-29-2012, 01:42 PM   #921
choi0706
Drives: t
I had my parts changed, and still showing a CEL/SL right away.. The dealer ordered a new ECM because a reflash isn't on the flow chart..
Marrk (09-29-2012)
Old 09-29-2012, 03:58 PM   #922
Christina_Marie
Christina_Marie's Avatar
Drives: 2013 Asphalt FRS AT
add me to the list as well :
christina_marie, FR-S (Asphalt AT), 7073xx, western MA area - normal break in, never went above 4K and didn't drive her hard until after 1000 miles.
first incident - 8/20 (day of purchase) with 40 miles on her - CEL popped, no SL, no engine shake or anything else noticeable, brought it immediately back, all they did was clear the code and I was good to go for a week.
second incident : 8/27 (830 miles) - CEL/SL/extreme engine shake, RPM hunting, code pulled P0019. Was in servicing for 3 or 4 "business days" and given a loaner. They swapped the OCV sensor, cleared the problem for awhile until the following ...
third incident : currently in for service as of 9/23 with 2200 miles on her - CEL/SL/(CEL was actually blinking this time)/engine shake/RPM hunting - service manager stated new ECU being ordered, 2-3 week wait as most everyone else is hearing. my service rep already talked to a toyota/scion corporate rep who approved compensation of some sort once the problem is "fixed", which I'm happy about at least. I will be well within lemon law rights in MA by the time the ECU even comes in, so that will be worst case scenario if need be. Just miss driving her as everyone else is feeling ! I will post updates as soon as I hear anything ..
Christina_Marie is offline   Reply With Quote
Old 09-29-2012, 04:20 PM   #923
HATED1
HATED1's Avatar
Drives: 86
looks like you and i have had the same type of symptoms, keep us posted!
HATED1 is offline   Reply With Quote
Old 09-29-2012, 07:42 PM   #924
CMOS
Drives: 2012 FUJI Z
Originally Posted by Marrk View Post
I agree.
My concern comes from the inability of replacement engine components to permanently make one engine send as proper of signals as another, this implies that something is different about the way it operates and the computer is not happy with that. Why would a simple rev counter become unhappy with these engines while another 50%+ seem to operate as intended? Additionally, if the computer is at fault, why does the computer seem to pick a specific cause of concern rather then all of the symmetrical parts?
CMOS is offline   Reply With Quote
The Following User Says Thank You to CMOS For This Useful Post:
@Art_Mighty (09-29-2012)
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 07:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 11:42 AM
Idle issue scioneric CANADA 23 08-24-2012 02:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 11:00 AM
