Old 06-09-2011, 07:35 AM   #15
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by 70NYD View Post
For the 100000000 time HAVE 2 exhausts. What the hell if you don't like it chop one off
I'd rather have 2
SUB-FT86 is offline   Reply With Quote
Old 06-09-2011, 08:15 AM   #16
Leeky
3S-GTE Junky
Leeky's Avatar
Drives: Toyota Celica GT-Four ST205
I dont mind twin exit as long as they are equal and one isnt just legged off the other.
I'd prefer single exit though.......
Leeky is offline   Reply With Quote
Old 06-09-2011, 08:54 AM   #17
bofa
Drives: Ms. Daisy
Originally Posted by ft86cbx View Post
Toyota, if your listening, give us some more info, take a look at the forum, your killing it
Amen to that...
BRZ before hoes
bofa is offline   Reply With Quote
Old 06-09-2011, 01:21 PM   #18
PAImportTuner
Turbo Mafia Presidente
PAImportTuner's Avatar
Drives: U Mad?
LOL
That would suck to have a Scion brake light, there goes easy badge swap.
Aftermarket companies will have a dual exhaust.
I'd like to make my own, do a 2" diameter true dual with 2" x-pipe and 2 mufflers. Everything would be 2" diameter and each muffler would be 2" inlet&outlet/5" round body/2.5" tip. Like a motorcycle.
http://www.alibaba.com/product-gs/46...showimage.html
OR
"the FR-S is going to have to give me a blowjob every time I touch the steering wheel if all it can make me smile with is the handling." - Maxim
PAImportTuner is offline   Reply With Quote
Old 06-09-2011, 02:48 PM   #19
82mm 4g63
4G63 & Rotary
82mm 4g63's Avatar
Drives: 92TalonAWD, 93RX7, 11F150EcoBoost
Send a message via AIM to 82mm 4g63
I'd like the dual exhausts if it were truly dual exhausts. If it goes from two pipes, to one pipe, and back to two you might as well just keep it one. However, if they're running two pipes all the way back...keep the dual exits!
82mm 4g63 is offline   Reply With Quote
Old 06-09-2011, 03:02 PM   #20
bofa
Drives: Ms. Daisy
I'm pretty sure, based on everything we've seen so far, its a single pipe to a single muffler with dual outlets, very similar to the Z.
I imagine there will be true dual offerings via aftermarket but that's somewhat counter-productive to the light weight concept... although I personally would be willing to deal with any moderate increases in weight in exchange for slightly improved performance and better sound. Then again, my car probably won't see a track very often.
BRZ before hoes
Old 06-09-2011, 06:47 PM   #21
zigzagz94
BRZerhood Lurker #13
zigzagz94's Avatar
Drives: 15 DGM BRZ Premium
Yep that's the way it goes. Toyota drops a little nugget of knowledge, the forum blows up for a couple weeks, and then it slowly dies down until just the hardcore members are left trying to derail every thread into OT.
zigzagz94 is offline   Reply With Quote
Old 06-09-2011, 06:49 PM   #22
Neutral_Eyes
Softparker
Neutral_Eyes's Avatar
Drives: 2002 Mazda Miata
Add turbo. Single side exhaust.
Neutral_Eyes is offline   Reply With Quote
Old 06-09-2011, 06:53 PM   #23
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by Dark View Post
Aftermarket can take care of exhaust.
If anything if you really are against twin exit, you should hope that they DO put that on the production model. At least then you can stand out with your single exit and not look like us tossers.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 06-09-2011, 06:58 PM   #24
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I'm reading true dual piping... what's true? from header to exhaust dual pipe (like muscle car)? from cat to exhaust dual pipe (like Supra)?
Old 06-09-2011, 07:05 PM   #25
bofa
Drives: Ms. Daisy
Header to exhaust is true dual. I think your cat to exhaust example is referring to a y-pipe setup where the headers combine into 1 pipe and split after the cat and before the muffler(s).
BRZ before hoes
Old 06-09-2011, 07:17 PM   #26
ichitaka05
Site Moderator
ichitaka05's Avatar
Hm... if that's the case, then isn't that add more weight to the car? Also two separate cat equal to two extra o2 sensors (before cat & after cat)... which means more ecu crap. Also add to that, isn't it gonna cost more for after market parts?
Old 06-09-2011, 07:38 PM   #27
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by PAImportTuner View Post
LOL
OR
They sell most of the components to build your own muffler if you want to make it similar to a bike. It'll be beyond loud though...
http://www.motorcycle-superstore.com...cessories.aspx
http://www.carpimoto.com/EN/13734_P-...-from-list.htm
Old 06-09-2011, 07:52 PM   #28
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Im with Ichi on this one. A single exhaust will probably be an all around better option for this car. Except for the personal aesthetic opinions but to those I say: Function > Form (within reason of course)
chulooz is offline   Reply With Quote
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 10:27 PM
If there is no Toyota will you go with Scion or Subaru tranzformer Scion FR-S / Toyota 86 GT86 General Forum 91 04-25-2011 11:53 PM
PRIZEFIGHT: Toyota or Subaru? Raiden Scion FR-S / Toyota 86 GT86 General Forum 16 10-25-2010 08:04 PM
