Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-26-2012, 03:17 PM | #15 |
Drives: 2013 Asphalt FR-S
I don't think so...at least not on the E85 tune. I have the aFe intake or (Greddy) and I have had no issues yet. In fact, that idle seems even better. It is crazy smooth with John's tune. Not sure about performance however? Sometimes the stock felt better, sometimes the intake feels better, sometimes it feels the same. I will have to wait until my dyno to test the two.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
The Following User Says Thank You to Opposed For This Useful Post: | travace (09-26-2012) |
09-26-2012, 04:43 PM | #16 | |
Chronic Flashturbator
Drives: '13 Scion FR-S MT
Above 2k rpm, the car seems to run better though, so I doubt there's a leak or operator error. When it goes to that low +/-650rpm idle, that's when the trouble happens, likely meaning that it's something that just needs to be fine tuned. The engine's low-speed throttle response is also compromised, meaning that it needs more pedal to launch. Sometimes it even randomly loses all power for a split second at 1000-1500rpm just after I (gently)let out the clutch, so now I have to launch at 2000-2500 to be safe. I read the Airraid intake thread and apparently many people are having similar problems with that intake as well, so at least I don't feel like I chose the wrong intake. Any intake seems like a bad idea on the stock tune.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
09-26-2012, 06:36 PM | #17 |
Drives: 2013 BRZ Limited 6MT
Sucks to get something new and shiny and have probs, good luck. FYI since I saw it's something you are considering. I'm running the aFe dry drop-in. No issues at all with stock, pumpgas reflash, or E85. Can't say that it helped, but more importantly it didn't hurt.
09-26-2012, 06:56 PM | #18 |
Drives: Scion FR-S
I have this intake and I have not had a single problem with it. The sound did change and get a little deeper in the first few days as the ECU got use to it. after 300 miles on it I got a tune that limited the low end of the rev to 800 instead of the stock 4 stops that backfire sound people are talking about I heard it once so I just did the tune.
09-26-2012, 07:09 PM | #19 | |
Backfire sound? Are you talking about when the idle dips below 650 and shoots automatically to 1000? If this is an actual backfire sound, I haven't heard it. How expensive was your tune? Anyways, I just unplugged my battery again. This time I have left it unplugged for a good two hours, ensuring that the ecu is reset properly, hopefully. I also adjusted the filter a bit more to the end of the tube instead of pressed on as far as it will go, which was probably inconsequential, but worth a shot in my book. \ EDIT TO EARLIER POST: -Upon further inspection and thought, I figured that the filter would probably achieve the best flow with the tube stuck in as far as it would go, so decided against my previous adjustment above. -Furthermore, I disconnected the intake tube from the throttle body and repositioned it so that the airfilter was further away from the intake tube's hole on the airbox. Previously, I had it positioned so that the airfilter's rubber gasket(where the pipe fitting is) was nearly butted up against the side of the airbox, nearly plugging the hole that the intake tube goes through.
09-26-2012, 08:47 PM | #20 | |
Drives: Scion FR-S
09-26-2012, 08:50 PM | #21 |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Maybe someone stated this before or I did not read it. But I wonder how many people that are having intake bogging issues with or without an aftermarket muffler. it seems like back when I installed an injen intake on my Celica I had more bogging issues before I put on my performance muffler. I also had more rpm idle dips before the muffler as well.
09-27-2012, 12:09 AM | #22 | ||
The Following User Says Thank You to BuBlake For This Useful Post: | whataboutbob (09-27-2012) |
09-27-2012, 01:52 AM | #23 | |
Drives: Scion FR-S
Sent from my SGH-T989 using Tapatalk 2 |
09-27-2012, 05:05 PM | #24 | |
Addicted to cars
Drives: 2013 Whiteout FR-S AT
2009 370z (sold), 2011 Mustang v6 Premium (sold), 2013 FR-S [Whiteout](current)
09-27-2012, 07:12 PM | #25 | |
The idle is still choppy, but most of, if not all of the low speed throttle response came back during my last drive, which is about my third drive since my last ecu reset. It only gets a super low idle for a short period of time now, similar to problems people have when this car is 100% stock. It did get low idle, but the engine didn't stall and it never cut power while I slowly accelerated. Before this last, third drive, I adjusted the "crank case tube"... Could that be the reason? I previously had it slipped about 1/2 the way down the inlet, but now I have it pressed all of the way over the inlet and against the intake tube. Maybe that was the problem all along! Update: Although it has improved, the occasional bog is still there. The idle of the car is all over the place, switching phases and whatnot, but doesn't seem as prone to a dangerously low idle anymore... My guess is that another ecu reset may be needed, since I haven't reset it again since I adjusted the crank case hose.(What may have been the issue.) However unlikely it seems, i'm willing to try anything rather than swap the stock intake back on.
09-29-2012, 01:50 PM | #26 |
Alright guys, I know you're tired of this thread already because all I do is complain to no avail, but now my car is running great and I would like to share some advice for anyone else getting this intake:
-Make sure the crank case tube is slid all of the way on, not half way! I thought that having it all of the way on would kink the tube, so I backed it off a little. Instead of helping, this actually caused my engine to run like crap with this intake. That's what apparently caused all of my problems: -Choppy idle -loss of torque at +/- 1500RPM The car doesn't run perfect, but it does seem to have more top end power. The low speed throttle response is now about 95% of what it was stock. Idle is fixed and it restored my confidence... Now back to enjoying the car without worry of reliability or random jerkiness!
The Following User Says Thank You to BuBlake For This Useful Post: | BRZranger (11-01-2012) |
09-30-2012, 08:34 PM | #27 |
The Following User Says Thank You to EN2_Squirrel For This Useful Post: | FantomRider (10-01-2012) |
10-11-2012, 12:33 AM | #28 | |
Drives: Supercharged Car
The Following User Says Thank You to itsibarra For This Useful Post: | BuBlake (01-18-2013) |
Similar Threads | ||||
Injen Short Ram Intake Installed on my 86 :D | R2RO | Engine, Exhaust, Transmission | 57 | 06-10-2014 07:14 PM |
Injen Technology Intake ;) | staycrushing | Engine, Exhaust, Transmission | 61 | 08-21-2012 09:28 PM |
Injen Intake IN STOCK! | Mach V Dan | Engine, Exhaust, Bolt-Ons | 0 | 08-14-2012 01:04 PM |
