BRZ Stock Head Unit + Aftermarket Amp + 3-way Components question
Has anyone installed 3-way components (powered by an aftermarket amplifier); while retaining the original head unit? If so, I want to know how you installed everything! My understanding of the system is as follows:
The plan is to:
How I *currently* plan to wire this up:
I was wondering:
Any and all help would be appreciated!
#2 |
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
Didn't really read the details of your post, but this build uses the OEM fujitsu ten head unit.
http://forums.nasioc.com/forums/show...php?p=36481713 |
#3 |
It's really difficult. The factory head unit has the crossover built into it. It powers the dash speakers directly while offloading the door speakers to the amp in the trunk. You're better off just getting an aftermarket head unit if you're dead set on using an amp with a 3 way setup.
On my install, I removed the stock amp, and put the crossovers there while putting the 5 channel amp opposite of th(both under the trunk "floor"). |
#4 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
You want to add something like JL Cleansweep into the setup.
#5 |
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Actually it's very easy. This car is a piece of cake and the Nav unit works fine as there are NO crossovers built into it. See my link below for a partial build thread. Also got one on diymobileaudio.com
#6 |
Thanks for the input y'all. The spec sheet of the Audison Bit Ten states:
"Automatic de-equalization of signal fed into the high-level inputs (with supplied Test CD) if necessary. It can also be performed without the PC." Knowing this, one could feed the door speaker's source (that is already being run to the stock amp) to the Bit Ten, and have it de-equalized to a full-range signal, correct? Or would I need to use the amplified signal from the stock amp? |
#7 |
My experience was completely different. Are you sure you're talking about a BRZ? What is the model of your stock head unit?
#8 |
Drives: 2016 Toyota 4Runner Trail Premium
Has anyone tested the stock amp inputs to see if they are full range? The head unit output only
has provisions for LF, RF, LR, RR. That leads me to believe that the inputs for the stock amp are just split from the LF and RF with no processing (full range). |
#9 | |
Running a test tone through my amp directly and looking at my RTA then running through the HU, almost identical, for all intents and purposes. I keep volume between 30-45, set gains so it covers the volumes I want. The unit may modify the curve at lower volumes, but I didn't check that. Make sure your EQ is flat...
#10 |
Input to the amps is full range. Rear is run of the HU.
| The Following User Says Thank You to michaelahess For This Useful Post: | sure74 (09-25-2012) |
#11 |
So you can place the LOC where the stock amp is. Grab the front channel inputs from the stock
amp inputs and grab the rear channel inputs from the rear speaker locations. This will minimize the wire needed to light up the LOC. |
#12 | |
My build thread links off the link below has some pics of it.
#13 |
Drives: Whiteout FR-S
Can you tell what frequency response the stock speakers are seeing from the amp?
#14 |
Engineer
Drives: WRB 2022 Subaru Brz
Just to be clear, The front door speakers are powered by the stock amplifier right. The rest of the speakers in the car, the two speakers and tweeters on the dash and the rear speakers are all being powered by the head unit?. Right now i am running jbl p66s speakers in the doors and infinity reference speakers on the dash. The jbl's are 2ohms and have 55 watt rms. Does the stock amplifier have enough juice to power the jbl speakers?
I am thinking of getting the alpine power pack to boost the head unit's power output. the alpine power pack is good in that it can be tucked away behind the head unit, a much cleaner install.
| OEM mic with aftermarket head unit | phenom86 | Electronics | Audio | NAV | Infotainment | 13 | 05-10-2013 12:20 AM |
| FRS aftermarket head unit installation - wiring | MindtheGap | Electronics | Audio | NAV | Infotainment | 35 | 01-14-2013 10:00 PM |
| Stock Stereo Head Unit Languages | Bonburner | Electronics | Audio | NAV | Infotainment | 12 | 08-18-2012 09:41 PM |
| stock nav head unit outputs | brzzz | Electronics | Audio | NAV | Infotainment | 2 | 07-13-2012 04:37 PM |
| Is the standard stock FRS head unit good to go if I.... | Liquidsnake | Electronics | Audio | NAV | Infotainment | 2 | 06-17-2012 04:16 AM |
