#29 | |
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
For those touching on quality, even higher priced, "real" wheels can fail. Obviously not as frequently as lower end or "cheap" ones. As people mentioned, that's due to materials/manufacturing process.
However, even cheap wheels, such as rota, have come a long way from what they used to be. I know people that track on expensive and cheap wheels... both have been fine without issues. What's important to look at is HOW the wheel failed, i.e. what conditions was the wheel subjected to first. Poor fitment for a wheel (mostly "fake" ones, unfortunately) is often overlooked (e.g., brake caliper rubbing against the wheel). Running off track or slamming into a curb is often overlooked. The end result is usually the same: "Brand X sucks don't get them, look how they broke." Quote:
#30 |
In addition, I'm not advocating to use cheaper wheels or more expensive wheels. Either can be just as functional. Care needs to be taken, regardless which type one chooses. Slamming into a pot hole can be bad for any wheel, not just a cheaper one. In the end, choose a wheel that you think meets your needs.
#31 |
Drives: Scion FRS Asphalt
What do you guys consider "Fake" vs "Real"?.. every wheel are real, they are just rebranded for different markets.. If you consider Rotas fake which are "reproductions" of and they have been tested on track and in house to make sure they are safe. my friends in the philippines uses rotas for drifting, track and everyday usage.. One particular friend of mine uses custom rota wheels for his cars and he drifts the cars on rotas plus he told me he'd rather use those than expensive wheels.
Cefiro A31 RB25 17x9.5 ET (-10) 235 45 17 ![]() His M5 with custom wide wheels ![]() If you guys do a search and look up wheels UK, you will find also wheels that have been reproduce for their market to fit their cars which those wheels are not available in our country. This has been an on going debate through all the forums.. here are pics of "REAL" wheels that broke.. then ask yourself how much you would pay for wheels.. Id buy Rotas any day, use the saved money for some expensive tires. Enkie RPF-01 ![]() Advan TC-II ![]() SSR ![]() Custom HRE Wheels ![]() Rays (notice Made in Japan)
| The Following 2 Users Say Thank You to phenom86 For This Useful Post: | diirk (09-20-2012), Propaganda (09-20-2012) |
#32 |
Drives: bicycle
Yes we know that even real, high quality wheels can fail and that's fact. Any wheel can fail really. The issue here which fails more often? Imitators or innovators?
| The Following 2 Users Say Thank You to RAYSSPL For This Useful Post: | Godzilla35 (09-29-2012), Ro_Ja (09-20-2012) |
#33 | |
Well that all depends on how you use it, im sure 90% of the guys here will never track their car to even push the limit of their wheels. Daily driving im sure the reproduction wheels will do its job as good as the originals. Im not expecting my wheels to come apart going around a turn in my commute.
| The Following User Says Thank You to phenom86 For This Useful Post: | Propaganda (09-20-2012) |
#34 |
Drives: 2013 FR-S Argento
I think this is generally true for strength and cost:
gravity cast < low pressure cast < flow formed < forged and this is generally true for wheel weight for a given load capacity: forged < flow formed < low pressure cast < gravity cast |
#35 | |
Maybe check into the manufacturing process and load capacity of the wheels along with the weight, cost, and looks, before deciding. |
#36 | ||
Drives: DC5
besides that "custom hre" wheel, these wheels all were obviously subjected to some sort of hard IMPACT which caused the the wheels to break. The great thing about Volk wheels is that even in accidents, they dont break, they usually bend. Which is why they're so highly regarded in the racing industry because a bad off on the racetrack will crack a low quality wheel causing it to lose air, while the Volks will bend but still hold air to continue and finish the race. now if you look at these replica wheels pictured, they didnt simply break because of an impact, they FAILED! The freakin faces of the wheels were sheared off the barrel for gods sake! Now tell me thats safe! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
| The Following 4 Users Say Thank You to ASSALBERT For This Useful Post: |
#37 |
Drives: 4Runner
I found this article to be pretty interesting:
http://custompinoyrides.com/2012/03/...f-rota-wheels/ not that it really matters. Haters are going to hate.
diirk
waiting on a Neptune Premium MT |
| The Following User Says Thank You to diirk For This Useful Post: | JoeBoxer (09-20-2012) |
#38 |
Drives: 2013 FR-S Ultramarine
Uh Oh, someone better notify GST that the Rota's they've been breaking records on in their Time Attack car are going to spontaneously explode if they don't switch them out!
![]() I too used to buy into the "Rota sucks" bandwagon. Yes, they had some QC issues YEARS ago. But in the last few years their wheels have been consistently well made pressure cast pieces. Are they the lightest wheels you'll ever find? No. But unless you're Colin McRae or the next Schumacher I doubt it's going to matter all that much. Just for kicks and giggles: ![]() So Lotus must have used Rota as their manufacturer I guess. I've seen pics of wheels from all different manufacturers broken. It happens.Me personally? I think a nice set of 1k of original design Enkeis or OZ's is a good compromise for us mortals. Nathan |
| The Following User Says Thank You to SubieNate For This Useful Post: | Propaganda (09-20-2012) |
#39 | ||
Drives: 1994 Toyota Tercel
These Motorsports apparently do fine with Rotas. Just curious why they use them when they have a rep of falling apart. Quote:
#40 |
My issue is not as much with the fact that they are cheaper wheels it is the fact that they are PURPOSELY trying to make them look exactly like another respected wheel. Try and design something on your own.
As a designer it really annoys me when people steal other peoples designs. Just because it is an idea or concept not a tangible item that does not make it ok to steal it. What really gets me is when people try to put the real wheels stickers and center caps in them to hide they bought cheap wheels. If all you care about is that they are affordable why go to the hassle of putting a different logo on them? It's funny, back in the day people used to rock fake wheels on the down low. Now kids seem proud to be rocking their fake wheels.
#41 | |
If he had the choice and cost wasnt an object would he still choose the knockoffs?This saying always rings true again and again. You get what you pay for. |
| The Following User Says Thank You to AJUSA.com For This Useful Post: | RAYSSPL (09-27-2012) |
#42 |
Drives: DC5
yea, i already know there are many teams out there that run rotas on their race cars. In my last post i was simply trying to convey that replica wheels have more catastrophic failures due to lack of QC or structural integrity compared to that of authentic wheels. The most you will usually see when a "brand name" wheel breaks is that a spoke or two have cracked, instead of the whole face of the wheel being torn off.
keep in mind the main issue at hand here is the blatant copy of designs, not to mention companies that try to pass off wheels as the real thing by supplying stickers, *cough* varrstoen *cough* and even konig was dumb enough to put "rays eng" "forged" "monoblock" stampings on their ce28n copy and still has them for sale.
| Fender Vents real or fake | KaliKev | Scion FR-S / Toyota 86 GT86 General Forum | 48 | 12-03-2011 02:24 PM |
| Subaru brz autobild article + Picture (maybe Fake) | aeon | BRZ Photos, Videos, Wallpapers, Gallery Forum | 5 | 10-31-2011 05:07 PM |
| FT-86 Article on Performance magazine | 4agze | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 01-09-2010 12:33 PM |
