View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 09-19-2012, 02:35 PM   #953
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Both BP & Sunoco have ethanol in their fuel. No chirps for me (yet).. :/
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 09-19-2012, 02:49 PM   #954
HunterGreene
Hail Magnet
HunterGreene's Avatar
Looking around the Cleveland area, there aren't any E0 stations within a decent driving distance
Old 09-19-2012, 04:09 PM   #955
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Sometimes it's there, sometimes it's not. I've ran 3 tanks without Ethanol, still got the "chirps" at the same frequency and randomness as with E10. With E10 (and E0) I would go entire trips/days with no chirping and then it was back the next day.
I don't think there's accurate or sufficient enough data to determine if ethanol has any part in it whatsoever. The same thing can be said of Octane level as chirping reports are made in Australia, the UK and Japan; all with "supposedly" better fuel.
I'm ready for someone, anyone to surmise a hypothesis regarding the chirping that isn't fuel related. It might be temperature related. I can more narrowly track the occasions on which it occur to temp then I can fuel type. It almost never happens when cold/startup/first days trip but almost always occurs after long driving and stop/go traffic.
Old 09-19-2012, 04:55 PM   #956
dsgerbc
Drives: BRZ(sold), STI
E0 Premium nearest to me is actually a 90-octane with some marine octane booster (and looking at the OH map this seems to be the picture near Cleveland as well). I'm not too sure it's safe for automotive cats.
Old 09-19-2012, 05:36 PM   #957
HunterGreene
Hail Magnet
Yeah, from what I have been told by my father (we sail regularly and we have both been on the water since we were children), marine fuel either has additives or doesnt that can harm the car. Secondly, most marine places won't let you fuel up your car at their pumps. Thirdly, its usually a markup of about a buck a gallon. I didn't count any places that said "marine" or anything like that on them.
Old 09-19-2012, 05:50 PM   #958
alrashwa
alrashwa's Avatar
Drives: '12 370Z Monterey Blue
In my own experience, had the chirps about 50 miles off the dealer's lot. It was hot, and the car was full of 10% ethanol 92 octane fuel. I continued to add the same fuel and hear the chirp for a few tanks. At one point I added 2-cycle oil, which silenced the sound for the remainder of that tank. The next tank I did not add any 2-cycle, and it still ran quiet for a day or so afterward, probably because of the residual 2-cycle. Chirping literally started sneaking back in quietly at first, then back to full volume by the end of the tank.
Next tank I used ethanol free 92 octane, marked explicitly so at the pump, and it has been silent ever since, on the second tank of ethanol free fuel. At least in my personal case, I've found a solution for this issue which I believe is fuel quality related. It may not be specifically the ethanol causing it, but I definitely think that ethanol as an additive is kind of a cheap way to water down gas, and is somehow causing the issue.
I hope they are working on a countermeasure mechanically for this issue. It's only a few dollars per tank for now, but it shouldn't be that way to begin with.
alrashwa is offline   Reply With Quote
The Following User Says Thank You to alrashwa For This Useful Post:
Sigh-on-Rice (09-19-2012)
Old 09-19-2012, 11:15 PM   #959
TennisHsu
TennisHsu's Avatar
Drives: 2013 Whiteout MT Scion FR-S
Originally Posted by tennishsu
9-800 miles w/ 10% ethanol gas= Chirps
801-3300 miles w/ ethanol free gas= zero Chirps
Was in a rush the other day and filled up with Shell 92 w/ 10% ethanol, chirps return in 10 minutes!
I was chirpless for the entire time using ethanol free gas, that is enough evidence for me to suggest ethanol is the main culprit here.
TennisHsu is offline   Reply With Quote
Old 09-19-2012, 11:29 PM   #960
smokeyFRS
smokeyFRS's Avatar
Drives: 2013 Scion FRS MT / Argento
I have posted this on page 39:
1. Take it in for an oil change. Had mine around 1100 miles and I have not heard it since.
2. Call Kearny Mesa Toyota/Scion and ask for Chuck - he's their Lead Technician. Toyota is working on this issue and soon will issue a TSB.
3. Here's a good site that you can check:
http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm
I have been using Chevron 91 after their initial tank of gas. Had the chirps all the way up to my first oil change. After the oil change, I have not heard since. Here in San Diego, we recently had a heat wave reaching 99 - 110 degrees and never heard a thing. Try an oil change if you have not done so.
smokeyFRS is offline   Reply With Quote
The Following User Says Thank You to smokeyFRS For This Useful Post:
rice_classic (09-20-2012)
Old 09-20-2012, 12:35 AM   #961
rice_classic
Already changed oil once and I'm on my 3rd oil filter.. 5200 miles on car.
Old 09-20-2012, 12:38 AM   #962
rice_classic
And that's absolutely fair which makes this diagnosis even more fun eh?
Because so many others don't have the same experience when using E0. If using E0 was the answer why would it not have the same affect on every other 86 that ran it (like mine)? The only conclusion that leads me to is that E0 isn't the answer which leads me then to conclude that E10 isn't the problem.
Old 09-20-2012, 07:49 PM   #963
dsgerbc
Been to a dealer. Complained about the chirping. Dealer called Subaru, and was told that there are tons of identical complaints and they are saying this is a normal DI sound. Nothing about potential TSB etc.
I started the case with SOA too, so when I get a follow-up call I'll push for replacement HPFP or at least get some next level rep and try to get some info.
Old 09-20-2012, 08:11 PM   #964
jeebus
That's crazy. I have owned 4 cars with direct injection. They all have made DI noise, clicking, tapping....none have chirped like this car. It ain't normal.
jeebus is offline   Reply With Quote
Old 09-20-2012, 08:43 PM   #965
dsgerbc
Oh I agree. Pretty short-sighted too.
The Following User Says Thank You to dsgerbc For This Useful Post:
jeebus (09-21-2012)
Old 09-20-2012, 11:36 PM   #966
jeebus
So I changed my oil today, since some have claimed it fixed the chirp. I used 0w20 Subaru synthetic and an OE Subaru filter. Drove around till car was warm. Chirpity chirp chirp chirp. Still sounds like a bird having a seizure.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
