Old 09-17-2012, 01:33 PM   #155
jamal
jamal's Avatar
Drives: Legacy GT
I use a press for one side and then an air hammer with a chisel bit for the other. You can't press them through and have to pry them out.
jamal is offline   Reply With Quote
Old 09-17-2012, 01:33 PM   #156
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
Originally Posted by ATL BRZ View Post
Have you been driving with the bad com-c's all week? If so, did the noises get progressively worse? On the fence about swapping the stockers back on at this point... If I drive carefully and consciously avoid bumps its not rattling, so on the highway it's ok for the most part.
Been driving on them for several weeks. I noticed them getting worse and worse, and then when I had it looked at by a local shop a couple weeks ago, they found some loose bolts while they had it up on the lift to see if they could figure it out without taking the wheels off. After they tightened everything, it got better, but it seems to be slowly becoming more frequent and louder again.
However, I don't have any issues on bumps that I've heard; it's only during turning (more than what you need for a lane change).
I'm also sitting on the upper inner bushings, was too scared and ran out of time before I had to head into work to do those myself. Trying to figure out when I can get into a garage to get some of the work done.. Have a few parts ready to install, and I only feel comfortable doing some of them myself.
Smudgeous is offline   Reply With Quote
Old 09-17-2012, 01:37 PM   #157
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
That doesn't sound like fun at all. The rear upper A arm looks like a bitch to remove too.
Old 09-17-2012, 04:30 PM   #158
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Thanks for posting that image and yes, I used a Gearwrench Pass thru socket, which allowed me to get a long allen wrench with a ratchet adapter to hold the shaft steady to remove the top nut.
The Gearwrench set and these:
are the most useful tools ever!!!
I've looked over 3 different diys/instructions and they don't include a step using these tools. Could someone explain for dummies exactly what tools are needed and at which step, why, etc.? Thanks.
For removing the top nut on the strut without the strut turning? Do you use this to torque on the nut too? And which size tools are needed? Thanks.
Phaedrus29 is offline   Reply With Quote
Old 09-17-2012, 04:36 PM   #159
ATL BRZ
ATL BRZ's Avatar
I think I only used those flexy wrenches for the nuts that secure the top mounts to the car. To remove the top nut on the strut I used the Gearwrench and allen key with ratchet adapter. The RCE instructions posted in this thread tell you which sizes are needed.
Old 09-17-2012, 07:55 PM   #160
Duo
Drives: 86 pending move
Looks good!
You could have gone with quite a bit more camber up front, but overall your alignment is solid.
- drew
What's the max camber you can get from the Comp C's?
Motorsports: Because basketball, baseball, and football only require one ball.
Duo is offline   Reply With Quote
Old 09-17-2012, 07:56 PM   #161
I think we're running -2.3, but I'm not sure if that's maxed out. It should be close to around there.
- Andrew
Old 09-17-2012, 08:44 PM   #162
Calum
That Guy
Drives: 2013 asphalt FRS MT
I just read through the instructions, this is my first disappointment with this car. On every other car I've gotten away with using a spark plug socket. Oh well, looks like I've got a new tool to add to my Christmas list.
Old 09-18-2012, 02:08 AM   #163
Phaedrus29
Phaedrus29's Avatar
I found pics of the "Gearratchet" being used on the top of the strut here:
http://www.ft86club.com/forums/showp...1&postcount=50
I'm still a bit unclear on how you torque the top nut back on afterwards with a torque wrench. Do you not need to worry about the allen key when you are tightening the top nut?
Old 09-18-2012, 09:51 AM   #164
ATL BRZ
ATL BRZ's Avatar
So I spoke too soon about the Whiteline Com-C's not making any noises while turning. Today I drove to work on city streets and alongside the horrible rattling over the slightest bumps, the Com-C's are making a loud, crisp POP noise when turning. This is embarrassing. I don't think I can wait until WL ships me new ones. I may drive back to the shop and swap my stock top mounts back on.
Old 09-18-2012, 10:05 AM   #165
Smudgeous
Smudgeous's Avatar
So I spoke too soon about the Whiteline Com-C's not making any noises while turning. Today I drove to work on city streets and alongside the horrible rattling over the slightest bumps, the Com-C's are making a loud, crisp POP noise when turning. This is horrible. I don't think I can wait until WL ships me new ones. I may drive back to the shop and swap my stock top mounts back on.
Are you sure you tightened the bolts with the allen key enough? When I was doing the install, I hadn't noticed the allen keys and had just tightened it with a normal bolt until I couldn't tighten it anymore. The result was that the struts had give to them with only applying like 20lbs of force. When that happened, I creaked over any uneven surfaces, even on straight roads. Once I tightened them with the allen key + boxwrench combination those creaks went away (of course I took everything back apart before realizing I could have tightened just by removing the dust caps as it was already installed :P)
Old 09-18-2012, 10:09 AM   #166
ATL BRZ
ATL BRZ's Avatar
Yes, tightened them while using a spring compressor when reassembling while off the car, then double checked when they were on the car, then triple checked after driving on them.
Maybe they are too tight? Not enough clearance between the top mount and the black spring cap?? How are you guys judging torque on that top nut?
Old 09-18-2012, 10:46 AM   #167
We're disappointed with the quality of the Whiteline Com C top mounts. Did not expect this at all but we're glad that they are replacing them for customers. In the meantime we're not going to be selling them until it's sorted out.
As always please feel free to call us with any questions or concerns.
- Andrew
Old 09-18-2012, 12:01 PM   #168
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Has Whiteline gotten back to you guys on what their action will be? I contacted them 2 weeks ago but they never called me back.
mechaghost is offline   Reply With Quote
White n' Yellow. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 08-02-2015 04:01 AM
Yellow fog tint looks awesome! DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 37 11-07-2012 03:40 AM
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 08:12 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
FT86s at Megaweb (more footage of the yellow 86) ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 05-26-2012 02:08 PM
