#29 |
Drives: 2017 Subaru BRZ PP
I can kind of understand with all wheel drive. But I would think with a car like this with not so much rear grip that the tires would usually slip/wear first.
Toyota + Subaru =
#30 |
Reverse Burnouts
Drives: 2013 Argento FRS
if you glaze the clutch over before 200 miles, its only a matter of time before the clutch goes, it could have been damage at port if someone hooned in it
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#31 | |
WUB WUB
Drives: 2013 Firestorm
i also blew up the transmission. literally. it exploded. there were only little metal chunks left of 2nd gear. damn i was stupid |
| The Following User Says Thank You to wrxgoose For This Useful Post: | czar07 (09-16-2012) |
#32 |
Drives: 13 whiteout scion frs
first manuel and up to 3k. mayb just luck
#33 |
Drives: 2013 FR-S Hot Lava
Ok, this thread scares me a bit.
The FR-S is my first manual car although I've been riding motorycles for a good few years now. When I'm sitting at a stop light on a incline, I keep the clutch partially engaged to prevent me from rolling backwards. This has always worked for me on a bike and I never use brakes on a hill. Is this bad for clutch break in?
Live to drive another day
#34 |
Drives: 2012 honda civic ex
yesss! absolutely! clutch will heat up,and wear prematurely!
always ''engage" your emergency brake,while shifting to neutral to hold the car still on the grade,then when the light turns green,release the emergency brake,while "at the same time" shift into first,while letting up on the clutch pedal to go forward,WITHOUT rolling back.this is NOT difficult,just requires practice until you get it right the objective is to NOT roll back...just sayin' |
#35 | |
Drives: BRZ Sport Tech 6sp
Someone else chime in if wrong. |
#36 |
Scrape Master
Drives: Goal: Oldest FRS State Side
yes you are correct.
#37 | |
Drives: Supercharged Golf Cart
What a bafoon! He hasn't even replaced the window, now he's got much bigger problems. HA-ha!
IMO, if a clutch is too soft it's harder to shift smoothly because there is no feedback. It's like a surgeon performing delicate surgery with his arm hovering in the air versus resting on a table for balance. The balanced hand will be infinitely more careful and easy to be precise with the movements. |
#38 | |
Drives: 2018 Golf R
Stop that. Stop that right now. Sent via telepathy
Parting out HERE
| The Following User Says Thank You to civicdrivr For This Useful Post: | czar07 (09-16-2012) |
#39 |
^ Ok, thanks for the replies guys. Good thing I've been avoiding hills in my first 250 miles so far.
#40 |
Drives: nissan frontier, DGM MT BRZ
ok guys i let my clutch out slowly and i kinda get a little jerk half way of letting it out in first. i would say i let it out half way then add a little more gas then let it out faster. am i destroying my clutch?
EDIT:btw i never smell clutch burning clutch. |
#41 |
Drives: 13 White MT FR-S
My first car was a 5spd 1990 Nissan Stanza, I attempted (and succeeded) to start the car in forward motion with 5th gear. No smoke, but the car smelled extremely bad. That was at like 190,000 miles, and lasted to 230.
#42 | |
Scrape Master
| 5k~ Miles - Clutch with extreme broken glass noise | Pscylo | Issues | Warranty | Recalls / TSB | 11 | 08-30-2012 02:12 AM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 01:22 PM |
| Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 | Redline360 | Transmission and Driveline | 2 | 07-30-2012 11:01 AM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 01:06 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 04:48 PM |
