Old 09-16-2012, 09:24 PM   #29
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by wrxgoose View Post
when i had my WRX (first owned/driven manual) i went through my first clutch in 1300 miles
I can kind of understand with all wheel drive. But I would think with a car like this with not so much rear grip that the tires would usually slip/wear first.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 09-16-2012, 09:29 PM   #30
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by Bonburner View Post
So I dropped by my happy dealership - power cerritos - and I had a quick chat with my salesman, apparently some guy with a white FR-S blew out his clutch in 700.
I asked him how and he said he wasn't sure, wondering if anybody around here got any news on this ~
if you glaze the clutch over before 200 miles, its only a matter of time before the clutch goes, it could have been damage at port if someone hooned in it
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 09-16-2012, 09:31 PM   #31
wrxgoose
WUB WUB
Drives: 2013 Firestorm
i also blew up the transmission. literally. it exploded. there were only little metal chunks left of 2nd gear. damn i was stupid
wrxgoose is offline   Reply With Quote
The Following User Says Thank You to wrxgoose For This Useful Post:
czar07 (09-16-2012)
Old 09-16-2012, 09:35 PM   #32
_F-R-S_
Drives: 13 whiteout scion frs
first manuel and up to 3k. mayb just luck
_F-R-S_ is offline   Reply With Quote
Old 09-16-2012, 11:05 PM   #33
whtchocla7e
Drives: 2013 FR-S Hot Lava
Ok, this thread scares me a bit.
The FR-S is my first manual car although I've been riding motorycles for a good few years now.
When I'm sitting at a stop light on a incline, I keep the clutch partially engaged to prevent me from rolling backwards. This has always worked for me on a bike and I never use brakes on a hill. Is this bad for clutch break in?
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 09-16-2012, 11:17 PM   #34
jmaryt
Drives: 2012 honda civic ex
yesss! absolutely! clutch will heat up,and wear prematurely!
always ''engage" your emergency brake,while shifting to neutral to hold the car still on the grade,then when the light turns green,release the emergency brake,while "at the same time" shift into first,while letting up on the clutch pedal to go forward,WITHOUT rolling back.this is NOT difficult,just requires practice until you get it right the objective is to NOT roll back...just sayin'
jmaryt is offline   Reply With Quote
Old 09-16-2012, 11:18 PM   #35
KingRohan
Drives: BRZ Sport Tech 6sp
All I know from what I've learned that it's considered riding the clutch on a car. But on a bikes it's ok because our clutch is always in oil being lubricated.
Someone else chime in if wrong.
KingRohan is offline   Reply With Quote
Old 09-16-2012, 11:28 PM   #36
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
yes you are correct.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 09-16-2012, 11:29 PM   #37
fistpoint
Drives: Supercharged Golf Cart
Originally Posted by b.e View Post
What a bafoon! He hasn't even replaced the window, now he's got much bigger problems. HA-ha!
Originally Posted by WolfsFang View Post
Im guessing he did not know how to drive stick. Which is sad because it is so easy learning to drive stick in this car, it has the softest clutch ever!
People keep saying this, but when I sat in one(finally a manual) at the dealership, it didn't feel "too" soft at all. Softer than my 4th, 5th, 6th gen Civics and current RSX yes, but not soft when compared to the Scion tC or 2012 Civic Si. Both of which have the most pathetically uninspiring and "in the middle of having a stroke" grandma-soft clutches I have ever had the displeasure of using.
IMO, if a clutch is too soft it's harder to shift smoothly because there is no feedback. It's like a surgeon performing delicate surgery with his arm hovering in the air versus resting on a table for balance. The balanced hand will be infinitely more careful and easy to be precise with the movements.
fistpoint is offline   Reply With Quote
Old 09-16-2012, 11:29 PM   #38
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
This is the equivalent of driving down the highway at 80mph while simultaneously dragging the brakes for miles on end.
Stop that. Stop that right now.
Sent via telepathy
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
czar07 (09-16-2012)
Old 09-16-2012, 11:31 PM   #39
whtchocla7e
^ Ok, thanks for the replies guys. Good thing I've been avoiding hills in my first 250 miles so far.
Old 09-16-2012, 11:32 PM   #40
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
ok guys i let my clutch out slowly and i kinda get a little jerk half way of letting it out in first. i would say i let it out half way then add a little more gas then let it out faster. am i destroying my clutch?
EDIT:btw i never smell clutch burning clutch.
Lee358 is offline   Reply With Quote
Old 09-16-2012, 11:36 PM   #41
ML
ML's Avatar
Drives: 13 White MT FR-S
My first car was a 5spd 1990 Nissan Stanza, I attempted (and succeeded) to start the car in forward motion with 5th gear. No smoke, but the car smelled extremely bad. That was at like 190,000 miles, and lasted to 230.
Old 09-16-2012, 11:38 PM   #42
WolfsFang
Scrape Master
WolfsFang's Avatar
hmm maybe its because i used a ACT XTSS (SS lines) clutch on my evo 8 before i owned this car. Also i let my friend drive the car and he DD's a stock civic si (09 i think) and says the clutch is super soft. I guess im not use to stock clutch feel since the 2 cars i owned before this one had stiff aftermarket clutches on them.
5k~ Miles - Clutch with extreme broken glass noise Pscylo Issues | Warranty | Recalls / TSB 11 08-30-2012 02:12 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 11:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
