Old 09-13-2012, 12:41 PM   #295
gmookher
I want some of what he is smokin..
Old 09-13-2012, 12:46 PM   #296
Yruyur
Yruyur's Avatar
Originally Posted by jesperswe View Post
Is this a reliable source, even if i got a Toyota it gotta be the same software? If that can be 100% confirmed i'll take my car back from the workshop before they rip her apart.
Not really sure thought if i'd enjoy driving with a crappy idle....
Can it all just be to bad programming in the ECU/ECM regarding the VVT part? We all know computers crash for no obvious reason
Could be possible also seeing some posts where they just changed the cam sprocket and ocv, and still got error code.
When they changed the ECM everything worked out? Maybe there's a new software in the new ECM?
They swapped out my hard parts and still the same issue. It was not until they gave me the newer ecu part number that the problem was resolved. Visconti confirmed it had a newer factory flash that had not seen and that he was going to have to retune for me. My fix was 3000 miles ago and doing good.
Old 09-13-2012, 12:47 PM   #297
pituala
Mr. Know It All
Drives: 2013 FR-S Asphalt
Me too!!! :P
2013 FR-S Asphalt MT (55w HID's)
1985 Celica Supra 1JZ (Stupid Fast)
pituala is offline   Reply With Quote
Old 09-13-2012, 12:51 PM   #298
mact
Drives: 13 GTI
Do you have the part number of the new ECU handy? I want to check mine.
mact is offline   Reply With Quote
Old 09-13-2012, 12:52 PM   #299
Yruyur
Yruyur's Avatar
It ended in 811 instead of 810
Old 09-13-2012, 01:08 PM   #300
01s0uljah
Drives: SWP Subaru BRZ Sport-Tech 6AT
I would take it back and drive it with the CEL/TRAC for now until the flash becomes available.
Ask them to call the tech line at Corporate and they'll probably give you the answers. I wouldn't have the mechanics taking apart crap and replacing something thats resolved with a software fix.
01s0uljah is offline   Reply With Quote
Old 09-13-2012, 01:32 PM   #301
KingRohan
Drives: BRZ Sport Tech 6sp
Originally Posted by 01s0uljah View Post
Was just informed by my dealership and a tech at Subaru canada that a software flash will be available at the end of the month to resolve the CEL/Trac light issue.
Finally some sort of info, with a timeline!!
Thanks for sharing 01s0uljah
KingRohan is offline   Reply With Quote
Old 09-13-2012, 02:27 PM   #302
jesperswe
Drives: GT86
Damnit i don't know what to do, it doesn't feel good driving around missfiring and idle crap but also i dont want the car to stay at the dealer untill end of september
jesperswe is offline   Reply With Quote
Old 09-13-2012, 02:35 PM   #303
gmookher
Drive it. Break it. They WILL fix it, its bad PR if they dont.
Old 09-13-2012, 03:07 PM   #304
01s0uljah
Thats what I'm sayin'
Old 09-13-2012, 03:35 PM   #305
pituala
Mr. Know It All
So Scion headquarters just called me. They didn't really say anything that filled me with confidence. They asked what I expected. I said I expect to get my car back working correctly in new condition without the smells of oil or coolant, and I don't want to have a repeat of this problem. He asked me if they could do anything else for me like make my next payment or extended warranty. I said I would like dealer installed foglights, a rear spoiler, and an extended warranty. He said they would take care of me.
I also just spoke with the service writer at Toyota and he told me 3-4 weeks backorder on the parts they ordered for me, but he wouldn't tell me what they ordered. I just hope the 811 ECU is in that order!!!
Old 09-13-2012, 03:57 PM   #306
RossGA
Drives: Audi S4
I understand your point there, but you could be doing longterm damage that may not show up for a few years (like after a warranty period).
Audi should have recalled the 2004-2006 S4 due to bad cam adjusters on the intake VVT. They quietly ignored the issue, and most S4s of those years need major engine repairs by 75K, and many are simply ruined and need to be replaced...conveniently after the warranty has expired. My 2004 S4 was an absolute nightmare the last 1-2 years of ownership. As soon as it hit 65K, it was all downhill....primarily out of bad intake VVT components causing a chain of issues.
The long list of problems is from bad cats (from shooting raw fuel into them due to misfires), scored cylinder walls (due to other contributing issues, but misfires add by allowing unburnt fuel to cause oil dilution), a myriad of timing chain/adjuster/tensioner problems, grenaded motors, power loss, and 5 figure repair bills. The BHF 4.2L V8 in that car lists from Audi at $13K; if you have to replace it.
If it were me, I would drive it *sparingly* with a running misfire problem until it gets fixed; assuming you plan on keeping it beyond 50-60K. High compression motors and misfires create a toxic mix for the oil. The effects of which may not show up for a few years, but in an all aluminum motor....they will most likely show up if there has been any lubrication impacts..... If you must drive it daily, I would routinely check the oil to see if it smells strongly of raw fuel. If so, change it or get it changed.
My $0.02
RossGA is offline   Reply With Quote
Old 09-13-2012, 04:13 PM   #307
pituala
Mr. Know It All
My $0.02
Couldn't have said it better myself!
Old 09-13-2012, 04:21 PM   #308
gmookher
your two cents are worth alot
all good points, on the conservative side
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
