Tire Destroyer
Drives: Firestorm+snail
Installation cost for a crank pulley?
I'm a noob when it comes to installing aftermarket items, so I'd rather leave it to the experts. Is 70$ a reasonable price for the labor? It seems fast and easy to install from the tutorials...
#3 |
Drives: '13 GBS Subaru BRZ
Yes, and no. It's a really quick and easy job, but the simple fact is whenever you have someone else do the work ther is going to be a minimum charge which this probably falls under.
#4 |
Drives: 2014 Widebody Cosworth FR-S
A lot of shops have a 1 hour minimum and $70/hr seems to be a fairly average rate. Seems decent to me.
-Zach |
#5 |
Drives: Firestorm FR-S
If you are planning to add aftermarket parts to your car you better learn to do the work yourself or it will get insanely costly. You need to start somewhere and the pulley is stupid easy, check the DIY section as I am pretty sure there is a write up.
#6 |
Drives: 86
find someone in your area who has done the mod. if i lived nearby id do it for ya for just 10 bucks or free food or something. i'm sure someone in your area would do the same.
#7 |
Drives: 2013 Scion FR-S MT Raven
If you don't have the tools (Breaker bar, torque wrench, sockets and screw drivers) then buying these to do it yourself can easily run more than $70. If you plan to do other aftermarket stuff it's worth the investment to get your own tools and learn your car. Take the opportunity to learn and enjoy it.
#9 | |
Drives: 2013 Raven FR-S
#10 |
Drives: FRS with 2jz, 2015 STI 9.68@147
If its an auto I would recommend a shop doing it for you as its not easy to get it off (you need to lock the flex plate) if its stick its not too bad. We charge about 50 for the install and free if you buy the pulley from us.
| The Following User Says Thank You to PrimeMotoring For This Useful Post: | StarsGarrador (09-12-2012) |
#11 |
#12 |
Drives: 2013 Asphalt FR-S
Man, I was lucky enough to get it done for free from a local shop right down the road from my house. But yes, I really took about 15-20 minutes, so I don't see it costing too much.
#13 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I am not mechanically inclined. Never even did an oil change. I installed my pulley no problem.
It built some confidence in me for sure. I'm looking forward to installing more mods. I'd rather do the mechanical stuff than electrical.
#14 |
You can also use a crank pulley tool. That's what I did, and it makes the job easier on a MT as well. Well worth the $50 I paid for the tool.
| The Following User Says Thank You to neutron256 For This Useful Post: | ATL BRZ (09-19-2013) |
| Aftermarket Crank Pulley Install | Enigmus | DIY (Do-It-Yourself) Guides | 305 | 02-04-2019 11:37 PM |
| Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 06:45 PM |
| Perrin/Brand 'Y' Crank Pulley ? | rikdrt1 | Engine, Exhaust, Transmission | 1 | 09-10-2012 04:39 PM |
| Crank Pulley and the warranty | Brimford | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-08-2012 03:47 PM |
