| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
decided: keep steel for now! save up for rays or kics
#16 | |
Vtec Jesus
#17 |
Ontario's FT86
Drives: 2016 Lexus GS-F
what I know is muteki are made in china and RAYS are made in japan, but if cost is a factor then I would buy muteki by all means
#18 | |
Vtec Jesus
http://www.mackin-ind.com/?page_id=2165 Educate yourself before posting again. Every thing you say is wrong. |
#19 |
Drives: bicycle
It's true that you shouldn't use an impact gun on these lightweight aluminum lugs as they fatigue and deteriorate quickly.
I am using forged aluminum lug nuts from 949racing for my Mr2 Spyder. They're amazing. http://949racing.com/forged-alloy-lugs-black-12x15.aspx
#20 | |
Drives: bicycle
| The Following User Says Thank You to RAYSSPL For This Useful Post: | TouchMyHonda (09-11-2012) |
#21 | |
Ontario's FT86
#23 | |
Vtec Jesus
You are going in circles and creating contradictions for yourself. I'm done letting you embarrassed your self further. It's all on you now. I will no be responsible for feeding you more ways to prove you have no idea about this. |
#24 | |
Ontario's FT86
And plus you are contradicting yourself too, you first said they are all made in the same place, and now since I proved to you mutekis are made in taiwan and you are assuming what i said is right lol |
#25 |
Drives: Rx7
Guys:
We sell tons of the Muteki, RAYS, WORK, WEDS, KICS etc. All the anodized color lug nuts chip and color fade away regardless of the brand. Never use impact gun, always use torque wrench. Aluminum lug nuts are lighter, but also softer. Ur studs are steel, so if not use carefully, the aluminum lug nuts will get destroy. KICS made chromely steel lug nuts which was the R26, and R40 series. They are a bit heavier than the Aluminum version but because it's chromely steel, it's stronger as well. If use properly, most of these lug nuts are safe. I had used every single brand for the past ten years, the most common problem is the color fading out and chipping off regardless of the brand. Last edited by RavSpec; 09-11-2012 at 01:58 PM. |
| The Following User Says Thank You to RavSpec For This Useful Post: | gmookher (09-11-2012) |
#26 |
Drives: Rx7
I have some OEM lug nuts from the BRZ and also a set of OEM wheels from the BRZ. It looks like the tapered wasn't enough to use any of these aftermarket lug nuts. So you might not get enough thread to use aftermarket 60 degree tapered lug nuts on the stock wheels.
Mark |
#27 | |
Vtec Jesus
I simply informed you that you are basically claiming that mutekis are crap... when they are made the the same factory as rays engineering under that same manufacture plant designed both by the same engineers. You clearly didn't know you were bashing one brand with another brand... when they are both the same brand. HA ![]()
#28 |
Vtec Jesus
| Black Chromed Accents and Emblems for SWP | ScottDRFT | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-21-2014 03:17 PM |
| Chromed out FT? | KritiK | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 09-30-2012 02:01 PM |
| Why no aluminum??? | epson1 | Engine, Exhaust, Transmission | 41 | 08-01-2012 02:18 PM |
| Steel Vs Aluminum in the FT86 | blur | Scion FR-S / Toyota 86 GT86 General Forum | 72 | 06-08-2011 04:35 AM |
