View Poll Results: Are you experiencing the same problem?
Yes - I have an aftermarket intake only. 14 9.21%
Yes - I have an aftermarket intake and a tune. 15 9.87%
Yes - I'm all stock. 11 7.24%
No - I have an aftermarket intake only. 43 28.29%
No - I have an aftermarket intake and a tune. 3 1.97%
No - I'm all stock. 66 43.42%
Voters: 152. You may not vote on this poll
Old 09-11-2012, 12:14 PM   #211
Visconti
Drives: 05 STi
I'll have a intake and hope to test it out tomorrow or Thursday
Visconti is offline   Reply With Quote
Old 09-11-2012, 12:18 PM   #212
2forme
Originally Posted by Sargy View Post
Make that 7 now
Interestingly, After 2,500 quick Miles after a 3 week ownership, I did a 1-5 Pull on the freeway one empty night and it started.
Cant wait to have money to buy my solution, John
Are you experiencing the same thing I was? Also was it with stock intake or aftermarket intake?
Old 09-11-2012, 12:28 PM   #213
Sargy
Long Distance Driver
Sargy's Avatar
Like the quote said, I am 100% stock. Didn't do anything hard driving until that one night.
It isn't as dramatic as yours in those videos, but I can compare it not being able to move at all in 6th gear and having hesitation with getting it to move between 2-3k rpm in all other gears. very noticeable and surprised me.
Sargy is offline   Reply With Quote
Old 09-11-2012, 12:30 PM   #214
Sargy
Sargy's Avatar
plus I have not done the first oil change yet, it was in 60 degree cool night weather and I had the heat on full blast during that run. It was fun though
currently the battery has been disconnected for the last 2 hours maf unplugged. going to hook everything back up shortly.
Old 09-11-2012, 12:48 PM   #215
2forme
Interesting, I've never had an issue stock. I'm actually back to stock intake now, well, minus the snorkel.
Old 09-11-2012, 01:02 PM   #216
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
It happened to my daughter twice now, both times at slow speed leaving a parking lot, weird.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-11-2012, 01:27 PM   #217
Visconti
Drives: 05 STi
Will send update shortly
John
Old 09-11-2012, 01:31 PM   #218
gmookher
why minus snorkel?
Old 09-11-2012, 01:33 PM   #219
tonystewart
John
No rush or worries John, please attend to your testing of the airaid intake and other more pressing matters, this can wait, she's learning how to avoid it.
Old 09-11-2012, 01:35 PM   #220
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by gmookher View Post
why minus snorkel?
Probably because he removed it for his previous CAI, and it's a pain in the ass to put back. Plus he's getting a different CAI anyway.
Old 09-11-2012, 02:02 PM   #221
Keith@AIRAID
Drives: 51 Kaiser, 97 4Runner, 07 Civic Si
Just to clarify, was Visconti able to write a tune that works with aftermarket intakes?
Keith@AIRAID is offline   Reply With Quote
The Following User Says Thank You to Keith@AIRAID For This Useful Post:
ATL BRZ (09-11-2012)
Old 09-11-2012, 02:40 PM   #222
2forme
This.
Old 09-11-2012, 02:45 PM   #223
Sargy
Sargy's Avatar
Well that was a process,
So here are the steps I did to have a normal stock feeling again.
Just to recap, I am 100% stock and had a bog/hesitation issue with my car after doing a 1-5 pull on a calm, cool night for the first time. 2,500 miles on ODO same factory oil.
PART 1:
-unhook battery and MAF sensor
-keep car in a cool area
-return to car after 2 hours
-Hook up battery
-without MAF plugged in, start you car. let it run until it idles at its stock rpm of around 600rpm and enjoy that Richness smell!(i think)
-once warmed up and idled, turn off the car, plug in the MAF sensor, start car again and wait for idle.
-Turn off car, unhook battery and wait one minute
-Hook battery on the car, verify your tools, plugs, etc is all in order. Set your G mode/S mode/ Rev limiter, stereo settings and start the car. PROCEED TO PART 2
PART 2:
-Once you have completed Part 1, begin to think about where to go because this process takes 40 miles. 20 There, 20 back. the 2nd half wont be long
-Begin your drive EFFICIENTLY and keep rpm below 2,000 RPM and below 45 mph.
-After 20 miles, pull over/stop and realize how well you have driven
-on your 20 miles trip back, it begins. bring 1st gear up to 2k rpm, 2nd gear up to 3k, 3rd up to 4k, and 4th until you see a red blinking light (CHANGE GEAR!!!)
-Stop and realize the grin on your face. test out all the gears and celebrate:happy0180:
Now, I know someone has mentioned this already. just wanted to share my experience and the steps I have Done to make this work out. would love to see stock cars with intakes try this or any other stockers, but to each their own. This worked for me.
The Following User Says Thank You to Sargy For This Useful Post:
AJUSA.com (09-11-2012)
Old 09-11-2012, 03:34 PM   #224
gmookher
PART 1:
-Hook up battery
PART 2:
where are you getting this procedure from?
The Following User Says Thank You to gmookher For This Useful Post:
Nitro22 (09-22-2012)
engine bogging, hesitation, intake, jerking motion
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 09:06 PM
aftermarket rubber intake tubing??? 20valvewynn83 Southern California 39 09-14-2012 12:12 AM
Can anyone read Dutch? Buggy51 BRZ First-Gen (2012+) — General Topics 14 12-28-2011 10:48 PM
Toyota READ THIS Mr.Jay Off-Topic Lounge [WARNING: NO POLITICS] 1 12-09-2011 01:13 AM
