Old 08-25-2012, 05:29 PM   #729
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
Not isf motors but ej motors. We can sti our 86s
driftartist is offline   Reply With Quote
Old 08-26-2012, 10:22 AM   #730
azburnin
azburnin's Avatar
Drives: 2013 Raven FR-S
Probably cheaper too lol.
azburnin is offline   Reply With Quote
The Following User Says Thank You to azburnin For This Useful Post:
driftartist (08-28-2012)
Old 08-26-2012, 11:00 AM   #731
computertech01
Drives: Jetta MK1V
Ok so let me explain my situation before I throw out my problem. I'm new to driving a six speed as my dd before I would drive my brothers integra 5mt from time to time and I got down driving with a stick. Now I never felt like I had to rev the car when I'm shifting into first driving his old car but If I don't rev it to at least 2k (i'll test these numbers more tomorrow) shifting into first from a standing position the engine bogs down. When it does this either I end up stalling or the traction control light comes on and the engine makes this horrible noise like its knocking then kicks in like its normal.
Also my car normally idles at 500-400.
Just got back from driving it a little more trying to recreate this issue and I've smoothed it out a bit. If you almost stall it from standing it makes this horrible noise then a surge of power.
Something interesting I noticed was the fact that my car idled higher at 700+ when the ac was on but when I turned it off it dipped back to 500-600. What should our cars be idling at?
I keep thinking of things to add.... I forgot to specify that I'm at 300miles and just added some 93, was still running off dealer gas.
computertech01 is offline   Reply With Quote
Old 08-26-2012, 04:30 PM   #732
White64Goat
If you wonder what parts are being replaced, go here http://www.ft86club.com/forums/showthread.php?t=8374 and go to the engine service PDF and go to pages EM10 through EM25 and you will see what they are replacing and what has to come apart to do the repair.
The Following User Says Thank You to White64Goat For This Useful Post:
azburnin (08-26-2012)
Old 08-28-2012, 11:21 PM   #733
baadshah
Drives: premium silver
I bumped into the warranty section for the first time. Looking at these issued I am worried I am having the same problem. I dont have CEL, but once a while my engine shudders while I press on the clutch(no load condition) and shift from 1st to 2nd. My guess is this is happening only in manual. Auto never go into no load condition except for low/high idle. Some engines have problems at no load conditions (infamous return to idle).
I work on engine controls and I can say idle is definitely bad. That idle performance is not acceptable for a DI engine
Loss of power with CEL is a bad omen. Power derate with a fault code signifies major component failure. Derate is imposed only when the engine thinks that is bound to knock or misfire without this component and hence limits itself in the power map.
I dont think this problem would be solved with parts unless it popped up because of error in the manufacturing line. Sounds like toybaru should release a software patch.
baadshah is offline   Reply With Quote
The Following User Says Thank You to baadshah For This Useful Post:
Marrk (08-29-2012)
Old 08-29-2012, 04:08 PM   #734
governor
Drives: 2013 FR-S Navy Blue
Had this problem yesterday.
Took my FR-S to the dealership this morning, 6MT, 2069 km of mileage. CEL and Traction lights on. Engine almost stalls on idle (esp. noticeable at red lights) after a few minutes of driving. Once the shuddering was so bad I looked around the car to see if someone outside was physically rocking the car..
After their inspection and reproduction of the problems, the mechanic talked to Scion Canada and they decided they are going to replace the oil control valve (I assume an error code points to this being faulty). This is the first time I have heard of a faulty oil control valve, and apparently it isn't a cheap part either (~1700$). So now I have to wait 4-5 weeks for a part that I am not certain will resolve the issue (based on what I have read so far about this problem cam, ECU etc.).
Other problems I am having:
- Launching in 2 Gear. Around ~2500 rpm in second gear the car will lurch forward as it accelerates (slow release of clutch). Service rep thinks that it may be related to oil control valve, but since I never have this behavior in any other gear at similar rpm I am skeptical - but I don't know how the controls are set up on the vehicle.
- Buzzing noise from rear. Didn't really determine which one it is, so it'll have to wait until I get the car back. They will keep it until its fixed.
governor is offline   Reply With Quote
The Following User Says Thank You to governor For This Useful Post:
Marrk (08-29-2012)
Old 08-30-2012, 12:18 PM   #735
Skye
Drives: TR2,CooperS,BRZ
If this is an actuator problem how hard is to change an actuator?
Skye is offline   Reply With Quote
Old 09-01-2012, 01:12 AM   #736
governor
I had the same experience. Car would feel like it would nearly stall for the first 500-1000km if it wasn't at least 2000-2500 when starting to release the clutch (which was strange since I was advised to break in the engine for 1500 km below 3000 rpm). As I worked on breaking-in the engine, this ended up dropping and got to a point where I could even start releasing the clutch around 1k rpm and barely notice rpm dip (pretty much from high-idle).
Unfortunately for me, it seems that the more the engine started to like the lower rpms, the worse the idle became and eventually CEL and SL came on. Just wait till you feel like someone is rocking the boat when you are sitting at a red light, quite the WTF moment. Just remember to apply the gas when it happens to reduce the severity and eliminate the shudder. (Actually, there is no guarantee this will happen to you.)
Old 09-02-2012, 10:58 AM   #737
White64Goat
Skye, read and follow link in #734 above.
Old 09-06-2012, 02:33 PM   #738
azburnin
azburnin's Avatar
Has Anyone else found out from the dealer of what is actually causing this yet? I know a lot of you guys have had your cars in the shop for a while now. Any Word?
Old 09-06-2012, 03:53 PM   #739
sa1126
Drives: n/a
This. I am having the idle issue without the CEL or traction light and never thought anything of it. Should I take the car in?
Raven MT as of 07-09-2012
'01 Taco prerunner
sa1126 is offline   Reply With Quote
Old 09-08-2012, 09:23 AM   #740
azburnin
azburnin's Avatar
Same thing is happening to me. I've taken it in, they told me they couldn't find anything coming up when they ran a check on it. Nor could they recreate it. If yours is more persistent then mine. Yes. It wont hurt to take it in, the more people bring this to toyotas, subaru's attention the fast there will be a remedy. Respectively.
Old 09-12-2012, 05:33 PM   #741
Ericbdrummin
Drives: Scion FR-S
My car originally had a bad idle, intense shaking,etc, without the CEL coming on.
After about 3 or 4 instances of that all the lights came on.
Go get it checked !!!!
Ericbdrummin is offline   Reply With Quote
Old 09-12-2012, 06:38 PM   #742
Hammer
Drives: BMW 335i, FJ cruiser
So I finally decided to call SOA yesterday because I was tired of waiting for my dealer to find out when parts for my car will arrive. Explained to the rep that I took delivery on 8/19, had the car for a total of 3 days (4 driving hrs.), and that I wanted to know what was going on with the parts on order. Rep says she will get back to me by Thursday. Today, I got a call from someone higher up in subaru informing me that the part on order will be to my dealer by Friday. I explained to him my situation and the guy says once they are finished fixing my car and everything is to my satisfaction that we can talk about compensation possibly including getting a payment made on the month I lost. So I have to say, if you are in the same situation as I am, you might want to think about giving SOA a call.
Hammer is offline   Reply With Quote
The Following 2 Users Say Thank You to Hammer For This Useful Post:
azburnin (09-13-2012), Marrk (09-12-2012)
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-28-2012 11:38 PM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 01:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 12:53 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 12:32 PM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge [WARNING: NO POLITICS] 32 05-09-2011 12:58 AM
