#71 |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I am not sure if I am following anything you guys are talkin about. I know in my celica I seem to have better power after I reset my ecu, then over time it would seem as it was boging down a little. I don't know if I recall this correctly, but don't know of anybody successfully reprogramming the stock computer. And most piggyback computers were just very minimal successful. Real tunes were from stand alone computers.
#72 | |
There are two modes where timing is dynamically changed, and when you reset the ECU it goes into a different correction mode than the long term one. It also sets an initial advance multiplier value which is not 0. It may actually be higher initially than what your car ends up after driving for some time. By default it is set to half of its maximum on all of the other ECUs, John said it is set to .7 initially on the BRZ with a max of 1. There are some fairly convoluted steps Subaru guys go through in order to get the IAM value set as high as possible right after the ECU reset. It's possible at some point during your driving you have encountered some knock and that will definitely do bad things to the ignition timing. |
#73 |
Drives: 2013 brz limited
Just wanted to add my experience from an ecu reset. I've been averaging 31 mpg since I got my car. Installed a catless front pipe and drove it and mpg stayed the same. Did a reset and avg mpg went up to 34. I've been driving the same,using the same gas and driving the same route. Was the mpg increase from the ecu adjusting to the front pipe?
#74 | ||
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
If you look back through this thread you will notice that this discussion began when we posted our initial gains from break in and Visconti said he felt that our gains were due to the advance multiplier, not from break in. Quote:
I am open to that possibility and would happily perform any test regimen we could use to prove it out one way or the other. I also intend to purchase the ECU TEK software in the not too distant future and we can further test things out by simply setting the dynamic advance multiplier to start out at 1. I am new to the Subaru control strategies, but I have been working on Toyotas since 1995, including work for corporate as an engine specialist and N/A and Hybrid powertrain engineer from 98 - 05. I know a thing or two about factory engine controls on Toyotas. And this is EXTREMELY consistent with the behavior you will experience on any Toyota with an ECU reset. Regardless of the reasons for it, that similarity definitely exists. Now it only remains to find out why - if the engines are simply overly conservatively rated HP wise, or if there is something else at work. Understand that I am doing this ONLY to try and further my own and the community's understanding of this vehicle. I have nothing but respect for John and ECU TEK, I am extremely impressed by how quickly they came to market and I have every intention of using their product. (John can confirm that I have been in communication with him since they announced it) This is not some attempt to discredit ANYBODY. Simply an attempt to learn, and a presentation of some theories for why things behave as they do. The test results we have to date indicate one of two possibilities: 1 - this car is actually considerably under-rated from the factory HP wise or 2 - There is something else going on with the ignition logic that we are as of yet unaware of. or 3 - This car has less drivetrain loss than any other RWD car I have ever seen. I offered my observation that this behavior was very conistent with normal Toyota ignition strategy. I was told that that is absurd and that the car is definitely running Subaru ignition strategy. I can accept that, but if so it means that the car in stock form is capable of over 180 to the tire in ideal conditions, which is pretty damn amazing. It is also a bit odd, considering manufacturers are not prone to understating HP claims these days. I would love to see some other shops or people duplicate the test - just pull the battery for 20 minutes after a few pulls, then hook it back up and see where your power goes. Last edited by Boosted2.0; 09-04-2012 at 07:03 PM. |
#75 | |
Anyhow I DO believe what you are saying John - I am just at a loss as to why we wound up gaining so much power from the reset when we run on 93 Octane in the first place. Based on your response to that test result I assume this is not a typical behavior. The only thing I can come up with is that the car is capable of producing higher WHP numbers than I had anticipated, and that even with 93 on board in the summer temps we get here the ECU has been pulling timing to below the 0.7 dynamic advance multiplier through normal driving. Would you concur that this seems to be the most likely explanation? Do you have any other ideas? I saw someone (maybe you?) mention that the ECU TEK software allows the multiplier to be set to a default of 1.0 instead of 0.7 - is this true? If so I may just buy it now and start playing with it to see where we wind up. |
#76 |
I must say that was a very calm and professional response to what I felt was a bit of a jab to ya. "GUESSING"
#77 |
Drives: Raven Black
#78 | |
Drives: 2013 Asphalt FR-S
#79 |
Exactly. ESPECIALLY if it is putting down 178 WHP at only 70% of possible ignition timing as the information from Visconti and others suggests.
#80 |
Thanks. I like John (Visconti) and am not trying to start a pissing match. I simply was reporting our findings and what I felt was a likely solution. John promises that my theory was not correct and I accept that. Which now begs the question of how we explain the car's behavior and dyno numbers.
#81 |
Reverse Burnouts
Drives: 2013 Argento FRS
tell me where to sign the 1400 check, i loved your manifold on my celica, made the car sound mean ;P
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#82 | |
Kuruma Otaku
x° + (y° * multiplier) ? Just throwing random stuff out there. But a multiplier over the whole thing seems rather coarse to me.
Because titanium. |
#83 | |
The exact method used is not as important as the fact of the power increase after reset to such a high level, with the promise of more. I'm thinking an excursion back to the 1/4 mile is in order to see if the MPH has changed significantly from the first time. |
#84 |
Drives: ITR
Like I said before, your settings are STD, not SAE corrected (more accurate). Once you change the settings, your whp is going to be more like 172 whp or less.
| BRZ on the dyno | Symbiont | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 05-22-2012 01:17 PM |
| When will magazines start testing the performance? | swift996 | BRZ First-Gen (2012+) — General Topics | 10 | 03-23-2012 02:10 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
