View Poll Results: Are you experiencing the same problem?
Yes - I have an aftermarket intake only. 14 9.21%
Yes - I have an aftermarket intake and a tune. 15 9.87%
Yes - I'm all stock. 11 7.24%
No - I have an aftermarket intake only. 43 28.29%
No - I have an aftermarket intake and a tune. 3 1.97%
No - I'm all stock. 66 43.42%
Voters: 152. You may not vote on this poll
Old 09-03-2012, 02:31 AM   #127
scioneric
scioneric's Avatar
Drives: Firestorm FR-S
Is your ECU flashed?
Mine is stock. But flash is on its way
scioneric is offline   Reply With Quote
Old 09-03-2012, 07:12 AM   #128
2forme
Originally Posted by Reason View Post
Is there a way to watch MAF signal (Hz?) with an obd2 reader? I would watch the maf signal and see if it's maybe actually disconnecting... someone else mentioned this happened with the mazdaspeed3 crowd when it was new and it turned out that intakes that relocated the maf and pulled the MAF wires really tight were actually causing disconnect issues.
I posted a graph of the MAF logging earlier in the thread.
Old 09-03-2012, 07:17 AM   #129
2forme
Originally Posted by Plxdjake89 View Post
Dude....ur car is fucked! Lol, do you even rev up the engine a lil before taking off, or do you just drop the clutch and smash on the throttle?
Yes. I know how to drive, thanks. None of those were clutch drops. The first gear jerks are normal takeoffs with clutch slipping.
Old 09-03-2012, 09:57 AM   #130
Plxdjake89
Plxdjake89's Avatar
Drives: 2013 Scion FR-S-white out
That's really weird dude....watching that makes me all sad, I just don't understand it
Plxdjake89 is offline   Reply With Quote
Old 09-03-2012, 10:50 AM   #131
Opposed
Drives: 2013 Asphalt FR-S
This is getting interesting. So far we have reported this issue with the Airaid and Injen intakes? I have the AFE intake coming, and im runnging the Ecutek stage1. I hope I don't end up in this thread with issues.
Opposed is offline   Reply With Quote
Old 09-03-2012, 10:53 AM   #132
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I'll be very curious to see what you find with the AFE intake. I was looking at the Greddy version of it since the Injen one I got worked for crap.
Old 09-03-2012, 10:56 AM   #133
Visconti
Drives: 05 STi
Originally Posted by scioneric View Post
Is weird mine is fine. Sorry to see yous in the video hope you fix it soon!
Call me in 30min
Visconti is offline   Reply With Quote
Old 09-03-2012, 11:09 AM   #134
Opposed
So you had issues too with your tune and the Injen? Hmmm...I will let everyone know once I get it installed what issues I have if any. Im sure somewhere down the line we figure this hiccup out, otherwise im going to just go with the Perrin drop-in and call it a day.
Old 09-03-2012, 11:14 AM   #135
neutron256
neutron256's Avatar
The Injen intake gave me problems both with and without the tune. I'm very curious about the AFE intake, as well as what Perrin eventually comes out with.
Old 09-03-2012, 11:16 AM   #136
Visconti
Drives: 05 STi
I'll have the intake in a few days .. Just need to spend some time with Mike's car.. Also trying to do a track rental next week and gave a few trips planned
Old 09-03-2012, 12:01 PM   #137
UncleFester
Sounds like a fix is on the way. Which intake are you getting/testing?
UncleFester is offline   Reply With Quote
Old 09-03-2012, 12:40 PM   #138
bpracer
Drives: Asphalt FR-S
I'm very interested in this as I have an Airaid intake that I have not yet installed.
I do find the off-idle throttle response to not always be very smooth in stock form. I have had a few large oscillations when accelerating slowly from a stop.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 09-03-2012, 03:05 PM   #139
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
If you need/want an Injen intake, I can try to talk to Adrian and see if he can send you one. Did he every drop you an email?
Symbiont is offline   Reply With Quote
Old 09-03-2012, 03:18 PM   #140
Brzce
Brzce's Avatar
Drives: WRBP BRZ Limited - Manual
I'm in the same spot. Haven't installed airaid yet due to incorrect threads on air tube. Will install when new part gets here.
I am able to confirm a hesitation below 2000 rpm when stepping on the gas while at a 5 mph roll. I've only tried it once - but watching the tach and feeling the car - its definitely there.
For me - I would never encounter this situation 'in the wild.'. Seems academic.
The closest situation for me would be rolling up an icy driveway - or up our icy road to the blacktop. I in fact do need to be able to creep the car along at 5mph I'm both cases. In neither case do I plan on mashing the pedal.
Once airaid is installed - I will see if the condition is accentuated and / or becomes non academic.
One a side note - I feel like I'm up to date on the feedback thread and this thread and I don't believe I've heard anyone say that they've checked for vacuum leaks after the install. If I have any issues upon install - I plan to get a can of carb cleaner and spray each changed interface and see if the motor revs up.
Regards, brzce.
Airaid 511-307 Intake - installed 08sept12
Brzce is offline   Reply With Quote
engine bogging, hesitation, intake, jerking motion
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
aftermarket rubber intake tubing??? 20valvewynn83 Southern California 39 09-13-2012 11:12 PM
Can anyone read Dutch? Buggy51 BRZ First-Gen (2012+) — General Topics 14 12-28-2011 09:48 PM
Toyota READ THIS Mr.Jay Off-Topic Lounge [WARNING: NO POLITICS] 1 12-09-2011 12:13 AM
