Old 08-31-2012, 10:37 PM   #15
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
What size are your wheels and tires? I have some Tein H Techs waiting to be installed but I'm thinking I want these instead.
Old 09-01-2012, 09:10 AM   #16
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
http://www.ft86club.com/forums/showthread.php?t=10244
Offset: 42mm
Backspacing: 5.82"
Bolt Pattern: 5-100
Rec. Tire Size: 225/45-17
Weight: 16.4lbs.
Finish: Matte Grey
Construction: 1 Pc. Cast
Finish Warranty: 1 Year
Manufactured in China
Walk like a King, Be like a Sir, Swag it out like a Boss
S2kphile is offline   Reply With Quote
Old 09-01-2012, 10:14 AM   #17
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Two questions:
- Why didn't you go for more front camber?
- Why the clunking? Your install looks just fine so that worries me. I was hoping that the Com-Cs would be a pretty robust, clunk-free solution.
Oh, and thanks a ton for the excellent post. Looking forward to your driving impressions.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 09-01-2012, 11:10 AM   #18
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
on the com-c...question on that. are they rubber based, where the mount sits on the spring? if its solid, it could be the cause of the clunking. I think... Ive had several issues with solid mounts.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 09-01-2012, 01:51 PM   #19
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The interface between the tophat and the upper spring perch is the same as stock. I think the OP should double-check the top nuts, as mine isn't clunking. Granted it's only been about 75-100 miles.
Old 09-01-2012, 02:18 PM   #20
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by mechaghost View Post
I had it installed at Tru-line Bellevue in WA. Byron the owner is a champ, he even leant me his B Series Mazda truck when the car was needed overnight. He also did the alignment, unfortunately no corner balancing as the car setup wont be able to do this. He is a top rated alignment specialist here in WA, and regularly does alignment on high end cars and track use cars.
How many hours did the install take at the shop? Thanks.
Phaedrus29 is offline   Reply With Quote
Old 09-01-2012, 02:33 PM   #21
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
yup, Ive had that issue too where the top hat nut is not properly tighten. Could be that then
Old 09-01-2012, 09:14 PM   #22
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Update on the Popping Issue: It is more of a popping sound that a clunking sound. This happens when I have the wheels more than 40% turned. It's not loud but is definitely noticable by me. None of the instructors noticed it though when I was driving, or maybe they thought it was a normal sound to hear and never pointed it out.
I just did a Skills Day with the Porsche Club here in Seattle. The car handled even better with the RCE Springs and the alignment.
Slalom: The car felt more settled and was better at keeping the backend in check. It allowed me to go faster through it.
Skid Pad: I was less prone to understeering and oversteering. It needed more gas to get the tail end loose.
Handling Oval: Tires were definitely the weak point as I am still on the Stock Tires. Entering the corners with heavy braking is good, but you still need to feather very lightly the gas as you unwind the corner. Also having too much speed on the turn causes understeer. (This was the case even before the suspension upgrade)
AutoX: People were saying I was staying flatter than the other Stock BRZ doing the course today.
DD Ride Comfort: I did not feel any difference with the Stock Springs
Truline quoted me a price and not by the hour. They did keep the car overnight though.
For the Camber, I'm not the suspension expert, truline are the suspension experts and that is what they said would be reasonable compromise for a DD and AutoX.
mechaghost is offline   Reply With Quote
The Following User Says Thank You to mechaghost For This Useful Post:
rs999 (08-21-2014)
Old 09-01-2012, 09:15 PM   #23
mechaghost
mechaghost's Avatar
Top nuts are secure. The car is handling perfectly so I need to figure out what is causing it. Tuesday will bring answers when I bring the car in
Old 09-01-2012, 09:39 PM   #24
mechaghost
mechaghost's Avatar
I had my gf turn the wheels for me while I look at it. The popping is coming from the Top Mounts
Old 09-01-2012, 09:58 PM   #25
Racecomp Engineering
Make sure the springs are properly seated. They definitely shouldn't make any noise.
Old 09-01-2012, 10:34 PM   #26
mechaghost
mechaghost's Avatar
they look properly seated... i raised the car and turned the steering while the wheels were off the ground and same popping noise.
have you guys heard of the same issues with other installs?
Old 09-02-2012, 04:15 AM   #27
r4m3n
r4m3n's Avatar
Drives: Ultramarine FR-S
Gonna get my RCE springs installed this Wednesday. Looking forward to it...hope the popping sound isn't an issue.
BTW, i'm in Seattle for PAX...
6.4.12 | Ultramarine | SoCal
r4m3n is offline   Reply With Quote
Old 09-02-2012, 10:53 AM   #28
Draco-REX
Corner Junkie
Draco-REX's Avatar
While someone turns the wheel, check to make sure the nuts in the tophats are turning. Also, again while someone is turning the wheel, look at the upper spring perches and see if they are turning also.
White n' Yellow. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 08-02-2015 04:01 AM
Yellow fog tint looks awesome! DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 37 11-07-2012 03:40 AM
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 08:12 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
FT86s at Megaweb (more footage of the yellow 86) ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 05-26-2012 02:08 PM
