#29 |
Drives: WRB MT-BRZ LMTD
Woot I get mine this friday, its not the II one but its the first one. Both are pretty much the same anyway but one has better operation temperature range and compression. But other than that, meh.
Cant wait for mine to arrive! I do wanna hotwire it but I dont know how
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM Traded for Black 2013 Camaro 2SS RS |
#30 |
Drives: truck and old car
#31 |
Did you check out how it was done?
#32 |
SLO NO MO
J
Just pick up a mini add-a-circuit (aka add-a-fuse) http://www.parts-express.com/pe/show...number=071-585 from your local auto parts store, amazon, ebay, etc.
Pick any existing 10AMP fuse in your fusebox, pull it out, plug in two 10AMP fuses to the add-a-circuit. Plug the add-a-circuit into the now-empty fuse receptacle. Now you have a spare power lead that is protected by its own fuse. Run your camera wire to that, and ground it to any bolt near the fuse box (there's one conveniently right in front of the box towards the firewall). |
| The Following User Says Thank You to Foobar For This Useful Post: | Want.FR-S (08-30-2012) |
#33 |
The things that go on when you are not around. Sure gets a lot of attention!
#34 |
As "FOOBAR" mentioned; I believe they ran the wire on inside the panelling, starting up by the rearview mirror, then down the drivers side to fuse box, so you don't see any wire.
You do know you can also plug it in your lighter for starters, if you don't mind a wire showing. this is a great video review that explains how to set it up and also a forum that answers tons of questions: http://forums.redflagdeals.com/merge...hread-1147913/ |
#35 | |
Grip>Slip
#36 |
Drives: White FR-S
Drifter, Is this in Monterey?
#37 |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Mine was 50 bucks on ebay, and works fine. Blackviews are actually worth stealing which kind of defeats the point. Auto on/off and looping recording on the memory stick are all you need.
#38 |
Currently I have mine plugged in to the glove box power and wires are hidden using the headliner and the rubber thingy.
But I would like to use the parking features XD Ill figure it out. For now, glove box power is temporary solution. For some reason, the quality isnt as good as I thought it was going to be.
#39 |
Yup, that part was Pacific Grove, next to Monterey.
Well, they better make sure they complete the job or they will be on youtube for the world to see. Also, if anyone gets one, make sure you go into the set up menu and disable the "park mode light". Otherwise when parked, you will see a glowing light which could attract unwanted attention. |
#40 |
Drives: 2013 Argento Silver FR-S
Should we keep adding to this thread or start an official video thread?
Here's one from this morning: [ame="http://www.youtube.com/watch?v=4QD-CY4P2_4"]http://www.youtube.com/watch?v=4QD-CY4P2_4[/ame] |
| The Following 3 Users Say Thank You to cgrey For This Useful Post: |
#41 |
^ Only problem with that vid is it looks like you may been going a little to fast. I didn't see the MPH in vid.
#42 |
Drives: Nissan Altima
Do you have a link to it by any chance?
| Anyone use a dash cam? | hansthegerman | Electronics | Audio | NAV | Infotainment | 54 | 01-12-2019 02:58 AM |
| Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 04:48 AM |
| Dash Kits? | KRAZYK | Electronics | Audio | NAV | Infotainment | 10 | 03-11-2013 11:49 AM |
| What do you use to wipe off dash? | Memphis | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 08-22-2012 11:40 AM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 11:06 PM |
