View Poll Results: Best wheel size for stock power?
17x8 173 36.58%
17x8.5 29 6.13%
17x9 80 16.91%
18x8.5 37 7.82%
18x9 21 4.44%
18x9.5 22 4.65%
Staggered (please list sizes below) 14 2.96%
Other- I am interested to know. 97 20.51%
Voters: 473. You may not vote on this poll
Old 08-26-2012, 05:17 PM   #15
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
Originally Posted by Kairos View Post
The problem is not that they are 18's, it's that you bought 28+ lb. wheels. Get a 18x9 that weight 18 lbs and I guarantee you'll see a huge difference. I believe the stockers are 20-22 lbs so you added alot of extra weight to rotate.
I didn't buy the works for this car in particular, and I think they are closer to a 22-24lb wheel, probably not a 28+, but I get your point. I think the front tires contact patch is a balancing act as well.
Tanuki is offline   Reply With Quote
Old 08-26-2012, 05:20 PM   #16
Mitch
form follows function
Drives: RIP '13 BRZ
Originally Posted by D1cker View Post
a light 17x9 with a 245/40/17 will be ideal for a car that sees the track and autocross as well as the street, if it's more of a street car, go with 235/40/17.
18's look better but the 17 will be better for performance.
I think the size is just a matter of opinion. I think 18s make the brakes look ridiculously small. I'm running 17x8 RPF1s with 255/40 Star Specs. I'll probably go to 245/40 next time just to see if I can feel the difference.
Mitch is offline   Reply With Quote
Old 08-26-2012, 05:44 PM   #17
D1cker
Drives: B9 S4/ND2
The 255/40 works as well, but with an 8" wide wheel you can't really utilize it. When I was doing time trials in miatas, a 225 on a 9" wheel would be faster than a 225 on an 8" wheel, The 235 is abour as big as I'd want to run on an 8 before running into diminishing returns (excluding autocross, which I'm not really into)
D1cker is offline   Reply With Quote
The Following User Says Thank You to D1cker For This Useful Post:
Tanuki (08-26-2012)
Old 08-26-2012, 06:00 PM   #18
Mitch
Drives: RIP '13 BRZ
My setup is for autocross, so there ya go. 245 may be the sweetspot for me.
The Following User Says Thank You to Mitch For This Useful Post:
Tanuki (08-26-2012)
Old 08-26-2012, 06:00 PM   #19
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
P
white_knight is offline   Reply With Quote
Old 08-26-2012, 06:38 PM   #20
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
I will be looking for a 18x7.5 with a 42-45 mm offset
OEM
17x7 5-100 48mm offset with 215/45-17 tires
Sidewall 3.8 in
Radius 12.3 n
Diameter 24.6 in
Circumference 77.3 in
RPM 819.0
Option 1
18x7.5 42-45mm offset wheel with 235/35-18 tires
Sidewall 3.2 in
Radius 12.2 n
Diameter 24.5 in
Circumference 76.9 in
RPM 824.0
Option 2 = Expensive as all Hell
19x7.5 5-100 42mm offset 235/30-19 tires
Sidewall 2.8 in
Radius 12.3 in
Diameter 24.6 in
Circumference 77.1 in
RPM 821.0
I learned over the years that if you keep the RPM close and the weight down you only lose by the drag created from the width, any deviation from this has direct effect upon gearing and power bleed.
Spartan65 is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartan65 For This Useful Post:
Bonburner (08-27-2012), Tanuki (08-26-2012)
Old 08-26-2012, 06:57 PM   #21
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
How will it affect the trip/odom/mpg comp reading?
Old 08-26-2012, 06:59 PM   #22
D1cker
Drives: B9 S4/ND2
OEM
Sidewall 3.8 in
Radius 12.3 n
Diameter 24.6 in
RPM 819.0
Option 1
Sidewall 3.2 in
Radius 12.2 n
Diameter 24.5 in
RPM 824.0
Sidewall 2.8 in
Radius 12.3 in
Diameter 24.6 in
RPM 821.0
The problem with this is that almost no one makes a 235/35/18. 245/35/18 will be a lot more readily available or 225/40/18
The Following 2 Users Say Thank You to D1cker For This Useful Post:
JimmyMac (08-26-2012), Tanuki (08-26-2012)
Old 08-26-2012, 07:19 PM   #23
D1cker
Drives: B9 S4/ND2
It depends on the diameter of the tire. If you go with a 235/40/17 the speedo will read just a smidge high, where if you go with a 245/35/18 it will read a bit low.
Google a tire calculator and you can input different tire sizes to get an idea.
Tanuki (08-26-2012)
Old 08-26-2012, 08:02 PM   #24
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Better yet, use this calculator. Just type in stock spec on the left, and what you want to try on the right. Remember stock is:
215/45-17x7+48
Here is the link:
http://rimsntires.com/specs.jsp
JimmyMac is offline   Reply With Quote
The Following 2 Users Say Thank You to JimmyMac For This Useful Post:
Tanuki (08-26-2012), tripjammer (04-08-2013)
Old 08-26-2012, 08:41 PM   #25
Spartan65
Spartan65's Avatar
Falken makes the Ziex, probably the least expensive.
FALKEN ZIEX 912 ALL SEASON 235/35R18 140-165$ per
and the
BFGoodrich g-Force T/A KDW-2 approx 180-195 per
Old 08-26-2012, 08:46 PM   #26
Spartan65
Spartan65's Avatar
18x7.5 ET 45
When speedometer reads 60mph (96.6km/h) actual speed will be 61.8mph (99.5km/h): 3% faster.
19x7.5 ET 45
When speedometer reads 60mph (96.6km/h) actual speed will be 59.9mph (96.4km/h): 0.2% slower.
Old 08-26-2012, 08:47 PM   #27
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
Thanks for the info on those calculators.
Old 08-26-2012, 08:50 PM   #28
Spartan65
Spartan65's Avatar
Seriously a smidge?, you sound like the guys that tried to sell tires with me when I was at DTC. I retired (sorry about the pun) from DTC, three words " I know Tires"
http://www.miata.net/garage/tirecalc.html
optimal street tire size for RTR on 17x7 hankster Tracking / Autocross / HPDE / Drifting 110 03-21-2013 12:40 AM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Stock Wheel Size Confirmed..? CoryUyede Scion FR-S / Toyota 86 GT86 General Forum 4 12-22-2011 12:26 AM
Wheel size, what's your opinion? #87 Off-Topic Lounge [WARNING: NO POLITICS] 4 02-24-2010 03:06 PM
