Old 08-24-2012, 11:29 PM   #15
AVOturboworld
Originally Posted by Superhatch View Post
x2
I stopped in at my Subaru dealer last week and they said they couldnt order any JDM parts. They said it would likely be next year when any parts would be released to the US dealers.
Aside from ordering from Subaru.jp, is there a JDM Subaru parts outlet? I'd really like to get an STI suspension (this one when released, not the current springs) and other bits if possible.
Our sister site, avojdm.com, will have them available as soon as they are released.
Old 08-24-2012, 11:32 PM   #16
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
Originally Posted by Skyllz View Post
No intercooler no care...
Yeah, if this is what STi has in mind for the BRZ STI and they aren't planning on a turbo version so as to not compete directly with the Impreza STI and the Legacy FA20T, then I feel pretty good thinking about buying P&L's turbo kit.
Although, I do think if/when the BRZ STI suspension is available in take-off JDM form, I think I will run those.
vubaru is offline   Reply With Quote
Old 08-25-2012, 12:23 AM   #17
(K)
They call me..."Ken"...
Drives: '04 Accord V6 MT
Is that a CF roof cap or an actual CF roof? Agreed that the lip spoiler is ugly and I almost want to question it's functionality just from looking at its minimalist design. But I won't.
(K) is offline   Reply With Quote
Old 08-25-2012, 12:49 AM   #18
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Anyone think these rear skirts will fit with the Subaru OEM rear diffuser accessory?
About the 2-tone remarks... well... a stock BRZ already comes with a black bumper guard, black tail pipe surround, and black on the fender garnish and side mirror housings. The STI skirts enhance the existing stock black pieces, IMO. I just don't like the STI rear spoiler and how the carbon hood contrasts to reveal the ugly square-ish hood line.
Old 08-25-2012, 02:24 AM   #19
AVOturboworld
The hood and the roof in CF are each about 3kg, or 6.6lbs, lighter than the stock.
Old 08-25-2012, 02:32 AM   #20
JDM-dono
JDM-dono's Avatar
Drives: WRB BRZ '13
each time I go onto this forum, I find another reason to spend money ... I'm going to be poor after this.
JDM-dono is offline   Reply With Quote
Old 08-25-2012, 02:40 AM   #21
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
can anyone explain the function of the rear diffuser? better airflow underneath? btw, i like how the STI BRZ looks!
SuperDave is offline   Reply With Quote
Old 08-25-2012, 04:21 AM   #22
JDM-dono
JDM-dono's Avatar
Drives: WRB BRZ '13
Before I explain what a rear diffuser does, I should note that the above rear diffuser from subaru is not functional and purely aesthetics.
For a car without a rear diffuser:
- Air hits the front of the car causing a high pressure region in front of the car
- Behind the car there is a low pressure region (think of it like a void)
- Pressure tends to go from high pressure to low pressure
- So basically what happens is that the car is forced backwards because of high pressure region in the front and low pressure region at the rear (this is known as drag)
Car with a rear diffuser:
- Air hits the front of the car -> high pressure region in front of car (as per above)
- This time because we have a rear diffuser, air expands at the bottom rear end of the car where rear diffuser is located
- According to fluid mechanics equations, expanding the air causes the air to slow down
- Air that is slower is associated with higher pressure
- So now we have high pressure region at the front, and high pressure at the rear thereby reducing drag. (high pressure at rear pushes the car forward)
Old 08-25-2012, 04:23 AM   #23
JDM-dono
JDM-dono's Avatar
Drives: WRB BRZ '13
Considering that the hood and roof are wet carbon fibre parts, I'm assuming that we can't paint it to color match the body?
No point for me to think about getting hood or roof if I can't color match it to the body.
Old 08-25-2012, 05:08 AM   #24
serialk11r
Drives: '06 AM V8V Coupe
Yes, the OEM "diffuser" is useless because it does nothing to improve the airflow below the car, which is not great because we have the diff, exhaust pipe, suspension, etc. sticking out causing drag. To improve aerodynamics, those should first be covered, and then you can look at the "diffuser" portion. The stock "angle" (try to picture a curve that would fit snuggly under the muffler and plastic bumper piece) is probably right on the dot for drag reduction, without going past the bumper.
Old 08-25-2012, 10:06 AM   #25
Turbowned
Turbowned's Avatar
Anyone else think those side skirts look terrible?
I want to know if the rear bumper winglets, the Subaru "diffuser" and the TRD diffuser will all work together with the right exhaust system. My guess is probably not, but you never know! Looks like the TRD diffuser is a really simple piece to replicate.
Old 08-25-2012, 10:31 AM   #26
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Is it pretty normal for a company like AVO to get invited out to see a concept-ish car like this or was Subaru courting you guys for something?
I think most of the STI body bits don't look great. I wish they stuck with something more like the chargespeed sideskirts instead of ones that creep up the sides like that. The wing is questionable at best. The carbon fiber roof is nice though. 6 pounds off the top of the car is great!
Where was this piece? I really wanted to see this thing so I can replace the crappy one on my car. I don't care if it's rice! I'll add a STI oil filter to make it legit.
industrial is offline   Reply With Quote
Old 08-25-2012, 10:47 AM   #27
86BRZ
86BRZ's Avatar
Drives: BRZ Limited arrived on 9/1/2012
It looks so different than the STI from the car show. No wider body, no bigger wing, no new tail lights, etc. Is the a self upgrade and stick on a STI badge ? I can see most of these upgrade are after market parts. Yes, the side fender STI badge is missing too.
86BRZ is offline   Reply With Quote
Old 08-25-2012, 11:18 AM   #28
jeebus
not really feeling most of it.
jeebus is offline   Reply With Quote
brz forum, brz forums, brz sti, brz sti forum, brz sti forums, brz sti news, brz sti photos, brz sti pics, brz sti rumors, brz sti specs, subaru brz forum, subaru brz forums, subaru brz sti, subaru brz sti forum, subaru brz sti forums, subaru brz sti news, subaru brz sti photos, subaru brz sti pics, subaru brz sti rumors, subaru brz sti specs
BRZ wins Gymkhana event in Japan Spaceywilly BRZ First-Gen (2012+) — General Topics 18 04-26-2012 09:39 AM
86/BRZ owners offsite event in Japan yajin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 04-18-2012 03:09 PM
Full Subaru BRZ Site (JDM) Now Launched + Subaru Event Zaku BRZ First-Gen (2012+) — General Topics 81 02-07-2012 02:47 PM
Subaru Of Japan Finance Deal Jayvelliott BRZ First-Gen (2012+) — General Topics 13 02-03-2012 05:29 PM
