#57 |
Drives: 2013 BRZ Limited
#58 | |
also are 1157 the stock brake light bulb size too? |
#59 |
I picked up one socket and a two pack of 1157 bulbs at Autozone (in the store).
#60 |
Drives: nissan frontier, DGM MT BRZ
How are you keeping the water out???
#61 |
The stock reverse sockets seal pretty well without water entry.
When I did my project, I also put some hot black glue to help seal it. I also created a plastic piece to go below the wiring (above the exhaust) where the center bumper cutout is and tie wrapped it to make sure. Furthermore, I pressure checked it. I also did the water test on the inside for leakage, and vacuumed it all out (including any condensation). It's bulletproof regarding moisture entry. Bottom line, get a good socket, do a good job, and you won't have to go through and do all the testing I did.
| The Following User Says Thank You to xcelir8brz For This Useful Post: | Dadhawk (07-16-2012) |
#62 |
anybody who did this mod get condensation?
#63 |
No condensation.
#64 |
Drives: 2013 SCION FR-S FIRESTORM
nice
Did any warning lights come on after your installation was done? such as bulb out warnings .....ect Last edited by ichitaka05; 03-27-2013 at 09:43 PM. |
#65 |
Boostin'
Drives: FRS-T
no not at all!
#66 | |
Also the FRS has no wiring for the rear fog light, I am not sure about the front. |
#67 |
Sarcastic SOB
If you really want it done right toss the electrical tape and use shrink tubing.
| The Following User Says Thank You to wbradley For This Useful Post: | SkAsphalt (12-22-2012) |
#68 |
Drives: 2013 Scion FR-S-white out
I used a 194 t10 led, works and looks great
| The Following 2 Users Say Thank You to Plxdjake89 For This Useful Post: | calis5nest (12-29-2012), JFBRZ711 (01-29-2014) |
#69 |
Sarcastic SOB
Correct me if I'm wrong, but the bulb out warning is the issue people get installing LEDs on a Canbus enabled harness? Apparently Canbus standard is used in most all Euro (German) cars.
#70 |
Only on blinkers.
| Automation Lighting offers HID xenon headlight + foglight kits | jjdrivesajazz | Exterior Parts - Lighting | 138 | 01-13-2014 02:19 AM |
| rear seats? | EJ20 | BRZ First-Gen (2012+) — General Topics | 67 | 11-12-2012 08:15 PM |
| Rear Bumper Foglight | kanundrum | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 06-08-2012 01:47 AM |
| 215/40-17 front, 225/40-17 rear? | ZDan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 01-21-2012 03:08 PM |
