Drives: Toyota GT86
Need help, GT86 left and right height difference
Hi all, I am newbie here and this is my first post in this forum
![]() I just got my GT86 3 days ago, very happy with it. But I noticed small problem with the height difference from ground to top of wheel wells between left and right side. When I measure it, it appears that the front left side of the car (passanger) is 3-3,5mm higher than the front right side of the car (driver side). Anyone experience the same problem? Is this normal? What's the cause of this? Can I repair or fix this 3,5mm height difference between left and right side? Will the trd coilover fix this issue? Please help Thank you in advance
#2 |
Drives: Toyota GT86
Oh yeah, I park my car on flat surface/ground during the height measurement
#3 |
Drives: 13 Firestorm FRS
This may sound silly, but have you checked the tire pressure?
#4 |
Drives: 2013 Hot lava Fr-s, 2007 Mazda 3
/\this!
Raising the bar one step at a time!
Kansas City FR-S/BRZ Facebook group. https://www.facebook.com/groups/452909128083343/ Hotlava86's Build thread!http://www.ft86club.com/forums/showthread.php?t=14152 |
#5 |
Drives: BRZ and NA
Actually, it's pretty normal for stock cars to be off a little bit. Go ahead and measure some other random cars at a lot (make sure to measure hub to fender) and you'll see that all the cars aren't exact.
Most people only notice this when they are swapping suspensions out and they want to get a differential measurement. |
#6 |
Drives: Toyota GT86
Right, I forgot to check the tyre pressure. Will check it soon.
By changing coilovers, can I adjust the same height on all 4 corners? Or it will still uneven at one or more corner? Think about getting TRD coilovers, so want to know if those coilovers can fix this uneven ride height ... Thanks for replying
#7 |
The coilovers should be able to fix the issue. Whoever is aligning the car, should be able to adjust it accordingly.
#8 |
Enthusiast
Drives: 2013 Scion FR-S (37J)
Tire pressure -OR-(most likely) to compensate for a full tank of gas, so check pressure and fill her up!
#9 |
Drives: Toyota GT86
Thank's guys. Fuel tank is at full position, next check point is tyre pressure, need to borrow the tool from my friend. 3mm should be easy to fix by using coilovers, I may choose TRD coilovers. Anyone fit this TRD coilovers before?
| Left hand drive GT86 exist? | hotmetal | Scion FR-S / Toyota 86 GT86 General Forum | 62 | 01-04-2018 01:22 AM |
| Need help with Stock height measurement | D1cker | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 08-03-2012 03:30 AM |
| BRZ/FR-S Trunk Height? | ngabdala | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-24-2012 01:41 PM |
| Dead pedal height | bqe-lie-fdr | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 02-25-2012 08:21 AM |
| Lower ride height in NYC? | blur | NY / NJ / CT / PA | 9 | 01-19-2012 06:31 PM |
