Old 08-16-2012, 01:54 AM   #407
Allch Chcar
Drives: N/A
Originally Posted by R8 View Post
Well supposedly just as the Boxer's shape made the Twin's chassis possible, the tiny rotary also made the RX-8's chassis and handling possible. Stuff in a piston engine, and it'd become more nose-heavy and probably no longer be a mid-engine car.
That little worse balance(the Renesis weighs almost exactly the same as the MZR) would have been a fair trade for a vehicle that has trash for resell value. A '04 RX-8 GT is worth the same or less than a base '04 MX-5. Brilliant idea though but the implementation wasn't good and that isn't the chassis' fault.
The S2000 still had good balance and had an "inferior" piston 4 banger. So I'd say the placement is just marketing fluff. An interesting anecdote is that the two share a transmission design and it's probably one of the more common failures that the two share. :-/
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 08-16-2012, 02:08 AM   #408
serialk11r
Drives: '06 AM V8V Coupe
They also share the most retarded highway cruising gearing ever conceived for any <3L displacement engines (I think?)
Old 08-16-2012, 03:15 AM   #409
CSG Mike
CSG Mike's Avatar
Originally Posted by CSG David View Post
So at the track I mentioned (Autoclub Speedway) there is a straight that you can get up to about 125mph (Mike hit 133mph with draft) on the BRZ before you take the NASCAR left curve to hit a straight and then enter the infield. When you're "cornering" at 120+mph (S2ks with big wings are doing 130-135mph) the BRZ/FR-S is quite "planted". The rearend is significantly more stable than the base S2k. Even the CR will feel somewhat floaty, but that rear wing does keep the rearend a little more tame. I drove a base 08 AP2 prior to the BRZ and hit about 125mph+ before the turn. The moment I added a few degrees of angle, the car's rearend felt very floaty and there were noticeable corrections needed to be made with the steering. Since I didn't want to risk crashing someone's car, I decided to go 50% throttle instead of 100%. This dropped the speed down to about 115-120mph and did not feel very confident.
From that experience, I knew straight off the bat the aero on the BRZ/FR-S was significantly better than the S. The car still produces lift, but definitely not in the same order of magnitude that the S2 does.
I was hitting 125 when you were in the car. I was hitting 128 when I went solo
Some data points for the others in the thread.
I won my class in S2k Challenge with an "undermodded" car. S2k CR with wheels, tires (RS3), exhaust, and tune. The S2k was hitting a Vmax of 128 entering Turn 1. Exiting Turn 2, I am able to hit 132-133 before I have to brake for T3. The S2k enters the front straight at about 88-89 mph. I dare say that I am driving the car at 99% of the limit, especially considering how non-technical this track is.
The BRZ hit a Vmax of 128 entering Turn 1. However, the car lacks the power to push through in 6th gear, so I have to sit near the limiter in 5th. It also scrubs more speed due to the rear not being pushed forward, even at WOT through Turn 1/2. I exit 2 at 125, and never get past 128 before having to brake for T3. The BRZ enters the front straight at 83-84 mph.
The BRZ is at about a 55hp disadvantage, but is able to accelerate up to the same Vmax in the same distance, while starting at a lower speed. The car is slips through the air far better than the s2k, which I originally speculated months ago. Both the CR and BRZ have been dynoed.
The BRZ does create rear lift at speed, so it doesn't completely address the S2k's aero flaws...
BRZ in action at Auto Club Speedway:
[ame="http://www.youtube.com/watch?v=waCr19ZM640"]Subaru BRZ Auto Club Speedway - YouTube[/ame]
Per AMB:
Timing alias, time, session, avg mph.
S2k: psychoazn 1:58.224 Red 2 85.300
BRZ: psychoazn 2:04.812 Black 4 80.800
Old 08-16-2012, 04:20 AM   #410
samsam5886
Drives: Honda S2000
Hello Mike!
samsam5886 is offline   Reply With Quote
Old 08-16-2012, 04:20 AM   #411
Motopythons
Let it rain!
Motopythons's Avatar
Drives: 2012 Subaru Imprezza
Originally Posted by MY13FRS View Post
I agreed with you on all points. I gave up my S2K for the FRS because of something that means a lot more to me...back seats for the kids.
Don't listen to them. I never understood why 99% of the people are saying the back seats are useless. I'm 6'2, and I put 2 fine ladies at the back without any complaints from them. The backseats are definitely usable. Hope you enjoy the car!
"If you no longer go for a gap that exists, you're no longer a racing driver." - Ayrton Senna
Motopythons is offline   Reply With Quote
The Following User Says Thank You to Motopythons For This Useful Post:
Surok (09-22-2012)
Old 08-16-2012, 04:37 AM   #412
worfworf
Drives: Honda Odyssey, Evo X
Don't know...
I tried to put two of my kids in a brz at the dealer - one couldn't squeeze his legs in the back seat - he's only 6.
Wife saw that and grimaced... my hopes of buying this car is fleeting fast!!! A couple of more inches...
Sent from my iPad using Tapatalk HD
worfworf is offline   Reply With Quote
Old 08-16-2012, 04:38 AM   #413
CSG Mike
CSG Mike's Avatar
I'm only 5'7", and I can promise that NOBODY will be sitting behind me unless they don't have legs...
Old 08-16-2012, 04:52 AM   #414
Lasse
Drives: Avensis 2.2 diesel
So, what was dynoresult for both cars?
Lasse is offline   Reply With Quote
Old 08-16-2012, 05:33 AM   #415
CSG Mike
CSG Mike's Avatar
BRZ: 170whp
S2k: 222whp
Both are SAE corrected on a dynojet. S2k has a J's 70RR and tune.
Old 08-16-2012, 09:54 AM   #416
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Originally Posted by Marrk View Post
Sorry. I didn't notice your sig.
No worries at all. Believe me, I have A LOT to learn.
On another note, I took the track s2k to the autocross. Lots of fun!!! Can't wait to try out an FR-S!!
[ame="http://www.youtube.com/watch?v=p3p_94tDdt8&feature=g-upl"]MSNE 8/12/12 - 52.6xx - YouTube[/ame]
iLuveKetchup is offline   Reply With Quote
Old 08-17-2012, 03:37 AM   #417
Lasse
BRZ: 170whp
S2k: 222whp
Thanks Mike. Wow, nice numbers from SK2!
Old 08-17-2012, 01:48 PM   #418
Coaster
Coaster's Avatar
Drives: Civic
Nice view of the new Giants stadium in the video.
Coaster is offline   Reply With Quote
Old 08-28-2012, 12:20 PM   #419
bungholio
bungholio's Avatar
Drives: S2000
Interesting yet not surprised to see you here Clyde lol
bungholio is offline   Reply With Quote
Old 08-28-2012, 02:49 PM   #420
iLuveKetchup
Drives: EFF JAY
:happy0180: What's up Marty! I need to get a hold of you for some GTSPEC parts.
Thinking of Buying either MR-2 Spyder or an AP1 S2000 FT///R86 Other Vehicles & General Automotive Discussions 33 12-29-2011 01:53 AM
S2000 or MX-5 balance Other Vehicles & General Automotive Discussions 10 11-01-2011 03:01 AM
S2000 from hell CyberFormula Other Vehicles & General Automotive Discussions 13 07-09-2010 10:05 PM
The Real S2000 Successor S2KtoFT86 Other Vehicles & General Automotive Discussions 10 02-12-2010 02:21 AM
Honda S2000 Mugen Hard Top Headliner S2KtoFT86 Other Vehicles & General Automotive Discussions 3 01-15-2010 02:43 PM
