Old 08-05-2012, 05:37 PM   #15
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
My stock knob never rattled, but the Flossy knob that I just installed yesterday not only rattled, but the custom engraving wasnt lined up correctly when the knob was completely tight. I fixed the rattle and the alignment by removing the knob and wrapping the shifter threads with some plumbers tape and then pushing a rubber washer from an old garden hose sprayer that I don't use down into the bottom of the knob. No more rattles, no accidental spinning, and its perfectly aligned now!
The Following User Says Thank You to ATL BRZ For This Useful Post:
Brzce (09-03-2012)
Old 08-05-2012, 07:03 PM   #16
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by Sigh-on-Rice View Post
Does it rattle even when you have your hand on the shift nob? I've never heard my shifter making rattle noise. I always keep my hand on the shift nob unless I'm just cruising at a speed.
Always leave your hand on the shifter? I haven't pulled this transmission apart but I've built a few manual transmissions and often times the shifter forks are aluminum and the guide tabs of the fork that sit inside the collar will wear out REALLY fast if you do this. If the shift forks are steel then the wear will be less but conversely they will still wear and worse off could potentially create steal shavings which can shorten the life of the bearings and seals in the transmission. Overly worn shift fork tabs can lead to sloppy/difficult shifting, popping out of gear or the eventual broken shift fork.
I had the same habit when I was younger right up until I rebuilt my first transmission in tech school and once I saw how it all worked I treated my transmission very differently.
back on topic: My shifter rattles to and I really notice it because I have a steel slinky around it (with company logo) so that rattles too when I romp it and it makes a cool clanking noise during shifts.
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
Guff (08-06-2012), Sigh-on-Rice (08-05-2012)
Old 08-05-2012, 07:25 PM   #17
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
So with your transmission experience why is it rattling?
Hanzo is offline   Reply With Quote
Old 08-05-2012, 07:26 PM   #18
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Rice, thanks for the info. I now know not to do that anymore.
Old 08-06-2012, 01:01 AM   #19
rice_classic
They just do?
S2000 experiences the same thing, or any FR for that matter where the shifter goes directly into the tranny without linkages or cables. Unlike a "shift by wire" or a FWD car with linkages or cables, the NVH of the transmission is transferred into the shifter. Shifter vibration is normal, unless it's "floppy", then you have other problems.
The Following 3 Users Say Thank You to rice_classic For This Useful Post:
empower-auto (08-13-2012), Guff (08-06-2012), Sigh-on-Rice (08-06-2012)
Old 08-06-2012, 05:17 AM   #20
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Shifter vibration is normal, but what about audible rattling?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
The Following User Says Thank You to ultra For This Useful Post:
Hanzo (08-06-2012)
Old 08-06-2012, 02:01 PM   #21
rice_classic
I would say we should first identify "what" is rattling. This shifter itself isn't necessarily the culprit but something holding it or attached to it. It may be the collar used for getting the thing into reverse or it may be a plastic bushing.
Going back to the S2000, while the vibration is normal some of them had their plastic bushing crack allowing a bit of freeplay which led to rattling. Since these tranny designs aren't too far off from each other I'd say that could be a possibility (but I doubt it due to the low mileage of these cars).
Remove your center console and shift boot and go for a drive. You might be able to pin-point it that way.
Old 08-06-2012, 02:06 PM   #22
Hanzo
Hanzo's Avatar
It doesn't always rattle, only when it's warmed up.
Old 08-06-2012, 02:15 PM   #23
pyro530
Drives: Ultramarine FR-S 6MT
I'm pretty sure I know what you're talking about because mine does the same thing and I'm pretty sure I know where the sound is coming from.
It's from the reverse lockout ring/mechanical. I quite like it because it reminds me of my dad's '59 Corvette that also has a lever you have to pull up on to get the car into reverse.
Current: FR-S Ultramarine 6MT - Took delivery 05/30/2012 - Now for sale here
1995 M3 Coupe MT - the "Bavarian Bumblebee"
Past: 1994 Integra - Sold | 2005 Dodge SRT-4 - Totaled by Hail | 1997 Acura 2.2 CL slowmobile - Sold | 1991 BMW E30 - Sold | 1991 Acura Integra GS - Wrecked | 1971 Chevy C-10 shortbed stepside - Sold | 1973 Camaro Z-28 Clone - Stolen
pyro530 is offline   Reply With Quote
Old 08-06-2012, 03:36 PM   #24
alrashwa
alrashwa's Avatar
Drives: '12 370Z Monterey Blue
I've also been hearing this
I've been getting a similar "jar of marbles" type of sound when I'm usually in 2nd or 3rd.
Mine's already in the Toyota service center for just about every other issue people have mentioned on the forum. I love the car, feels great, but I'm really surprised so many things got past quality control at the Fuji/Subaru plant.
alrashwa is offline   Reply With Quote
Old 08-06-2012, 04:01 PM   #25
ultra
Curious cat.
ultra's Avatar
Exact same thing here. Once warmed up the rattle is consistent from 5k+.
Old 08-13-2012, 02:13 PM   #26
Hanzo
Hanzo's Avatar
Anyone else with this problem?
Old 08-13-2012, 02:23 PM   #27
empower-auto
Kouki-Monster
empower-auto's Avatar
They just do?
For posterity
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
alrashwa (08-13-2012)
Old 08-13-2012, 02:51 PM   #28
rice_classic
Originally Posted by empower-auto View Post
For posterity
Flywheel Rattle? CB762 Issues | Warranty | Recalls / TSB 119 11-16-2016 11:09 PM
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 11:56 PM
Flimsy shifter chessplaya2010 Issues | Warranty | Recalls / TSB 1 07-31-2012 02:21 PM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 08:46 PM
FR-S Shifter Video xravexboix FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 04-21-2012 09:20 PM
